Question about Philips Magnavox 51MP392H Rear Projection Television
Convergence problem I recently replaced the convergence chips and not sure what resistors to replace to finish the job. I'm not a tv repair guy, but I can solder. The picture is about 85 % better than it was before, but not quite there yet. I got the tv from a friend and he said that the picture slowly got worse over time. It doesn't sound to me that the chips was the prob , but I replaced them anyway. What resistors to look for? Can you help plz?
  • Philips Master
  • 8,617 Answers
There are 12 resistors all of them are 6.8 ohm 1watt resistors they are located in front of the ICs heat sinks at board location numbers 3149 -3160 they will all be identical and are grouped in sets of two side by side.
Posted on Jul 31, 2010
We don't have the same model but the resistors to look for on my Philips 51PW9303 were: 3149-3160. Check to see if they look brown in color at each end. If they have that burned-out look they should be replaced. Each resistor will be numbered.
Posted on Oct 23, 2010
I have a Panasonic Projection HDTV that i recently adopted. When i took it home I found a blue "bowing" at the bottom of the video. The experts i spoke to said i need to replace the convergence chips and...
The 2 STK convergence ICS are dead,all the resistors too,if it is smoking and glowing.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it again.Find the correct tv make and model.The convergence kit buy from one of these website's will have all the parts to repair it right this time.
Jul 16, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Double red image, distorted on bottom
Your TV has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Aug 02, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
The screen is blurry but still works the picture is not clear
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
  • Screen looks 3D
0667c5f.pngSolution # 2
Jul 08, 2009 | Philips 55PW9363 55" Rear Projection...
My Tv suddenly looks like it became 3D on the right side of the TV. What could be wrong?
  • Screen looks 3D
Jul 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
My philips 46PP8621 is cloudy and any white in the picture is so bright, i need shades. I cant fix it. It is unwatchable. Please help!!!!
Problem #2)
  • Screen looks 3D
Jun 15, 2009 | Philips Televison & Video
My magnonox is cloudy too!
You guys are awesome! I picked up one of your kits and fixed my TV in less than 1 hour. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Jun 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture too red and too bright
Problem #2)
  • Screen looks 3D
Jun 12, 2009 | Philips 64P8341 64" Rear Projection...
Color convergence "whacked out"/blue shadow to right side
Your TV most likely has a convergence failure. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 03, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Different color shadows appear.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
May 06, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Convergence chips
The convergence IC or in a sense ,amplifiers and the resistor are output resistors... if they are burning up the current going through them is spiking too high... TO me this is an indication that the "convegence yokes" are shorted. These are coils around the tubes that control convergence. I would suspect maybe that these are shorted to ground somehow. This is my first guess for this problem
Feb 11, 2008 | JVC AV-48WP30 48" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
476 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
