Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
FLASH WILL NOT OPEN - ERROR CODE SHOWS, ASKS TO SWITCH CAMERA OFF THEN ON - BATTERY REMOVED AND PUT BACK CODE ERR 05
  • 94 Answers
Top cover giving err05
you can open manualy and clean throughly and front cover edge just push it out side make little space beetween top cover flash and front cover.
try out if work then good other wise you have open camera and clean top cover part which is poping up flash.
Posted on Aug 08, 2010
I have an err 05 with my Canon 7D
The err code 05 says the same, Flash could not pop up. The manual says, switch off the camera and switch on again.it could be this does not change anything. Just a little more chance, when you switch off the camera and remove the battery. And while it is out, just charge the battery. When you replace the battery and the error reoccurs best guess you have to visit the Canon service centre.
Make sure there is no mechanical obstruction, that keeps the flash from popping up.
Jan 05, 2014 | Canon EOS 7D Digital Camera
Err 05 on Canon 7D
The error code is used to tell you the flash could not be raised. Check if anything is blocking the free movement of the pop up flash. First reaction should be, switch the camera off and then on again. Better though, after you switched off the computer remove the battery and charge it first, Then again try everything as before.
The manual says is the error persists, wroth down the error number and contact your nearest Canon Service Centre.
Jan 05, 2014 | Canon Rebel XT / EOS 350D Digital Camera
Well, my flash doesn't always pop up. It has been working on and off and now will not shoot. It says "ERR 05" - keeps blinking that. Can you help?
I have the Canon Rebel t1i (500d) and I had the same problem (built in flash not working). I tried a number of remedies I found on forums etc but none worked. I then tried this with the camera pointing away from me as if taking a picture. In the external flash housing is a metal sprung plate which surrounds the five circular pins (one big, four small at the rear). If you get a small straight headed screwdriver and lift the front of this plate and at the same time pull it back towards you it will come out altogether. (In picture 2 I show this plate removed and sitting in front of the mount only so you can see it removed, it was brought out backwards so towards me from the camera).
I then removed the four small screws being careful not to drop them and took off the mount for the external flash and then tried the flash it opened straight away. I then cleaned all the area of the mount and the two plates and replaced them all ensuring I fitted them exactly as before. I then checked the camera again and presto working fine. I hope this helps everyone with the problem.
Dec 25, 2010 | Canon Rebel XT / EOS 350D Digital Camera
When taking pic an "err 05" (the built in flash was obstructed). On this camera eos Digital Rebel xti 400D. How do fix this?
The obstruction is often caused by the interior latch which refuses to move. If the flash cover ever opens, move the latch back and forward a few times which "sort of" re-engages it to its normal position.
Jul 03, 2010 | Cameras
Err 99 when use internal flash
There is a Canon Help line on the Canon web site which will help you. They are excellent
Jan 19, 2009 | Canon EOS 40D Digital Camera
Canon Camera Rebel XTi reads error 05 and the flash will not pop up
Err 05 means: Something obstructed the built-in flash's pop-up operation. Turn off the main switch and turn it on again.
Prepare to press the flash request button with your left hand. With your right hand, position your thumb and finger to gently pry up the flash head, perhaps using fingernails. Push the button and pry. With that help, it should pop up.
Dec 20, 2008 | Cameras
Err 05
In my case, I borrowed a camera and when I got it back, err 05 appears. I've located a bit of old orange juice which sticked one of the sensors - you can see the sensors when flash is popped out.
Feb 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Error Code 05
Just because you've turned the camera off/on, doesn't mean it's been reset. This is a fairly easy procedure which involves either going into your setup menu and choosing "reset," holding down the menu key for 5 seconds, or, removing the batteries for a few minutes. It may be that the firmware loading got corrupted and the camera just needs to be "rebooted," which is something that turning it on/off won't accomplish. But after which, you should have the camera reset to factory default settings.
Another tip is to go to Canon's website and look for firmware updates. Download and install them.
Err 05 is when the internal flash is obstructed or the camera doesn't get an reply that the flash open sucessfuly. That should be covered in warranty if its an faulty "pop up flash." Call Canon at 1-800-OK-Canon or Email them at: https://consumer.usa.canon.com/ir/controller?act=SupportMailerAct&fcategoryid=215&modelid=9430
Talk to them and they will give you a more in depth stuff.
J. DeRuvo
Digital Camera HQ
Dec 04, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Rebel XT error 05
I had the same err 05 problem on my canon 350d. But there was no need to remove or open anything! If you have the camera in front of you looking at the lens, you can see a tiny black switch hidden under the flash. On the right side where the flash is attached to the body you can find a fine black piece of plastic sticking out of the camera body (smaller than 2mm. This switch can easily get stuck with some dust (or a grain of sand in my case)
Carefully clean it (with an ear stick) so it can go up down again as the flash goes open or is closed. (It somehow serves as a mechanical sensor)
This solved my error 05. Remember that this is just a general Flash error indication and there could be another problem triggering the warning.
Sep 15, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
456 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
