Question about KitchenAid KESC307 Electric Kitchen Range
Power board
The power board in my kitchenaid oven is broken. where can i get a new one?
    Problem Solver:
  • 6 Answers
We can rebuild your power board for you.
Regards,
Howard
www.appliancetimers.com
Posted on Apr 25, 2008
Kitchenaid superb microwave.oven combo KEMC308KSS0 is giving F2 E0/E1 error. Replaced the switch membrane and also the Control board. The error still shows up.
Ledgestone Technologies has replacement keypads for NO LONGER AVAILABLE Whirlpool and Kitchenaid models. Each one comes with a new ribbon cable and 2 year warranty.
Contact FixYourBoard.com for more information!
512-355-1108 info@fixyourboard.com
Apr 15, 2017 | KitchenAid Ovens
Kitchenaid range not working. 36" dual fuel. Had repairman out he tried replacing boards and knobs. still no power going to controls for oven. stove top working fine. 240v service has been checkd
Hello Joe Corney,
Not giving a MODEL NUMBER makes this mostly conjecture...
My personal experience with KITCHENAID does not
inspire great confidence... (still REALLY angry)
If it's NEW just ship the WHOLE THING BACK
IMMEDIATELY...
Else... Get on YELP... and start going thru "technicians" until you find one worth the trip...
If the control boards have already been changed ...
AND THE POWER HAS BEEN VERIFIED... repeat that process...
Nothing about electric ovens is MAGIC...!!
Pretty much replacing those boards eliminates
the lock & Sabbath modes...!!
If this is the UNIT I'm thinking... (High end = $$$$$)... but
in no way IMPLIES QUALITY in design or assembly
(my experience is quite the contrary).
You NEED to get COMPETENT (FACTORY AUTHORIZED)
help out IMMEDIATELY...
(patience/understanding will only make you the VICTIM).
KITCHENAID moves on quickly and has no problem leaving
customers like YOURSELF without service parts or reasonable alternatives...
Support Chat... 1 (800) 541-6390
Compare Appliances
ServiceBench
Jan 23, 2017 | KitchenAid Kitchen Ranges
Error code F6E0 on Kitchenaid KGSS907000 wondering if it is the control board or touch screen, what other components could cause this?
F6 - E0 Return line not connected If switch pulse return line is not connected, electronic control will display F6 within 60 seconds after power up. Replace control board
May 02, 2014 | KitchenAid Architect Series KEBC107KSS...
KitchenAid Double Oven LED Blank
These ovens are made by Whirlpool. The electronic control board is notorious for going bad. If it is the one I am thinking about it is probably no longer available and will need to be rebuilt. I have had good success with Corecentrics Solutions. A google search will bring them up. I sent off the board and a rebuilt one arrived in about a week. Much cheaper than the original board too.
Nov 26, 2013 | KitchenAid Ovens
Microwave won't heat for first minute - starts working normally after that.
The magnetron may be defective. You can replace the magnetron, there is no other possibility.
Jan 16, 2013 | KitchenAid KHMC1857WSS Microwave Oven
Error code of E1 F2 on a kitchenaid double wall oven. What does that mean?
F2 - E1
Keypad cable unplugged
1.
Check keypad connector for firm connection (keypad connects to control
board).
2. Press CANCEL. If error code returns after 60 seconds, replace
keypad (also called touch pad or membrane switch). Some models incorporate
keypad in to control board as one unit. In this case, replace control board
(also called ERC or clock).
Feb 15, 2011 | KitchenAid KEBC207 Electric Double Oven
Latch opener spring broken wont open door
You can buy a new door spring through KitchenAid by calling For more information on warranty replacement, please call 800-541-6390
that should solve the issue if not feel free to contact me.
Jan 29, 2011 | KitchenAid KCMS145J Microwave Oven
Kitchenaids microwave error message F2.Q1. What to
F2.Q1 Not reading keypad
inputs
1. Unplug microwave oven or disconnect power.
2. Replace the user interface board (UIB).
3. Replace the door control assembly.
4. Replace all parts and panels before operating.
5. Plug in microwave oven or reconnect power.
Many of the error codes may be solved by power cycling: unplug microwave oven or
disconnect power. After one minute, plug in microwave oven or reconnect power.
i found this info on a tech sheet hope this helps, let me know how it goes... some of those electronics had 5 year parts warranty i would check that out....Also u might be better of buying a new one if its out of warranrty as some of those boards are expensive, obvioulsy unplug unit first try to reset it self.
Feb 14, 2010 | KitchenAid KHMS2050SSS Microwave Oven
The knobs is broken on my Kitchenaid KCo1005 toaster oven
I had a similar problem a while back and contacted Kitchenaid at 1-800-541-6390 and they mailed me a new one at no cost.
Nov 24, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
All Surface elements are dead
Sounds like you might have a bad oven surface control board also called power board. The part # is 316239400. It is located on the left hand side about mid way down on the back of the oven. First, disconnect power and make sure all connections on board are tight. Plug back in and make sure you have power to that board if possible with a meter. If all check ok then the board is bad.
Oct 05, 2007 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
