Question about HP DeskJet 3325 InkJet Printer
My printer hp3325 can`t print and make sound but shows cartridges not moving
  • 31 Answers
Looks like a belt get damage inside the printer
Posted on Aug 15, 2010
Not printing
Lift the Flat Bed Scanner up so that you can find the Cartridges Inside.
Remove the Cartridges from the Printer.
Move the Cartridge Carrier Back and Forth as fast as you can!
Replace the Cartridges back to the Printer!
Good Luck!!!!
May 14, 2013 | Epson Stylus RX530 All-In-One InkJet...
Will the cartidge box move if cartridges are empty?
For your information obviously the cartridges will move while you turn on the printer or give a print job if the cartridges are full or empty, but it will not print and will show a massage that "cartridge are empty" or "Ink level is too low". If there is any stuck on the way of movement then the cartridge will not move.
Apr 26, 2011 | Canon PIXMA IP5200 InkJet Photo Printer
I bought a new cartridge for hp3325 printer and i used it for some days.Then i didn't use the printer for 2-3weeks now my printer is working but i cant print anything
don't worry your problem will be solved soon:-) please check your printers ink level 1st :-
i think your printer's cartridge become dry,if you are OK! to buy a new cartridge.,do it.,.
Oct 19, 2010 | HP DeskJet 3325 InkJet Printer
Can not detect cartridge from hp3325 deskjet
Solution
Check to see if the installed cartridge is the correct one for the printer. If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 17, 2010 | HP DeskJet 3325 InkJet Printer
My hp deskjet f4140 keeps showing a paper jam and won't print the page I need, there isn't a paper jam.
There is probably a problem with the position of the cartridge carriage. Try reinstalling the cartridge and make sure that the carriage is in the center of the cartridge access area and the center of the cartridge assembly bar. If it is not try moving the cartridge assembly in either direction and restore the printer for printing. Note any sounds as the cartridge attempts to go to its home position. Any grinding noise may indicate that the position of the cartridge needs to be adjusted. Be patient and adjust the cartridge position again until no grinding sounds are heard. It may help to unplug the printer for 30 seconds between adjustments. Good Luck!
Nov 05, 2009 | HP Deskjet F340 All-In-One Printer
Will not print
Make sure you select the printer has the default printer under the Printers and Faxes option on control panel.
Simply right click your printer and select the option "Set as the default printer"
To make sure it is solved, go to the printer properties under the right-click menu and hit "Print test page"
Good luck
Jun 21, 2009 | Canon BJC 80 InkJet Printer
Restart after replace ink cartridge
my CX4800 has done the same thing. I ran the utilities dozens of times, replaced every cartridge and it feeds papers the print head moves like it's printing but nothing is imaged on the paper.
Searching the web is my last chance to fix it before i toss this 18 month old printer and never buy an epson again.
Aug 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Printer not printing
hope you are not properly setup your cartridges
  1. turn off your printer
  2. open your cartridges
  3. setup properly
  4. go to printer properties then if your printer ink show press
  5. test print okkkkk
Mar 05, 2008 | HP DeskJet 930c InkJet Printer
Cartridges not moving
Sounds like a corrupt driver, uninstall your printer (Start> Printers and Faxes on right column), select your printer icon, right click>Delete. Disconnect your printer and re install drivers first, then reconnect printer when prompted. If still not performing correctly suspect printer head carrier fault.
Oct 25, 2006 | Apple HP DeskJet 3820 InkJet Printer
HP DeskJet 3325 InkJet Printer Logo
85 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
