Question about Janome MyExcel 3123
The fabric keeps getting pulled down into the machine when trying to stitch. I've tried to change the needle, clean the lint and rethread the machine.
  • Janome Master
  • 7,365 Answers
Try these suggestions
1.make sure the needle is in the needle holder correctly
2.check to see if the needle is in backwards
3.make sure the thread is not slipping off the take-up lever
4.check to make sure the bobbin is not warped
5.check for lint in & around the bobbin case
6.check for loose thread in or around the bobbin case
Posted on Aug 01, 2010
Why does the fabric get stuck in the feed dog plate?
try changing the needle it could be blunt
also make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin are for lint
Mar 24, 2016 | Brother Se425 Computerized Embroidery &...
Why first four to five stitches will not interlock
try changing needle
try rethreading machine
also could need a adjustment or have a timing problem
Feb 27, 2016 | Sewing Machines
Singer sewing machine pulls fabric and snarls
try changing the needle--make sure the needle is the right one for the
fabric being sewed.
rethread the machine using every thread guide
try turning the bobbin the opposite direction
clean under the needle plate and in the bobbin area for lint
you may also have to use a washable stabilizer with the fabric
Apr 15, 2013 | Singer Sewing Machines
Needle thread jams with first stitch
try rethreading the machine
change the needle--one that is correct for the fabric
turn the bobbin the opposite direction
Dec 16, 2012 | Janome Sewing Machines
Thread knotting up on underside of fabric
Try rethreading with a new needle. Make sure presser foot in up position when you rethread. Thread needle with flat side in back and more rounded side facing you. Make sure you pull the thread taut as you insert the thread into all of the tension disks.
Clean out the shuttle and the feed dogs with gentle handling of your small sewing machine lint brush. Sometimes broken thread, lint, and threads from your fabric get caught in these areas and are not visibile until you get the brush bristles in there.
Make sure your top tension is on a medium number and that your pattern setting matches the stitch you wish to perform.Also make sure your needle size matches the fabric weight. Another fix if it isn't anything I have mentioned so far, there is a foot pressure regulator on the left-hand side of your machine which controls the pressure of your presser foot. Turn it (some push up and down) just a tad in either direction and recheck with a scrap of fabric to see the results.
Hope this helps!
Jimmy
Apr 01, 2012 | Bernina Sewing Machines
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
Top thread is ok but bobbin thread misses stitches at will, zigzag stitches don't sew but a straight line. changed needle, sanded burrs off pressure plate, cleared bobbin chase of lint. what have I...
check tension usually 3 or 4 is good
clean under needle plate where feed dogs are for lint
is the flat side of the needle toward the back of the machine
rethread machine
is needle the right one for the fabric & thread
it might also need to be serviced
Nov 24, 2010 | Kenmore Sewing Machines
Every few stitches thread gathers and jams on bobbin side of fabric. Why? [the machine is a Singer model 6180]
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin
Check tension 3 or 4 is usually good
Nov 23, 2010 | Sewing Machines
Thread jams
Hi! I've had this happen to me many times and it is so very frustrating! First, take the bobbin out and also the bobbin assembly and clean the entire area of all lint, fuzz, little bits of thread....get it as clean as you can. Take out the upper thread too. Clean and oil. Change the needle. Make sure you're using the appropriate size and type of needle and thread for the fabric. Take off the needle plate and look for any nicks or scratches. If you've got them, you can get emery cloth from a good hardware store (often in the plumbing department) and polish them out (or mostly out).
Rethread the machine, carefully following the instruction manual. Use your basic, normal settings. Using a scrap of the fabric you're trying to gather, sew a seam and see if everything works ok. You may need to hold the top and bobbin thread firmly behind the needle as you sew the first few stitches (I find this little trick helps a lot to prevent birdsnests).
To gather, sew three parallel lines of long, basting stitches (you really don't need a special foot or special settings other than to make the stitch a long one). Don't backstitch, reverse, or lockstitch either end, and leave the thread long when you cut it. Pull the three bobbin threads and the fabric with gather nicely along them.
Something to keep in mind--if you're trying to gather very sheer fabric on a zigzag machine, you may need to replace the throat plate with the zigzag hole for a throat plate with a single, small hole for a straight stitch. I've run into this situation before, and ended up using one of my antique straight-stitch only machines to do the gathering.
If you don't have a throat plate with the single hole, you might try some light weight interfacing to give some density to the sheet fabric.
Hope this helps!
Jan 31, 2010 | Euro-Pro Sewing Machines
Sewing Machines Logo
57 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
