Question about Microsoft Xbox 360 Console
My xbox 360 power supply box thing has an orange light on it but when i turn it on it starts for split second then turns off and the light turns red and it wont turn on
  • 91 Answers
Sounds like your power supply is bad. You will need to get a replacement.
Posted on Jul 31, 2010
Testimonial: "thankyou ill try this thursday, i was installing led lights and click sound then problem started"
  • totrodder Aug 20, 2010
    cheers mate i will try my mates power cord and i know how you feel mate i just resprayed and modified my xbox and when i put it back together and tested it i had the same problem as you
  • resindrip Sep 09, 2010
    As many of you know the power supply gets extremely hottt! Now I found that if you place it on a box or off the groung it helps displace most of the heat. That seemed to help me. But it could be your power box is just shot. But it wouldn't hurt to try this solution in the future to avoid it overheating.
ionfreek458
  • 52 Answers
SOURCE: xbox 360 red ring
first of all, 3 red lights USUALLY means that you have an internal hardware error. microsoft has a garuntee that if your xbox DOES get the 3 red rings, you can send it in to them and get you xbox fixed or a totally brand new one for FREE. but before you do that, you should check ALL of the cords to make sure that they are plugged in right. there is a reported 33% of the Xbox 360 that were produced have a serious problem- once the motherboard reaches a certain temperature is bends, causing some solder balls to lose contact with the GPU and motherboard.
If there is anything that you want to be sure of before you take apart your XBOX 360 is assurance that what ever your going to do to it, is going to work!
just go to this website:
http://top3redlightfixes.com/XBOX3RedLights/xbox_360_3_red_lights.php?gclid=CIeBnJi1pJYCFQgRFQod0lsd7A
my friend used this site and got his xbox fixed in no time and he learned some suff too.
Posted on Oct 21, 2008
SOURCE: power cable light is orange and xbox 360 wont turn on
Hmm sounds similar to me. I saw a post stating that usb port where the controllers are connected were shorting out to ground. So I took my 360 apart and sure enough the pins were shorted to ground. A good thing to check is the orange light on the power brick. If before you plug it into the back of the 360 its a steady orange light and then you plug it into the console it blinks (pay attention) its a good possibitility that it is shorting out somewhere in the console. If you have a mulitmeter you can check the back of the power plug input to ground or the controller usb to ground. Even though I found that this was my problem with my xbox unfortunately for me my board was also fried. From now on Im going to collect xbox's that are broken and use them to fix my new xbox when it breaks(im sure it will) because microsoft enjoys putting out an infererior piece of ****. I'll be dam*** if ill pay anyone a penny and wait half a year to get a repaired (but still broken) xbox back, when I know Ill be able to fix my own. Maybe Ill open up my own 360 repair shop just to show microsoft how. customer service should be handled. Anyway hope that helps and you have better luck then I did.
Posted on Mar 28, 2009
v4ndre
  • 148 Answers
SOURCE: My xbox 360 power supply has an orange light and
could be a simple broken power button or maybe a cracked solder point in the base of your console female power plug...
or even a internal eletrical problem...
Check and test with another power supply...
Good Luck...
Posted on Sep 11, 2009
localwonder
  • 6784 Answers
SOURCE: xbox 360 not powering up at all. power supply
An orange light is illuminated on the power supply for one of the following reasons:
* The console is turned off.
* The power supply is disconnected from the console.
* The power supply cord is not fully inserted into the power socket of the console.
* The power supply is faulty.
* The console is faulty. (The console might be faulty if it does not turn on when the power supply light is orange.)
The power supply has several built-in safeguards to help prevent damage to either your Xbox 360 console or the power supply itself. The power supply will automatically turn off if either the current flow, the voltage, or the temperature is too high. When the power supply turns off for any of these reasons, the light on the power supply will turn from green (normal) to orange or to red, or the light will turn off. When the power supply light is green, the power supply is working correctly. What you are experiencing is an over heating issue, that may have damaged the supply.
With that being said, i would try to reset the supply by disconnecting the unit from the console, and unplugging the power supply unit from the wall socket for 5 minutes. Once the 5 minutes have passed, reconnect the unit to the console, and plug the power supply into the wall socket. If the console dose not power up, and the supply unit is still showing an orange illuminated operating light, this will confirm that the power supply unit will need to be replaced. Contact Microsoft for the correct replacement parts needed(power supply unit)
TIPS FOR PREVENTING OVERHEATING ISSUES
* Do not block any ventilation openings in the power supply.
* Do not put the power supply on a bed, on a sofa, or on any other soft surface that might block ventilation openings.
* Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
* Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register.
* Do not use an unlicensed accessory, such as a replacement power supply that was not manufactured by Microsoft, or any accessory that plugs in between the Xbox 360 console and the power supply.
* Plug the power supply directly into a working wall outlet. You may have problems with the power supply if you use an extension cord or a power strip if the extension cord or the power strip is faulty or cannot supply the required power to the console.
* If you are not sure about the reliability of an AC power outlet, power circuit, or power cabling, do not use it. Contact an electrician.
Posted on Oct 26, 2009
SOURCE: MY Power Supply light is blinking orange and xbox
I hate it when people put "Red ring of Death" for a ORANGE flashing light on the power bar and actually a red ring on the front of the Xbox (which then would mean the red ring of death)!
I just fixed this problem for a friend. They had a contoller charging lead plugged in to the front which had a bad connection in it. Thats all it was so I just unplugged the charging lead and it worked.
So Unplug everything except the power and see if it works 1st, if it does then plug things back in one by one and see when it starts to flash and thats your problem lead there.
Posted on Nov 10, 2009
My xbox was working and it cut off 5mins into me starting, the power supply light turned red. so i unplug evrythng plug it back up, the light is on standby (,yay) try to turn it on and the light turns...
I wouldn't recommend messing with it. The power supply is defective, and messing with a power supply is very dangerous. get a new power supply, just make sure that it is compatible with your xbox(there are 3 different versions of xbox power supplies out there)
Mar 10, 2011 | Microsoft Xbox 360 Console
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
Xbox won't power up, orange light is on the power brick
Are you using a plug and play kit? if so disconnect it, mine does that sometimes, if thats not the case comment me,I would write them all down but I am getting a bit fed up with writing lots of solutions to problems and getting no response from the person I give the time to help.
Feb 13, 2010 | Microsoft Xbox 360 Console
Xbox 360 is turning on for less than a second
Got kind of bad news , It is the power supply ,but it's the power supply
in side the box itself. It's more than likely a shorted regulator specifically
one of the 12 volt liner reg chips , I had to swap a few out to resolve
this a few times.
Rob
Jan 21, 2010 | Microsoft Xbox 360 Console
Xbox 360 won't turn on and the kids are upset.
Press the power button on the front of the Xbox to turn it on.
As you're doing this look at the power supply to see if the amber light turns green.
If the light does not turn green, you'll need to get a new power supply.
I you think this information is helpful to you, please take a few minutes to rate this reply.
Aug 29, 2009 | Microsoft Xbox 360 Console
Well when I turn on my xbox 360 the third part flashes red.
hello.
CAUSE The three flashing red lights may indicate that your Xbox 360 console has experienced a hardware failure. Please read the letter that discusses warranty changes for three flashing red light hardware failures.
MORE INFORMATION
If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue:
1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles:
906101 Xbox 360: The power supply light is red 906102 Xbox 360: The power supply light is orange 906103 Xbox 360: The power supply light is not illuminated
2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again. If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support, and then click Console Repair in the upper-right section of the Web page.
Note: The online console repair service is currently not available in all countries or regions.
If you would rather contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact for information about how to do this.
APPLIES TO
* Microsoft XBox 360 Video Game System
* Microsoft Xbox 360 Hard Drive (20 GB)
* Microsoft Xbox
Apr 27, 2009 | Microsoft Xbox 360 Console
X-box 360 wont turn on
Is your power box light orange or green. It should be orange if turned off and go green when turned on if it is red your power supply box is no good you can unplug it leave off for 10 minutes or so then try again if light doesn't go orange you won't be able to turn it on. I had the same problem and it was power supply box with red light got new one works great.
Jul 17, 2008 | Microsoft Xbox 360 Console
X box 360
Hey tjames2ya,
If your XBox 360 is not turning on, you may wish to verify that the power adaptor is functioning correctly. The power adaptor should have a light somewhere on its casing that shows up green, red or orange when plugged in. Each of these colors is an indication of a different problem:
* Green indicates that power is being correctly supplied to the XBox 360. If the XBox 360 still does not turn on, you will need to contact Microsoft for repairs and support.
* Orange indicates that at least one connection is loose. Making sure that all of the cables attached to the XBox 360 are secure should resolve this type of problem, and allow your console to power on.
* Red indicates that the power adaptor has either overheated or needs to be replaced. If the light is out, this may also be an indicator that the power adaptor is defective, but it may just as easily be a sign that the outlet the XBox 360 was plugged into did not provide enough electricity to power the console.
Unfortunately, in order to reset the XBox 360 you will need power to be supplied to the console. If replacing the power adaptor or double-checking your connections does return power to the console, you may then reset it by performing a "power cycle" (turning the unit off, then back on roughly 10-15 seconds later).
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 16, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
322 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
