Question about Refrigerators
My Refridgerator's door is tight.It can not open easily.
  • Refrigerators Master
  • 8,404 Answers
Wax the metal part of the door where the rubber meets it. Put some silicone spray on the rubber gasket ... dont go crazy with it. Spray on a rag and wipe it on with the rag.
Posted on Jul 31, 2010
  • A Miller Aug 07, 2010
    Sorry this response was not sexy enough for you ... I hope you ttied it before you passed judgement on my resonse.
How to remove ice bin on a Whirlpool Refridgerator in a tight spot?
Redesign the kitchen, sue the builder, put the fridge on wheels, reverse the door, buy a new fridge. These are all the choices you have..
Jun 18, 2018 | Whirlpool Refrigerators
Leveling a refridgerator
if not level you need to tip it back and unscrew or screw in the feet on it. use a 2ft level on top to be sure which way to go. if just the door, open door and there is a bracket in between the freezer and fridge and it should be adjustable a little bit. unscrew til lose adjust door to right spot and hold while tightening bolts. that should work. if the fridge door is on top and freezer is on bottom then adjust bracket screws on top of fridge.
Jun 24, 2012 | Stainless Cal Flame Refridgerator Steel...
Ge monogram has water droplets in refrigerator side just along top right corner edge where top door gasket closes against refridgerator. Refridgerator seems to be holding temperature. Condenser is above...
The gasket may have worn some causing an air leak,.and you
are seeing water condensation from the leak. Try adjusting
the door hinge. Close the door on a piece of paper and see if
you can pull the paper out. Adjust the hinge until the paper is
tight.You may have to adjust both hinges to align it properly.
Feb 08, 2018 | GE Monogram Side by Side Refrigerator
The refridgerator door is not sealing properly and the magnetic seal between the refrig door and the freexer door is hot.
Heat the seals with a hair dryer and then pull it tight - strap it tightly shut - you can also use some super glue to keep it in place while it dries.
Gary @ Fix Ya
Sep 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Adjustment of a Chamberlain WD822KL
The opener is having a hard time operating the door. It sounds like the door is out of balance. The door should stay all the way up at half down and all the way down. You should be able to raise and lower the door by hand EASILY. The opener is only meant to lift10-15 lbs. Thanks BB
Apr 08, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Kenmore refrigerator with bottom freezer. freezer works,refrig does not. Can you help me find the problem .Also, bar between the upper doors gets real hot.
I had this problem. The Evaporator fan in the freezer was working but no air would be circulated from the freezer into the refridgerator. To test this you open the door of the freezer, and depress the door button(s) of the upper refridgerator doors so that the light extinqueshes in the refridgerator. This will engage the evaporator fan in the freezer. You can check to see if air is venting from the freezer into the refridgerator by feeling the holes at the top most part of the multi-air flow channel in the refridgerator. If air is comming out when the freezer door is open, close the freezer door and feel if air has stopped. If you have kept the upper door buttons pushed in on the refridgerator and now have the freezer door closed, you should still hear the fan running, but may have not air flow with the freezer door closed. The cause of this is the air return channel from the refridgerator to the freezer is either frozen or clogged. My return-air channel was not frozen but clogged by a residue from something that spilled inside of the bottom of the refridgerator. The return-air channel has two vents in the rear-bottom of the refridgerator that exit into the freezer behind the evaporator (cooling coils). You can't see it even if the back interior panel is removed from the freezer compartment.
The bottom line here is that if air is prevented from moving from the refridgerator, back down to the freezer, then your refridgerator will not cool, but your freezer will work just fine. You will not need to replace the fan, unless the fan is not functioning. You may need to check the dampener, to ensure that your multi-air flow channel is open - (allowing air to come into the refridgerator). The multi-air flow channel is easy to remove once all of the shelves are removed from your refridgerator. Only 2 screws holding it in (securing the center rack top and bottom). The top screw is located behind a small plastic cover that can be removed.
That's what worked for me.
Jan 12, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Refridgerator door
a lot of the sub-zero doors are good and heavy duty, but the plastic shim under the hinge wears and can drag when you go to close door, usually a simply repair to find a washer for the door hinge.
May 16, 2008 | Sub-Zero 700TCLH Bottom Freezer...
Dryer stays on for 3 secs and turns off; sometimes won't turn on at all.
sometimes the movement will cause the door to open, thus shutting off the dryer. Does the door shut tight when you close it? there is a little clip that if broken, the door will pop open easily. After it shuts off is it easy to start again?
Mar 12, 2008 | Dryers
Frigirator
model more helpful then serial, can look up the daigram
Mar 07, 2008 | Refrigerators
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
