Question about Nokia 9500 Communicator
I drop my nphone n broken.the lcd cannot display.and i want change body housing.?
  • 677 Answers
Hi,To be able to fix the LCD display screen and change the housing for your phone, You will need to go to any Nokia store for assistance,they will help you. the phone is very complicated.will need an expert to fix the parts. that's why i recommended the Nokia store for you.
Take care.
Posted on Jul 31, 2010
LCD display shows broken numbers, why??
You have damaged it by dropping it displays of this type are sensitive to being dropped
repair or replace whole unit
Jan 20, 2017 | Health & Beauty
PANASONIC lcd TV DISPLAY SCREEN BROKEN
if you call the toll free number on manual they will be at your house
Nov 14, 2014 | Panasoni Viera TC-L32E5 32" 1080p LED-LCD...
My nokia 3200 lcd showing blank can any body send me the lcd jack print for jumpering.
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Jun 10, 2009 | Nokia 3200
I dropped my sony alph 100 digital camera and display wont work
Do you see Menu items or Menu Display in LCD?
If yes then LCD connector might be displaced and requires re-installation and if no, then LCD seems broken.
May 31, 2009 | Kodak EasyShare One Digital Camera
I have dropped n95-1 once, after a week, display gone, but still mobile is working , visited two different shops, as one is saying need to change display and another guy is saying due to strip issue, am...
the phone works fine except the LCD..
visualize it ,check the LCD if it is broken..try to swap the LCD to the other the same unit..if it work's ..
and if the problem still exist:
you state that it was dropped ..
i think they other parts have been dislocate..
i suggest that you need to disassembe unit and assemble it again to a repair personnel..
pls rate it , if it solve the problem..
good luck.
May 20, 2009 | Nokia N95 Cellular Phone
80gb Classic backlight on, no menu displayed
you LCD is Broken...Look for an iPod Repair in your area and have the LCD replaced.
it's a classic symptom of a damaged LCD..I see it all the time.
Apr 12, 2009 | Apple iPod classic MP3 Player
Help! Cracked LCD display on Canon Rebel xti
Had the same problem myself, I purchased a new lcd from ebay (user name: ProphotoSD). He has tons of factory LCD's, cost around 90$. Please note that if you cracked the clear cover above the lcd that is a separate piece however it wont effect the lcd working (this piece is also replaceable). Then I found a simple tutorial for disassembling the camera body on google. Took me like 25 min, very simple job, just need a very small phillips head screw driver. Hope this helps!
Mar 21, 2009 | Canon EOS Digital Rebel XTI Digital Camera
Nokia 7373, Powers up but the LCD displays 2 vertical lines.
Your broken display might shortcut your phone,
making it unaccessible with the broken display in place.
Jan 19, 2009 | Nokia 7373 Cellular Phone
Nokia 6131, front/internal screen light up but don't display
Dec 17, 2008 | Nokia 6131 Cellular Phone
Broken outer Mini Display
Well to replace the lcd first you need a new one and the proper screwdrivers to open it,usually when you get a new lcd it will be one piece with inside display and outer display,i have not opened the phone in question before but they all seem to have the same method,there should be 4 screws on the inside of the housing around the lcd,usually a t6 screw driver will work once you get these screws out you will need somthing thin like a credit card to seperate the housing.Ok now you should have the outer housing off and looking at your lcd.there is going to be one or two flex cables attached to it these disconnect easy once disconnected all you have to do is using tweezers or somthing get the lcd out the big display part will have a plastic covering that is stuck to the front if you remove this you could just push your lcd out from the bottom if you dont you will just have to play around till you get it out.then you just pop your new one in connect the flex cable(s) and put your housing back on
Sep 23, 2008 | Nokia 6103 Cellular Phone
Nokia 9500 Communicator Logo
48 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
