JUST MY TWEETER IS WORKING. BLOWN FUSE? CAN IT BE FIXED MYSELF?
    Novelist:
  • 169 Answers
Turn off the amp, change over the speakers turn on amp at LOW volume and listen to music, if same speaker is faulty them bass unit is blown replace or recone.
Posted on Apr 30, 2008
Have 2 jbl 615 get good base and sub but neither tweeter playing
You will need to determine if it's the amplifiers or the tweeter themselves that are not working. If you open up the cabinets and check each tweeter with an ohm meter for continuity it will show if the tweeters are working, in which case the amp is the problem. if the meter shows that the tweeters are blown, you should still hook up another tweeter or speaker to the horn amp to see if it's blown and therefor took out the tweeters.
If any of this sounds complicated, you'd be best off taking the cabinets to the repair shop.
Mar 16, 2015 | JBL Audio Players & Recorders
If all speakers except some of the super tweeters in my gem sound tr-150 cabinet aren't working, could it be the crossover network that they appear to be all wired to, is no good, or do you think all...
Did you actually mean "all speakers... AREN'T working" except some tweeters? Crossovers don't protect the woofers. If crossover die all speakers they protect go silent due to loss of signal. Excess volume or distortion kills speakers and not always linearly.
If you said it wrong and some tweeters work, I'd suspect the latter above...
You (or we) could guess or you could take out one tweeter at a time and swap it with a (presumed) working one or just emasure it for dead short or open with an ohmmeter. If the tweeters check out and work elsewhere the problem would likely be within the cabinet.
Sep 08, 2011 | Gem Sound TR-150 Speaker
I loaned my fender passport 300 to some friends. They said they ended up using it as a mixer on a larger system. Now one speaker works normally on one output. when i switch that same speaker and wire to...
It would appear they've blown one channel on the Amplifier and one Tweeter on your Speaker. It's more than likely that the Tweeter has blown first and overloaded the Amplifier.
The Tweeter shouldn't be a problem to replace (eBay more than likely) and you'll probably be better getting a new pair and replacing them both.
The Amplifier could be a different issue depending what Country you're in and your Technical ability?.
If you need any further assistance once you've opened the unit then just ask.
Please leave feedback
Cheers
Andy
May 08, 2011 | Fender Passport P-10 Professional...
My monitor is styill for working but the tweeter dont make any sound. i think its blowed up, is there a fuse a something that could be replaced in the amp?
no fuse in there unfortunately.
The problem could either be a blown tweeter (but that would likely cause distortion rather than silence) or a fault with the amp or crossover. Often it seems a relay is at fault in these instances with dynaudio monitors. In any case, unless you have considerable electronics knowledge (which I think it's fair to assume you don't ?) you won't be able to fix em yourself. Give dynaudio an email or call - they're helpful.
Dynaudio North America
1140 Tower Lane
Bensenville, Illinois 60106
USA
Phone (630) 238-4200
Fax (630) 238-0112
For Service: service@dynaudiousa.com
Apr 25, 2011 | Dynaudio BM5A MKII Monitor Studio Active
No sound from one tweeter
Could be an open capacitor in the cross-over, unconnected wire to the tweeter (not likely) or a blown (open) voicecoil in the tweeter. Remove the tweeter and with a 9 volt battery (even run down but not dead will work) quickly touch it to the connections to the tweeter - it should pop and crackle. No static, the tweeter has sung it's last song.
Apr 08, 2011 | Acoustic Research AR 318PS Speaker
Please help! I was playing my keyboard and i decided to have the volume a little higher and suddenly i heard and unbalanced output sound from the two of my monitors. I discovered that one of them only...
This is a BI-AMP powered speakers setup, the power amp for the woofer is still working but either the high frequency power amp for the tweeter is blown or the tweeter speaker is blown, you will need to use an Ohm meter to check the tweeter and the fuse in the high frequency amp.
Feb 11, 2011 | IKEY-AUDIO M-606 POWERED STUDIO MONITOR
BLOWN FUSE?
If no warranty - remove amp and check sub to another amp to isolate speaker from internal amp. Either the amp blew a channel or subwoofer blew. JBL's are typically well built. Has this speaker often been pushed loud often?
Apr 23, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Wharfedale Modus One
The tweeters are probably blown, i had the same problem.
You can test this by placing the cable on the dismanteled crossover at the back of the speaker. colour blue/yellow.
No high volume please.
See http://www.hometheatershack.com/forums/diy-speakers/4549-wharfedale-modus-one-six-crossover-pics.html
for pictures.
If the tweeter is blown it can be dismanteld with the aid of a screwdriver, horizontally.
Place it between the tweeterbowl and the ring which has the mark wharfedale on it. The tweeter comes loose. On second hand sites you can buy little speakers, like modus one or two's with the same tweeters for a good price and put them on your larger speakers.
This how i repaired 2 of my 4 modus eights.
good luck Danny Mol
the netherlands
Jan 15, 2008 | Wharfedale Modus One-Six Speaker
KLH tweeters stopped working
hi, have u first disconnected the tweeters and then checked, as if its on a cross over, the tweeter is in series with a capacitor,if u have a ohms meter or a continuety tester check the tweeter coil if its open,secondly you can have the coil replaced, check if u can get one before buying a new,let me know
Jan 11, 2008 | KLH HT-9930 System
TweeTer Not working.
The only way I can think of to check is to disconnect the leads to the tweeter, then check resistance with an Ohm-meter...no reading means dead speaker.
Dec 28, 2007 | Car Audio & Video
48 people viewed this question
 Grubhead
Grubhead
