Question about Samsung RS2630SH Side by Side Refrigerator
Hi there!! I own Samsung RS21FCSM refrigerator and currently have problem with it. No power at all. I check electronic panel and found 2A fuse broken. Changed fuse but still no life! Capacitor is swollen. I did not found any damaged diode and gretz in high voltage area. Please, if you have some advice or service manual I will be more than happy. Any way , thank you in advance!! Darko
2 Suggested Answers
comike187
  • 17 Answers
SOURCE: How can we install a electronic control panel on
very unlikeley to be the user control panel probably the freezer sensor or freezer fan not operating so no cold air circulating giving a false reading? is it colder at the bottom of the freezer than the top ? that is a dead give away for the fan
Posted on Jul 26, 2009
Hi there I have a Samsung model SRL551DP upside down fridge. Recently our whole block had a power outage. When power restored fridge did not resume. Refrigerator door panel blinks the letter d only?
modern fridges do not like power surges as it burns the electronics
call in a technician to check it out and put a surge protection in the power supply cord
Apr 18, 2016 | Samsung Refrigerators
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
What size is the fuse to the power cord
Hi, you must check the user guide to find fuse rating or check the blowed fuse for current rating, for a DVD/Bluray player it could be about 2A /120V AC..
Jul 08, 2015 | KLH Televison & Video
Need to find the ceramic fuse for my samsung 50"
Hello Dyan, Hi you can find one at any electrical or electronics shop that sells spare parts, But mind you the reason why the fuse blows in the first place, have the power supply board checked for shorts such as a shorted switching regulator. If in the event the replacement fuse blows again, there is definitely a shorted part. Have this checked by a technician.
Feb 12, 2011 | Samsung FPT5084 50 in. Plasma HDTV
Ive got a Fuse problem with an LCD TV a mini 12v 20w
Hi there
I would personally only use a 2.5 or 3A (The same or slightly above ) you may also find that something has gone faulty in the power supply that is causing the fust to blow, I would check the bridge rectifier and all diodes / resistors and also check for buldged / swollen capacitors first.
If these all check out fine then maybe its just a quick fuse change due to a surge.
Hope this helps
Apr 05, 2010 | Televison & Video
Magellan Maestro 4250 fuse
It is a Fast Fuse Glass type 5 x 20mm, 2A, 250v. Magellan 4250 can only take 1A of current at 5Volts Radio Shack
Jun 10, 2009 | Magellan Maestro 4250 GPS
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
No power in the system
Did you have to replace the fuse? Was it opened? Sometimes there is a THERMOfuse INSIDE the transformer [xfmr].Before it blows because of too much heat ,it may blow the 2a 250v external fuse.You must check the power supply [the circut attached to the fuse] input should be 120 a/c in and around [+] or [-] 12 v thru 15 v DC output. Look for filter capacitors & resistors that look like tiny cement blocks(they are thermo type fuse resistors) BE KILEFULL !!! (CAREFUL) the voltages are low but the current could be high. Could stop your heart!!
Jun 07, 2008 | Logitech Z-2300 Computer Speakers
Power supply
Hi have a nice day!
Check if new fuse is of same type that is needed ie 2A , 2,5A as manual says. dont put different.
If you put correct fuse and blows then there is a short circuit at power supply area or after it and your TV must take to a qualified repair shop.
If you are familiar with electronic repairs write me down make and model to look for a service manual available.
Mar 18, 2008 | Televison & Video
Samsung RS2630SH Side by Side Refrigerator Logo
112 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
