Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Husqvarna lawn tractor that will not move forwards or backwards
The motor still runs but the machine will not go forward of backwards it just stopped while in the midst of cutting the grass
2 Suggested Answers
stmc97
  • 41 Answers
SOURCE: Was mowing when it just stopped going forward. It
Under the mower below the seat of the rider, at the rear of the tractor, look up and you will find the transmission there. There is a belt that runs on the pulley under there, and this belt can slip off when it gets worn or stretched. Sort of a tough spot to get to but, that is most probably cause.
Let me know,
Chip
Posted on Apr 11, 2010
My RZ4623 will not move.
If the unit stopped moving at once. I suggest checking the belt. It is very unlikely both Hydro-Gear units would fail at the same time. check under the mower, and check on top of the transmissions, you should see the drive belt running between both transmissions and the engine.
Feb 15, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
My Weedeater riding lawn mower will not move when it is in drive or reverse
Check your drive belt that it has not slipped off the drive cog under the motor. Also check the alignment of the motor with the handle on the right side (speed, reverse, and neutral lever).. This lever tilts the engine to engage the drive belt.. there is no transmission in this machine.. just how the belt engages by its angle when you push the lever forward and backward.. If the engine is running, it must be either the belt to drive the unit or the angle has been messed up somehow..
Apr 21, 2013 | Weed Eater Weedeater 26" Riding Mower
Gt 245 lawn tractor won't go forward or backward
Check the drive belts first. and make sure the hydro release lever is in the correct position. If it is not- you can push the lawn tractor and have the rear wheels turn. It sometimes doubles as a "Forward" "Neutral" "Reverse" lever on other brands of lawn tractor.
The belts should be in their guides and pulley grooves- check to make sure it does not have a hidden break by having the engine off, and pulling on the belt.
Lastly, check to make sure the hydro itself is not out of oil or low on oil. It uses low viscosity "HyGard" oil. Capacity if you drain the old oil out and refill is 4.6 quarts. Look for a leak if the level is low.
If it still does not move, make sure the levers are set so you are in forward motion positions, and push- if the rear wheels move there is a problem in the hydro unit.
Apr 07, 2012 | Garden
Describe your Troubleshooting Husqvarna YTH2454 Problem The tractor will not move forward or backward. Any idea what the problem might be?
Check to see if your drive belt has slipped off the pulley assembly, or if you have broken a pulley or the belt itself broke.
May 08, 2011 | Husqvarna Lawn Tractor  25 HP 54in Deck...
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
Was mowing when it just stopped going forward. It won't go forward or backward. Husqvarna Lawn tractor 48"
Let me know,
Chip
Apr 11, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Jun 06, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
173 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
