Question about Toshiba Video Cameras
Reset button ?
My camera doesn't turn on but when I put it on charge it charges put then it doesn't turn on is there a reset button if so where ?
  • Michael Jingle
    Michael Jingle Apr 07, 2012
    I've got it, remove the battery for about 20 minutes or so with nothing connected to the camera, when you put the battery back in, it should work, worked for me.
I've got the same problem with my s20. but it won't charge. If I take the battery out, the lights light up, and shut off after about five seconds. with the battery in, nothing happens, plugged in or not. I've tried it on the computer and on the charger, and nothing will happen, but the computer still recognizes it. I'm not happy, it was working 30 minutes ago. Someone needs to find a solution.
Posted on Apr 07, 2012
My Toshiba Camileo H30 camcorder i put it on the charger last night and today it does not turn on and when i plug the charger into it nothing happens no lights nothing how do i reset it or how do i get it working again?
Posted on Nov 25, 2011
  • Tim Mitchell Nov 28, 2011
    Did you find a solution, I have an H30 with the same problem.
    Thanks
  • Michael Jingle
  • Toshiba Master
  • 6,826 Answers
Sometimes there is a reset button and sometimes you have to reset it through a menu. Of course, if it won't turn on, then you can't get to the menus.
May I ask, what is you Toshiba camcorder's model #?
Posted on Jul 31, 2010
  • mycatbob Feb 28, 2011
    Yeah, Have the same problem. It is a Toshiba Camileo S10. Charges OK. Tested Battery, sitting at 3.5V. Any Ideas on resetting?
  • Michael Jingle
Turns on, lens goes out then cuts out
Do a power reset on your camera. Switch on your cam. Now, without shutting it off, just open the battery compartment and take the batteries out.Check if there is a small pinhole in the compartment, which is usually a reset button. If it's there, insert a pin inside it and press a little, u will feel a button has been pressed. DO NOT PUSH Forcibly. Now, wait for about 1-2 mins. and then put the batteries in and turn on the camera. Try it. (P.S. Before doing this, Please check the batteries if they are charged or not, if not, charge them first.)
Sep 16, 2013 | Fuji FinePix S7000 Digital Camera
Phone is charged and won't turn on, also reset doesn't work
your battery is probably broken, try replacing it (ifixit.com), or let someone else fix it for you.
Dec 02, 2012 | Apple iPhone 4S
No GPS signal
Ok Marilyn,
Thanks for the info. Your device has no dedicated reset button like some other Tom-Tom units, but it still can be reset.
To perform a reset, make sure that the unit has a fully charged battery. Charge for several hours if unsure - and make sure the charging light comes on (if it doesn't - it will probably need service) while connected.
Disconnect from charger.
Press the On/Off button to turn the unit on (if not already on) and allow it to start up as usual.
Press AND hold the On/Off button for up to 15 seconds or until the unit turns off.
The GPS should now be reset, and should work as expected when you next turn it on. Good luck!
Apr 15, 2012 | GPS
I charge my mp3 but it doesnt fill up. i charge it for a few hours and it says ok to disconnect. when i try to turn it on, it doesn't.even when i charge it, the icon stays empty.
Check the charging , if you are using USB charging try with another port or with another PC. If the fault still stays then the battery, the main controller within the player or the cord can be a suspect. If there is a small reset button press it down to reset as the last option.
Aug 23, 2011 | Audio Players & Recorders
My camera won't turn on i charged it and now it won't turn on!
This truly depends on the make and model of your camera. If it uses a rechargeable pack, make sure to fully charge the battery and try it. If this still doesn't work, try plugging it in the computer via USB. If it turns on, then your battery pack may be causing the problem. I would suggest you to bring it to your nearest service center for them to check it out, especially if you still have warranty and so they can replace the battery pack. Some cameras have a reset button at the very bottom (or look into your camera's manual if there is such a thing for your camera) which could be an option as well.
Jun 14, 2011 | Cameras
After being reset and plugged back into computer to charge, a red light pops on as soon as plugged back into usb port to charge and will not turn on.
Put a pin in the reset button situated in the tripod hole.Do it three times for about thirty seconds each time.Also depress the on off switch for about thirty seconds.Put it in the usb port of your computer to charge.After about thirty minutes or an hour the screen should go white.A battery shows on the screen.Wait till the battery shows all green,then it is fully charged.
Oct 28, 2010 | Pure Digital Flip Mino Digital Camera
Dsc p73 wont switch on when in green camera mode. Tone is short, swiches on in photo preview only with normal tone battery is fully charged.
I'm sorry that the camera is not turning ON. Please make sure that the battery is fully charged.
Please reset the camera by pressing the reset button located near the DC IN jack. if the issue still persists, please power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Sep 26, 2009 | Sony Cameras
Camera wont turn on.
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jul 18, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Canon 40D can not turn on
Same problem. Fully charged main battery. In my case, I hadn't used the camera in over 6 months. All I did was pull the main battery and then pulled the small CR 2016 button cell battery located inside the main battery compartment and re-inserted both batteries. The camera made a quiet click and then turned on with the main power switch and asked to reset the date and time. Works fine now. If this doesn't work just purchase a new button cell.
Sep 17, 2008 | Canon EOS 40D Digital Camera
Video Cameras Logo
1,616 people viewed this question
Top Toshiba Video Cameras Experts
Marvin
Marvin
Voros101
Tom Chichester
Are you a Toshiba Video Camera Expert? Answer questions, earn points and help others
