Question about Acer Aspire Predator G7710 PC Desktop
Just put in a new hard drive in the SATA port 3 and my computer sees the device but i cannot find it on my computer, the hard drive is a samsung HD103SJ ATA Device 1TB
  • chapmanjason Aug 02, 2010
    Thanks for getting back but have sorted the problem now, just needed to format the hard drive, thanks
  • 229 Answers
You need to go in the bios and turn it on so the motherboard tells your HDD controller that it is there. Another thing you may need to research is if your motherboards BIOS is able to read a 1TB Drive most need an update. IF you have no clue what I am talking about I can walk you thru it but then I will need to know what motherboard you have, also if it is a off the shelf pc or a custom rig
Posted on Aug 01, 2010
My computer malfunctioned and I took out the hard drive to try and retrieve my files using a USB cable. I am stuck
Your hard drive has no USB port, it has a (seral) SATA 3 GB/sec interface, currently and
by far the most popular used on laptops, and also desktop computers. The SATA (serial advanced technology interface) 3 GB/Sec is version 2.0 of the SATA standard.
So, you'll need another laptop or desktop with a spare SATA 2.0 port, or a spare SAS (Serial
Attached SCSI) port, since SATA drive may be attached to SAS backplanes, as well as SATA backplanes. For a laptop, you may need to use the eSATA connector/cable
(see http://en.wikipedia.org/wiki/ESATA#eSATA for eSATA technical specs and a photo).
May 13, 2011 | Seagate MOMENTUS 7200.4 320GB SATA SATA...
My samsung sata hard disk HM120JI is not working fine. Windows is not coming up. I have replaced the hard disk and now want to copy data from samsung sata disk to the new disk. Could you please tell me how...
You can buy a SATA dongle that plugs in to the hard drive and plugs into the USB port on you computer $20 or buy a external SATA case to put the hard drive in $40 at most computer retailers.
Feb 06, 2011 | Samsung SpinPoint M60 HM120JI 120 GB SATA...
I have a Samsung HM060HI hard drive from my laptop, The laptop is wrecked, I have removed the hard drive... Is there any way of getting my data (pictures and files) from the hard drive by a lead that joins...
You can always use an external Hard drive enclosure whose SATA interface communicates with your computer using your USB ports... 1. Purchase/borrow the enclosure 2. Insert your Hard drive 3. Plug into your USB port 4. let the drivers install and begin migrating your data
I hope this has been informative...
Nov 21, 2010 | Samsung HM060HI Hard Drive
SAMSUNG 40GB HARD DISK MOTOR IS NOT ROTATING AND SYSTEM SHUTDOWN IMMEDIATELY WHEN IT IS CONNECTED TO PC
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Nov 10, 2010 | Samsung 80GB INTERNAL 3.5- IN SATA HDD...
How to install 2 t hard drive in computer compaq
A 2Tb hard disk will be a SATA hard drive. If your PC Desktop does not have a SATA disk controller then your have a couple of options.
1. Insert a SATA controller card into the PCI expansion slot, mount the SATA hard drive inside the PC case and then connect the SATA hard drive to the controller (you will also need a 4 pin power to SATA adapter cable) and install the SATA controller driver.
2. The other option (and the easiest) is to purchase an external USB 2Tb hard drive. All you need to do is, plug it into the USB port of your computer and it will see it as an external storage device.
Oct 22, 2010 | Computers & Internet
I have a NexStar 3 external hard drive that is not being recognized by my computer. It used to work now it gives an unknown device message
remove the hard drive restart your computer the plug the hard drive back into your usb port this should come up with new hard ware found and install the driver If not try a different usb port or your sata drive
Mar 30, 2010 | Vantec NexStar-3 External 3.5inch...
My mother board has Sata Ports. and IDE Ports.. i replace my Pata drive with a Sata Drive..The bios will see it, but will not access it.. so i put the drive in my other computer and loaded up windows 7 on...
With the drive came an instruction manual.In it it gave you some bridge pins,you use the bridge pins to change your drives so the computer recognises one as "Master" and the other as "Slave".Without the pins the computer will see the first drive first and the second as storage and will not boot from it.You need the pins bridged according to the instructions provided.Even your drive installation disk gave you these instructions.If you still have problems try unplugging the second drive,then boot up.Windows will then boot from the new drive.
Jan 10, 2010 | Computers & Internet
I Can Not See My [D:] drive Icon ....sec. HD
Did you just open the hard drive and install it out of the box? If that is what you did, then the computer its self will see the hardware but vista or any other operating system for that matter wont read it without a partition hence no drive letter....download a partition program like easius partition manager or partition commander and create your partition and windows will be able to see the drive. Once windows see's the drive then you have to format it! Once its formatted then your up and running. I hope this helps, comment back and let me know...thanks
Sep 27, 2009 | Computers & Internet
HDD Installation
Hi gravni,
The bios (MUST see the drive). If the bios does not see the drive neither will windows!
The down below port (as you mentioned) is for IDE devices. IDE1 by name. Use your ATA IDE port for the slower IDE drives or cd-rom drives. (This board does not have a second IDE port).
If the WD drive is a SATA drive connect it to the SATA 2 port. See your manual. Go to page 1-4.
As show in this pic below.
2711d19.jpg Is the WD 500Gb drive SATA or IDE?
It's suggested when adding a new drive into a working system, the user should setup the drive by using the manufactures guide. Click on this link & download WD's pdf file:
http://www.wdc.com/en/library/sata/2079-001042.pdf
You mentioned the drive is hot. This only means it is running.
Include in this post the model number of your WD drive? So I can check the specs.
Mike
Oct 28, 2008 | MSI P965 Platinum Motherboard
Acer Aspire Predator G7710  PC Desktop Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
