Question about Vacuums
The tech drive petal on my Kirby G5 fell off. How do I fix it?
    President:
  • 1,673 Answers
I assume you mean the pedal on the back of the transmission, if so, if has come apart, there is a piece that is pressed onto the shaft. Best to replace the pedal assm., the old one may not stay together anymore, you will have to pull the transmission out to replace it.
Posted on Apr 24, 2008
Neutral and drive grayandgreenonrear of kirby vacumn came out need instructions manual to fix model g5
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
http://kirbywhq.powweb.com/manuals/G5/681827108464D2611112D4446409F328/G5%20Manual.pdf
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Kirby
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jul 18, 2011 | Kirby Vacuums
G5 kirby's drive feature isn't working
the gears or the drive is probably worn down or is broken.take it into kirby and they can fix it for you.
Jul 02, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby G5 rear wheels lock up completely when in "Drive"
When wheels lock when vacuum is OFF - it is normal. If it happens when Kirby is ON then there are a few things that may have gone wrong
Primary drive belt is broken or something is wrong with plastic gears. See how to check the primary drive belt HERE.
If it is fine and gears are spinning - then something must be wrong inside the transmission. Parts for tech drive are not available from manufacturer so you are on your own. It is not really complicated - 2 clutches that engage and disengage depending which direction you push the vacuum. But if something in there is broken - you have to get a new tranny. It is not like getting a transmission for a truck but it still will set you back by about 100 $.
Good Luck
Rocky
May 16, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby G5 - the Tech Drive does seem to have much power
you need either a new nutreal cam bracket assembly, that is what engages and disengages the tech drive.OR to adjust the handle pivot assy- diffucult . this is not for the faint of heart. it is possible to fix them as i used to repair kirbys, however, I remember how frustrating it was to figure out how to disassemble and reassemble them. it is very complicated to a novice. I would recomend having it repaired professionaly. it is possible for a professional to repair it in a very short period of time.
another thing to consider. look on the UNDERSIDE of your Kirby, between the two drive wheels. just in fronnt of the tech drive/nutreal switch. there should be a screw there, tighten that screw up. actually tighten all of them. on My generation 3 the center screw came loose and it would not go in to drive and it would make an aweful clatter. hope this was helpful
Jul 08, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Transmisson
I know the lever you're describing, but it's very hard to tell someone how to put it back on. There's nothing wrong with your transmission, by the way, this is a part that's meant to be moveable, and it just happened to slip off in your case. You may call us at 1-866-509-1952, and we can do our best to help you.
Jul 01, 2007 | Kirby G5 Bagged Upright Vacuum
Vacuums Logo
83 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
