Question about Fujitsu Siemens AMILO Pro V2000 Notebook
I asked 5 experts if plugging a 20V 3.42A charger into a 19V 3.42A laptop would blow it up. 4 said no, 1 said yes. 1 was right. I removed the battery before hand and I put it back in after, still nothing... what component is most likely to have blown and how do I work out what to fix?
  • usedonlytosi Jul 31, 2010
    I thought putting 20V in it was stupid to but I am a software guy they're always playing with hardware and said it would be fine. Thanks for the extra info about lights, etc.
  • Fujitsu Siemens Master
  • 4,924 Answers
If there are lights on when the ac adapter is plugged in ..than the Cpu is most likely that didnt supported the the extra voltage ..but if there is nothing going on ..I mean no lights ..no nothing ...than if you are lucky will be just some final fuses ..but in the second case I am afraid that you will have to replace the motherboard ....You may try ..if you have lights ..if replacing the Ram memory bring it back ..cause the ram memory is also very sensitive on extra voltage ..I mean 0.2 is much ...but 1 V is already much too much ..This is not a radio that will just heat a little when you have an extra volt ...there are very sensitive components on voltage ..like the Ram memory and the CPU ..So ..in short if the mother board receives power and the stand by lights are on ...it means that the motherboard survived..but if nothing is lit .than is gone ..you may recover the rest though...if it blown suddenly .than the ram memory might be still intact or some other removable components like the cards for devices.....
I suggest to see if the battery charged in a similar model will bring it back ...in this case it may be just the charger that not fitting ....
Posted on Jul 31, 2010
  • Catalin Turcu
    Catalin Turcu Jul 31, 2010
    Dont worry ...until I got to know stuff I made stupid things ...and it was the fastest way to learn something ....have a nice day ..and remember what I said ..if there are no lights ..it is the board or the fuses...I mean it gets no power and it is probably the best thing ..if it has light and do not power up ..than may be the cpu or the ram ...
How can I charge a 20 volt lithium battery without its charger? Can I use a laptop charger for it?
Angel why not purchase a 20 volt lithium battery charger . It is better than risking blowing up a laptop charger or the battery.
Google search
charging 20v lithium batteries
and heaps of chargers come up that you could purchase.
Sep 28, 2015 | Drills
Laptop is not turning on after I change my laptop charger. I remove the battery and plug in my new charger it works fine but suddenly shut off. I put the battery back and plug the charger in. No good.
You need to check the charger, I do not think it is any good as the charging power is in the charger unit not the computer. It sounds as if the battery in the computer is totally dead and that is why it shut down. Hope this helps.
Sep 15, 2015 | Computers & Internet
Need a replacement power supply for a Evernote scanner
Sorry Gregory, gave you the wrong number.
You could try something like this. Various voltages and currents with different adapter plugs. This is on Ebay UK but I would think there are others, don't know where you are.
Ebay item number: 201154296095
Specs:
1.Rated Input Voltage: AC 110V or AC240V
2.Vibration Input Voltage Range: AC95V-265V
3.Input Rated Current: 0.4-0.6AMP
4.Input Power: 90W
5.Efficiency: >88%(TYP)
6.Out Power: 90W
7.Output voltage: 15V/16V/18V/19V/20V/22V/24V(0/+0.5V NOLOAD): DC15V-24V
8.Output voltage: 15V/16V/18V/19V/20V/22V/24V(-0.4/0.5V@rating load): DC15V-24V
9.Output current: 15-20V/4.5A@22V-24V/4.0A: 4.5AMP(max)
10.Overload protection: YES
11.Short Circuit Protection: YES
Dec 17, 2014 | Office Equipment & Supplies
My computer says plugged in, not charging
Dead battery. Test battery, try another cord/charger to verify.
Dec 01, 2012 | Toshiba Satellite A135-S4527 Notebook
Power is plugged in , battery is plugged in not charging with 0% available
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Replacement Acer Aspire 6930 AC Adapter 90Watt 19V 4.74A
Nov 12, 2012 | Acer Aspire 6930 6930g 6930z 6930zg Laptop...
The laptop will not turn on or boot, the power led will light but nothing further happens
Hello David,
Please remove the battery of laptop.
Press the power button for 15 minutes and it will discharge the capacitors of the laptop.
Repeat the step 4 to 5 times and then insert the battery and connect the charger.
Laptop will be boot up.
Apr 16, 2011 | Compaq Presario CQ70-116EM Laptop...
My laptop will not charge when the charger is plugged in. I tried removing the battery and turning it on while it was plugged in. Is my computer messed up or is it just the charger. Also my warranty has...
Your laptop still not charge even with the battery removed?
I guess you need a new adapter. Or you can test with a known working adapter first.
Specification of HP pavilion DV7 charger:
Output: DC19V 4.74A
DC Connecter (Barrel) size:
Internal Diameter: 5.0mm
External Diameter: 7.4mm
With central smart-pin inside
Reference: http://www.chargerbuy.com/replacement-hp-pavilion-dv7-ac-adapter-19v-4-74a.html
Feb 16, 2011 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Charger light flashes when plugged into laptop , stays on solid when unplugged,had charger checked 19v ok ,had socket checked 19v ok ,then checked to first board 19v ok ?? has a board gone down ??? annoyin...
your battery pack is causing your problem rule #1 never!! leave the charger in!! everytime you start up!! run off the batteries till the power low light come's on then apply the charger constant charging causes early failure of all/ any nican battery pack
Jan 13, 2010 | Acer Aspire 5920-6335 Laptop
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
43 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
