Question about Acer Aspire™ T180 PC Desktop
Hard drive filling up
I have a problem with the c drive filling up.i have had the acer aspire T180 with 250gig hard drive for 3 weeks and my computer shows i have used almost 60 gig of hard disk space with minimal usage.could it be a problem with vista?
  • 54 Answers
Clear the temp folder and recycled bin
Posted on Apr 25, 2008
C drive says there is almost no space
I assume that you're running a spyware/adware program weekly and that no one using this laptop is downloading movies, or large amounts of audio files as either can fill the hard drive fairly quickly. Also, although it is usually given a different drive letter, you may be viewing the restore partition Acer uses if the computer needed to be reset to original factory settings.
Jan 08, 2014 | Acer Aspire 4250 4251 4252 4253 4333 4339...
Hard Drive exchange older sata hard drive {acer brought 3 years ego}and newer system /deferent hard drive
All adapters and cables are available from a computer store or cheaply through fleabay.
Jun 26, 2017 | Acer Aspire One AOA150-1784 Netbook
Hi my acer aspire 5315 will not boot up, i turn it on i get nothing but the little cursor in the top right hand corner...can anyone help please thank u in advance
That is probably because some important boot files are missing. What you can try is to take out the hard drive and move it to another acer aspire 5315 computer. To take out the hard drive, remove ALL electrical components (power cable, battery, etc.), open the computer's hard drive bay, and take it out VERY carefully. Make sure you do not cut the cables. That could damage the hard drive. Then, you remove the hard drive on the other acer aspire 5315 computer using the same instructions above. Then, you can identify the missing boot files (they will be in a hidden drive called System Reserved), copy them onto your computer's hidden System Reserved drive (if it's missing you'll have to create one manually), and put it back in the other acer aspire 5315 computer. Make sure that you put the wires where they were when you removed them, otherwise the hard drive might not work. Then, try turning on the computer again.
Nov 14, 2010 | Acer Aspire 5315 Notebook
I have an ACER Aspire 5100 purchased in February 2007 and for the past two weeks it has been giving me trouble to load. I have to constantly restart or shutdown the computer for it to load properly. Any...
There are many details missing here but 1st
1. you may have a hard drive issue / the hard drive may need to be defragmented
2. You may have a power supply issue not enough power to power the mother board due to a failing power supply
3. your system may be set to sleep mode.
these are a few things to check.
More information is need to give a more detailed response to this issu
Oct 05, 2010 | Acer Aspire 5100 Notebook
ACER ASPIRE NOTEBOOK MODEL ASPIRE 4736ZG, IF I CHANGE RESOLUTION TO 1024X768 SCREEN SIZE BECOMES SMALL. HOW TO ADJUST VERTICAL AND HORIZONTAL SIZE SO WHOLE SCREEN CAN FILL IN.
i have acer 4736zg ;that i bought 4 months ago my computer gets heated and shuts down automatically; it works nicely for a week; and gets heated and shut down automatically 3 to 4 times in a day; i am using windows 7 and kapresky anti virus before my computer has windows vista and mcafee antivirus. yesterday my computer showed blue screen death for six times each time i connected net ; i checked the memory status and now its ok but it shutdown for three time in last 12 hours; can u plz help me out
Dec 16, 2009 | Acer Aspire 4720 Notebook
Acer aspire 3680 can't find op system
THE CMOS BATTERY IS BAD REPLACE IT AND REBOOT SYSTEM.
THE SYSTEM DOESNT SEE A HARD DRIVE, CHECK THE CABLES TO THE HARD DRIVE CHECK THE POWER CONNECTIONS
FILL THE HARD DRIVE SEE IF YOU FILL MOVEMENT, IS IT WARM,
POWER SUPPLY MAY BE ANOTHER ISSUE
NO OPERATION , NO SYSTEM, NO CONFIGURATION, CMOS CLEARED, POWER SURGE, LOSS OF POWER,
ROD
Jan 11, 2009 | Acer Aspire 3680 Laptop
Reset Acer Aspire One to factory settings--clean hard drive
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Dec 28, 2008 | Acer Aspire One AOA110-1626 Notebook
Acer Aspire 5100 crashing
search the help fill on your pc for the fixed drive problem or try google
Nov 17, 2008 | Acer Aspire 5050 5430 Laptop
ACER ASPIRE M5641
Acer Aspire M5641
NVIDIA nForce 630i/7100
Intel(R) Core(TM)2 Duo CPU E4700 @ 2.60GHz
1. Go to http://www.nvidia.com/Download/index.aspx?lang=en-us
2. Download the latest version driver, extract to flash disk.
3. Connect your flash disk when windows said that driver is missing (before enter vista serial
number) and browse to "IDE/WinVista/sataraid" windows will choose the driver that it need,
install it
4. The process will continue as usual....
Nov 13, 2008 | Acer Aspire RC500 PC Desktop
Acer aspire 3000
Could be a bad memory chip or a hard drive crash. Can you hear the hard drive engage? If so, is there any clicking or dull thunking sounds? Both of these are indicators of a hard drive failure.
Jun 21, 2008 | Acer Aspire 3000 Notebook
Acer Aspire™ T180 PC Desktop Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
