Question about Philips SHN9500 Consumer Headphones
The left headphone speaker of my Philips SHN9500 does not longer function properly. When I twist the jack-plug of the wire it sometimes connects and transmits the sound. If I don't fully insert the jack-plug (about 2 milimeter removed from complete insertion) then both headphones transmit sound (Mono). My headphones are not any longer covered by warranty. Is there a possibility to resolve this issue? Thank you for any advice.
zeusfaber
  • 247 Answers
SOURCE: Sound completely out in mono mode, distorted in stereo mode.
Assuming that you've tried plugging the headphones into a different device to check it's them, not the CD/MP3/whatever, that's at fault, then the most likely problem is a break in the screen of the headphones' cable. If you have a multimeter, you could confirm this by measuring resistances. If you look at the jack plug, you'll see it has three conductors to it called (reading from the end) tip, ring and sleeve. With the headphones set to stereo, you ought to see a few tens of ohms between sleeve and tip; the same between sleeve and ring; double that between tip and ring. My guess is that in your case, you'll only get a reading between tip and ring, with the two readings involving sleeve both showing open circuit. If you can see gross damage on the outside of the cable (where one of the children has ridden over it with a office chair again), you probably need to replace the whole cable. If there's no visible damage, the failure is usually just at the point where the cable goes into the jack plug (all the stresses when you move about are concentrated there). You can often prove this fault by wiggling the cable around while pushing it into the plug and seeing whether sound is intermittently restored. Solution here is to cut the last couple of inches off and fit a new jack plug. You will be able to buy lightweight screened stereo cable (if you need it) and a stereo jack plug of suitable size (the standard sizes are 3.5 mm and 1/4" - referring to the diameter of the sleeve) fairly cheaply from a hobby electronics shop (is Tandy/Radio Shack still on the go out there?) If you have to change the cable, use the way the old one is fitted as your guide to fitting the new one to the headphones. Either way, you'll need to fit the new jack plug. Don't forget to put the cover over the cable before you start to wire up the main terminals. Jack plugs usually come with solder tags. Of the two in the middle, the one on top is connected to tip, and the one underneath is connected to ring. The tag for sleeve is combined with a cable clamp usually just as a single hole halfway up the clamp. Strip the cable so that the insulated wires will reach the tip and ring solder tags, the bare screen(s) will reach the solder hole on the clamp, and the crimp grip at the top of the clamp will work on the sleeve of the cable. Double-check that the cover for the plug is already on the wire. Solder the red wire to the tag for ring (the lower of the two in the middle) Solder the other coloured wire (usually blue) to the tag for tip (the upper one in the middle) Solder the bare wire screen (both of them if there are two) to the cable clamp at the point where the hole is drilled through it. After all your soldering has cooled, use a pair of pliers to bend the arms at the top of the canble clamp around the sleeve of the cable and crimp to secure it all. Screw the cover onto the top of the plug. That should do it. A.
Posted on Jul 29, 2007
  • 3 Answers
SOURCE: Philips Headphones SBCHL155
my head phones got tangled and i have the ones that can stretch the ons that cost $9.99 right. And theres this meatel part and i want to know how to put it back in. OH an what do u do to the head phones
Posted on Jan 02, 2008
  • 1138 Answers
SOURCE: sound will not play through headphones
Try here:http://www.computing.net/answers/windows- xp/headphones-amp-speakers-switching/55486.html Also:http://www.vistaheads.com/forums/microsoft-public-windows-vista-music-pictures-video/133605-sound-doesnt-switch-automatically-headphones-when-plugged.html Also:http://www.vistax64.com/sound-audio/198039-sound-doesnt-switch-speakers-headphones.html scroll down the page for the discussion.
Posted on Oct 21, 2009
allan_C_V99
  • 105 Answers
SOURCE: audio jack has malfunctioned in headphones
You might cause more damage to it, please find a local electronic repair shop near you and let then check it.
Posted on Jun 06, 2010
Grubhead
  • 5515 Answers
SOURCE: i just bought a new
See my tip on dealing with dodgy plugs/cables on headphones.
Posted on Oct 07, 2010
I have a pair of philips SHN-9500 noise canceling headphones and the left speaker is not working how do i fix this?
Unless you are really good and have the correct soldering gear, I\'d sudgest taking it to a repair centre. If you are going to have a go, you need a variable temp, needle point solder iron, a solder \'sucker\', a magnifying glass and a steady hand. The wires to each side are in s single unit. Here is a break down, from the centre, + then insulation,then the common which is rapped around that with another layer of insulation. Good luck!
May 17, 2014 | Philips SHN9500 Consumer Headphones
No Sound, Windows 7 laptop
Is the speaker plug it the right connector and inserted all the way? Are you using the headphones jack? Do headphones work in the jack? Is the sounds section in Control Panel function properly ? TroubleShooting? What? Drivers? Power on speakers? Check connections/wiring?
Nov 24, 2012 | Computers & Internet
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Hello.
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
I have a Latitude D600 laptop. When I plug in my headphones, the sound still plays through the built in speakers. When I twist the plug in the jack I can sometimes get sound in the headphones but it still...
I dont think the JACK is the problem, I suspect a bad headphone wire (intermittent) or an incorrect driver, headphone jacks in laptops are software controlled, (no mechanical switch inside) if you hear sound in both the headphones and the speakes it is a driver issue, try updating the driver, if the headphone wire is erratic it can fool the software that controlls the input and do crazy things also...
May 26, 2011 | Dell Latitude D600 Notebook
Colors of the wires for CX 400 headphones
yellow and red-green are most likely grounds. red is normally the right channel and green is normally the left channel. quick question though, why on earth would you cut the plug off of a pair of 75-90$ headphones?
Apr 15, 2010 | Sennheiser CX 400 Headphones
Audio cuts in and out in media center or while watching a dvd
Check to ensure that the speaker connection plug is fully inserted into the speaker jack on the computer. Do the same for the power connection at the speaker, too. Slightly wiggle or twist the connections and wires - one at a time to isolate the source of the failure (can be the power plug or wire, audio plug or wire, or even the jack on the PC . If related to the speaker plug, try using the speakers in another speaker jack on the PC - or other device (mp3 player, etc.) if the problem is still present on both locations, it is related to the speakers / power. Try using a pair of headphones plugged directly into the speaker jack on the PC to see if the problem is present still. If the problem is common to both speaker and headphones, the jack on the PC is likely the culprit, and a new sound card will probably have to be installed. Otherwise, replace / repair the speaker cable, plug or system.
The likely source of the problem is a stretched wire along the cord - or at the plug. A repair can be attempted if desired - or replace the speaker system if lacking tools or if unsure how to go about it.
Sep 28, 2009 | Gateway GT5016E (RBGT5016E) PC Desktop
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Jack replacement for mdr-v500 headphone
You don't need to look inside the plug... just open up the earcups and test the jack plug with a continuity tester.
But FYI, Red = ring, Green = tip.
Apr 04, 2008 | Sony MDR-V500 Professional Headphones
Philips SHN9500 Consumer Headphones Logo
122 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
