Question about Adidas Sport Adp1131 Watch
How can I remove alink from my Adidas watch strap?
  • 2,334 Answers
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jul 31, 2010
I need a replacement strap for an Adidas watch ADP1084
Fixya does not sell replacement straps.
Oct 24, 2016 | Adidas Watches
I need a strap for my adidas wrist watch....please help me out
j is a problem of my shows I need to please a sinture shows adidas reference "ADP1039" and thank you.
Mar 06, 2012 | Adidas Sport Adp1039 Watch for Men
I have adidas watch adh1162 i would like to buy original strap ,wher i cant find it
This is only form of contact: call me please..,. Jamila its bad she needs help
Jul 25, 2011 | Adidas Trefoil Flyboy Chrono ADH1162 Watch...
Where can i get a replacement strap for Adidas ADP1010 watch?
Call Adidas up directly to order the part. Its a very rare watch with a unique band hopefully they will still have one.
Dec 28, 2010 | Adidas Medium Watch Adi Star Pro Chrono...
How do I remove links from an Adidas Candy Wrist watch?
You can't. You must be referring to a different watch because the Candy Watches have a polyurethane strap as shown here:
http://www.shopadidas.com/product/index.jsp?productId=3078734
Jul 19, 2010 | Adidas Unisex wristwatch
How do you set an Adidas Watch (Women's ADH6051)
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ADIDAS watch manuals. Rate me, please
Mar 10, 2010 | Adidas Digi III Watch
I cant seem to be able o turn the alarm on and off for my adidas fitness control watch
I presume that this means you no longer have the manual.
This being the case, then go to "www.adidas.com/campaigns/watches_fw07/content/" and you will see a menu on the left. Select instruction manuals and scroll through their list of instructions until you find the one for your watch.
Jan 20, 2010 | Adidas "Fitness Control" Orange & Black...
Adidas Sport Adp1131 Watch Logo
2,407 people viewed this question
Top Adidas Watches Experts
Ansel Alberto
Ansel Alberto
Watchmaker71
Level 1 Expert
Are you an Adidas Watch Expert? Answer questions, earn points and help others
