Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
Hi i have connected 4 pc with d-link des 1008d 8-port switch. prob is that i can access enternet only on 2 pc and can not access access on another 2 pc. when i disconnect one of connected pc then one another can get connected. what is the problem and its solutions. pls assist me... thank you
Maybe u should set domain(no workgroup) on ur server and set your default gatway to server IP. but I'm not sure that works
Posted on Aug 10, 2010
How to setup my des 1008d in my computer
The DES 1008D is an unmanaged switch. therefore there is nothing to set up. Just plug it in and connect to your computer via a cat 5 cable. Here are the manuals
Link DES 1008D
May 06, 2014 | D-Link DES-1008D 8-Port Ethernet Switch...
D link des 800d switch configure ip addess for 2 computers on a network
D-Link DES-1008D 8-Port Ethernet switch is unmanaged switch which can only support 10/100 MBPS.The DES-1008D is a passive switch which means there is no way to configure the ip address and no need to.
Jun 30, 2011 | D-Link DES-1008D 8-Port Ethernet Switch...
How can I install or connect my d link to the internet line and my computer
I assume you have a broadband connection which you are directly to your computer.
In that case please connect the broadband ethernet cable to one of your switch port.
Get a new CAT5 or CAT6 ethernet straight cable and connect one end to any free port of the DES-1008D 8-Port Ethernet Switch and other end to your Computer.
No configuration needed to be done on DES-1008D 8-Port Ethernet Switch
Best Regards
Nov 20, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
How to connecte d-link switch model-DES-1008D two same switch pls urgent
Sometimes we need to connect 2 switches, which can be done by using Ethernet Cable (CAT5 or 6). Just connect the cable to the LAN ports from one switch to another. Let me know the purpose of doing so that i may guide you better.
Hope this helps!
CreativeTECH
Nov 16, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
I have des 1008d switch running at 100 mbps.i want to get 200mbps speed full duplex.so please tell me how to configure this switch to get the full speed.
You need to replace the switch and the network adapters with a gigabyte switch and adapters to get more bandwidth.
For more information on your switch please visit the link below:
http://www.dlink.co.in/products/?pid=183
Rashish
Aug 15, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
1008d wanting to know what to plug in
The D-Link DES-1008d is an unmanaged switch that does not need any configuration to work. You just need to plug in your device (PC/Xbox/Laptop) into one of the ports of the switch, using an ethernet patch cord, and it would start communicating with it. I think your xbox 360 already includes a patch cable in the box. You also need to connect the 1008d to your DSL/Cable/whatever modem, using a similar ethernet patch cord, in order to get online.
This is all that you need to do as far as your 1008d is concerned.
Mar 31, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
I dont how to connect my pc's using D-Link
Dear! first of all you need a 4 port hub or 8 port switch that have easily available. Now, first of all, put three wires (Straight Through Cable) in three different ports and other side its ends put in that nodes or computers. Now they are connected to each other. You want to sharing data for each you should run setup wizard for sharing inside the network places after that computer required a restart. Now the computer will start and data will share to each oher. You should use IP address for computers, first of all IP 192.168.0.1 for first PC and 192.168.0.5 for second PC and 192.168.0.10 IP for 3rd PC. Enjoy, everything is accessible now ...........
Thank You
Jul 28, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Can i have a network gaming in d-link des-1008d
This is a 8 Port ethernet switch, so you can do your network gaming within your local area network, disable firewall on your network adaptor properties. If you dont want to disable firewall then specify exception where you can specify allowed ip address of PC's to access your computer. Find out port of your game www.portforward.com and you can also provide exception of ports.
Jul 15, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
105 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
