Question about Boating
Yamaha XR1800 jet boat the starboard engine won't run over 3000rp
Hi! on XR1800 jet boat the starboard engine doesn't run over 3000 rpm and the spark plug in the middle cilinder remains clean (not working?) All three have compression. On each cilinder sparkplugs show fire. Starts and holds idle ok. I've changed wire but it didn't help. When attempting to add throtlle higher smoke occurs from exaust. The water seems to cool the engine ok. thank you!
  • 157 Answers
SOURCE: Evinrude 25 pk 2 stroke 2cyl outbord boatmotor
Hello enjoy42. From the information you have provided I would lean to the weak cylinder coil. Unplug the good spark plug wire & test run the engine on the weak cylinder. You could go to swapping the coils on the cylinders. Check your wiring terminals on the coils. Check with a marine dealer for the correct plug. I owned a 35 Evinrude on a Bass boat & it would out run my buddys 40 Mercury. Good Fishing.
Posted on Oct 03, 2008
  • 43 Answers
SOURCE: 1993 Ford Explorer idles rough when engine is warm
try changing distributor cap & coil
Posted on Jan 06, 2009
SOURCE: Evinrude 55 boat motor model # 55672E
it could be a little intake manifold leakage...check it!!
Posted on Sep 08, 2009
Delage guy
  • 167 Answers
SOURCE: 1998 camry 5sfe engine, surging at idle
Check for air leaks in the vacuum pipes in and around the inlet manifold, they have a habit if going brittle and splitting.
Another possibility is the temp sender , if the ecu thinks the engine is too cold it will compensate causing the engine to " hunt". This can be something as simple as a worn radiator cap seal letting air into the cooling system and tricking the sensor.
Hope this helps, Marshall
Posted on Apr 29, 2010
bazzz7071
  • 342 Answers
SOURCE: 2001 yamaha ttr 250, starts, idles ok, bogs at acceleration
Has the bike been stored for any long length of time?
old fuel in the carburetor will turn to a varnish like residue blocking the jets,or possibly water in the carburetor.
Posted on May 03, 2010
Testimonial: "The bike was not stored and was ridden regularly, but it still sounds like it could be the carburetor. Thanks for your insight."
I have a starting problem with my 2005 Yamaha XTL 1200 jetski it turns over but won’t start I took out the spark plugs and cleaned them they were black but still wouldn’t go
Black plugs indicate carbon build up. Try starting with ether sprayed into carburetor. If it fires, clean fuel system with spray and additive. Use the fuel engine was designed for.
Jan 11, 2018 | Yamaha Jet Ski Pwc Watercraft Cover Wave...
2000 Yamaha TT-R 225 carburetor tuning
Hi, John if you have changed your fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" your not getting enough fuel.
1. Close to 1/8 throttle is managed by the air screw and pilot/slow jet.
2. 1/8 to 1/4 throttle is managed by the air-screw, pilot/slow jet, and throttle slide.
3. 1/4 to 1/2 throttle is managed by the throttle slide and jet needle.
4. 1/2 to 3/4 throttle is managed by the jet needle, needle jet, main jet, and air jet.
5. 3/4 to wide open throttle is managed by the main jet and air jet.
6. Wide open throttle is managed by the main jet.
If you are running lean, spark plug electrode color is white, engine runs hot and feels like it is starving for fuel you need to go up on the jet size or move the c-clip down one notch. If you are running rich, spark plug color is black or dark gray, the engine runs cool, and bogs down when accelerating you need to go down on jet size or move the c-clip up one notch. When your carburetor is properly tuned for maximum performance your spark plug electrode will be a light tan color like coffee with cream. If you prefer fuel economy over performance you can go down on main jet sizes until a satisfactory level of lower performance is acceptable versus MPH, your spark plug color will be whiter and your engine will run warmer. These tuning adjustments will only make improvements if your intake and exhaust system have no air leaks or sealing issues and the entire electrical system is in proper working order and you have no mechanical issues.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Other ttr 225 carb troubles
Carburator Theory and Tuning
http://tjsconcepts.com/ttr225/TTR225_Service_Manual.pdf
OEM parts for Yamaha
Yamaha TTR225S Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 30, 2017 | 2002 Yamaha TT-R 225
At least once every trip the starboard engine goes into a wild rpm fluctuation and has to be shut down several times to get back to normal
Hi David:
Starboard? Sounds more like a boat than a car or truck.
What kind of engines are we playing with.
Fuel supply will probably be the problem so make sure all filters are clean and that there is no water present (in the fuel - outside under the boat is OK)
If this is a diesel engine, the fuel will be shut off with a solenoid. If something is shorting the ignition switch off position, the engine will think it is supposed to shut down, consequently, engine will die, then rev, then die, etc.
Reply as a comment to this post to discuss further.
Cheers
Apr 15, 2016 | Boating
I have a 2012 mercury 6hp four stroke that will not idle without the choke on
Hi, Lee and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Boat Motor Won Stay Running Watch This
Mercury Outboard Idle Adjustment
2010 6 hp Yamaha 4 stroke wont run with choke in Page 1 iboats Boating...
8m0055686r. google this for a free manual
Won Idle Here what did to fix it Yamaha Outboard Parts Forum
Apr 13, 2016 | Motorcycles
1999 r1 flat spot at 3000 r p m
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for leakage in the dark.
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP sensor.
9. Intake air leak.
10. Water, dirt, or rust in the fuel system, carburetor and/or filter.
11. Fuel tank vent system plugged or carburetor vent line closed off.
12. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
13. Carburetor controls misadjusted.
14. Damaged carburetor.
15. Incorrect valve timing.
16. Weak or broken valve springs.
17. Damaged intake or exhaust valve.
18. Check for engine trouble codes
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
1999 Yamaha R1 Flatspot Biker ie Forums
http://www.r1-forum.com/forums/101-98-99-r1-mechanical-help/474929-99-r1-3000-rpm-flat-spot.html
1998 1999 Yamaha YZF R1 Service Manual R1 Moto Data Project
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 03, 2013 | 1999 Yamaha YZF-R1
I just got a 1997 yamaha virago 1100. It will not idle unless I leave the choke on and the engine revs at 3000 rpm. Runs perfect after 3000 rpm. Any ideas? Original factory carb settings? Thanks
Hi, Ungerconstru and the usual suspects are:
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Bike won Run without Choke
Won Idle Choke
http://service.tanga-moteurs.ro/data/yamaha_virago_535_700_1100.pdf
Yamaha Virago XV1100K Owner Manual
Jul 29, 2011 | Yamaha Motorcycles
Yamaha Exciter jetboat: eng stops when warm, not overheating
I have a 1998 Yamaha Exciter jet boat as well and am having a similiar problem. I just took it in today and the mechanic believes that it may be the oil pump failing which causes the pistons to stick and not lube the engine properly, thus causing overheating and eventuallly stall. The one motor sounds beautiful and the other sounds unhealthy. He checked compression and it seemed fine and it has new plugs. Maybe this is the same problem you are having...Hope this helps...
Mar 24, 2010 | Yamaha 12V Air Pump
I have a 50hp 2007 yamaha 2 stroke
Did you change your fuel? If you are trying to use the same fuel from last year without being stabilized then that would cause your problem. I know that you already had your carbs cleaned but it sounds like something els got plugged up in them. If you have fresh fuel then I would take the carbs back apart and check your jets in the carb to ensure that there is nothing obstructing any of the orifaces in the jets. I am a boat mechanic and I have had to take carbs apart 2-3 times sometimes if they were varnished really bad to make sure I got all of the gunk out.
Sep 14, 2009 | RTO Oar Sockets
How to connect a 2 bank (4 batteries) to the 3 GUEST switches.
Sorry for the delay. I don't understand why they have the third "on/off" switch. Normally on a boat like yours, the set would be as follows :
Each pair of batteries would be jumped together to make a single large bank. We can then consider them "bank 1" and "bank 2" usually they will correspond to port and starboard.
Now you will take the positive lead from bank 1 and connect it to B1 on the port switch and then jumper it to B1 on the starboard switch.
You will do the same for bank 2 and the starboard switch.
The "common" on each switch will be your positive output to the motors corresponding them to port and starboard.
Now you can run your port motor with the port switch selected to battery 1 and the starboard motor with the starboard switch selected to battery 2.
Your emergency parallel is already built in. If battery bank 1 dies, you can start both engines with battery bank 2 and vice versa. Putting the switche(s) to the "all" position will allow you to start/run the engine(s) form both banks at once.
You can use the third switch to supply the "house" system. Take its power feed from the "common" terminal on either of the battery switches. In this way you can isolate which battery bank you use to draw power from for all of your accessories so there is no fear of you running a battery bank dead and being stranded. For example if your house feed is connected to the port battery switch and you have the port battery switch selected to bank 1 (port bank), should you run the battery dead listening to the radio you can simply start the starboard engine and then select "all" on the port switch. Now the starboard engine will be charging the port battery bank, bringing the house system back to life and allowing you to start the port engine.
In order for the system to work it is important that all of the battery and engine grounds be connected together in a central point (a common buss bar).
Dont forget that you cannot switch battery switches while the engines are running.
Good Luck!
Jul 22, 2009 | Guest 297 Secondary Station Control For...
Boating Logo
227 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
