Question about Delta & Single Handle Shower Faucet
Adjusting the scauld guard on a shower mixer valve
How do you adjust a shower mixer valve water not hot enough
  • Anonymous Mar 17, 2014
    Bancroft shower valve temperature adjustment
  • 349 Answers
Uue a 1/8" allen wrench to remove handle to access the dial that set's the mixture of water.Remember or mark where it is and remove and reinsert counter clockwise about a 1/4 turn to start to you reach desired temperature setting. Be careful not to set it at a hot enough setting to burn you.
Once dial in place slide handle on and turn on to check water temperature.
Posted on Aug 01, 2010
Is it possible to adjust shower mixer temperature?
Now my best guess is that you kept heater too high for a long time which means that the pipe carrying hot and cold water got touched and water became hot So turn off the heater for while and let the pipes cool off then turn the heater on at a low setting ...
Aug 30, 2014 | Rubinet Home
How do I adjust my exacttemp shower valve?
Where it suddenly became not hot enough, it's probably not an adjustment. It sounds like the stem needs to be replaced
Feb 28, 2014 | Moen Home
No hoy water coming out on Moen shower faucet?
If you have hot water elswhere in the bathroom but not the shower head then the diverter valve in the handle for the tub is most likely bad and needs replaced. The diverter is also called an anti scauld valve, it mixes the hot and cold water to prevent scaulding you in the shower
Oct 02, 2011 | Moen Home
I have an emco equitemp shower valve and have recently installed a tankless water heater. I need to adjust the valve so that the hot water temperature is higher. The water heater heats at 140 degrees but...
You should have the ability to reach 185 degrees. As long as the Heater is capable of reaching 185 you should be able to process that extreme without a problem. The only reason you cannot get above 140 is because the valve is limited or defective. You may have to replace the shower valve to accommodate 185.
Feb 05, 2018 | Home
Low hot water tempreture
Your question doesn't give me much to go on, but, If you have installed a new mixer valve in your shower and you can't get water that is hot enough to come out, there is a reason.
All newer mixer valves that I'm aware of have what's called a non-scholding setting that is done at the factory. ( I believe some manufacturers explain how to adjust this, in the paperwork you got with the part, if there are no children living in the home.) This is a child saftey feature, and if you want hoter water, you may have to raise the temperature setting in your water heater.
I hope this helps you.
Jan 29, 2011 | Home
Temperature too hot on bristan art deco mixer shower even on lowest temperature setting.
if the water is that hot then lower [adjust] the temp of your hot water heater -if need to adjust the shower you can adjust the mixing by removing the handle and on the valve stem are the adjusting clips the red [hot] and blue [cold]plastic clips can move them around to adjust the mixing of hot and cold water
Jul 23, 2010 | Home
Thank you for reading this. I am a non-technical home owner. I have a Groge Atrio shower with a thermostat mixer in the wall. The water does not get hot enough so I need to adjust it upward. Do I remove...
You didn't mention what model you have. Here is a link to their web site. You can download a manual, that has detailed instructions on how to adjust. You should have a thermometer to measure water temperature to adjust properly. Go to : http://www.groheamerica.com You can identify your model, and then download the technical product information. Also check the temperature of other faucets in the house to be sure they are getting hot enough, and not a water heater temp problem.
Jun 30, 2010 | Home
At shower time in the morning the hot water varies from cold on one day medium on another and hot on any given day. What's wrong?
Do you share your hot water with anyone? Is anyone washing dishes, laundry, etc before you shower? How old is your hot water heater? If it has filled with sediment, your hot water is limited. Try turning up the heat control valve on the hot water heater, only go up one notch today, then if not enough another the next day. Be cautious of scaulding hot water after turning it up.
Apr 10, 2009 | Water Heaters
Not enough hot water
Some higher end models do have an adjustment that is behind the face plate. You would have to remove the handle and the screws in the faceplate to expose them. If you have adjustments they will be located on the brass valve body facing you. You will need a flashlight and a flathead screwdriver to make the adjustment. If your model is not equipped with adjustments you could have a faulty valve stem. The stem is comprised of a rubber band like gasket that separates port holes into which the waters flow. There could be some piece of trash blocking the port not allowing adequate water from the hot side into the valve.Some valves stems are also able to be installed upside down causing the same issue as the ports do not rotate fully to allow adequate supply. However you say that you have adequate pressure on the hot side but not warm enough. There is another possibility also based on the way the shower supply was plumbed but there is no need to go into this unless this does not resolve your issue. I hope this is of assistance and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Oct 20, 2008 | Home
Delta & Single Handle Shower Faucet  Logo
1,876 people viewed this question
Top Delta Home Experts
Mike
john h
Colin Stickland
Colin Stickland
Are you a Delta Home Expert? Answer questions, earn points and help others
