Question about Sportsart 6300 Treadmill
Treadmill mati pada saat dioperasikan
Treadmill merk sportsart 6300 tiba tiba stop pada saat operasional
maxtreadmill
  • 832 Answers
SOURCE: SPORTSART 6300 SHOWING E 1
Error 1 come up when the drive motor is not moving. Unplug unit then remove motor shroud then plug unit back in and you will see a circuit board with multiple lights. On Lower portion of the board you should be able to see a amber LED this is your speed sensor light . To test the speed sensor just manually rotate motor fly wheel ( where Drive Belt is visible) and you should be able to see the amber light flickering that means speed sensor is good. Next thing to do is unplug unit and check the motor they sometime get stuck in their chamber so be gentle pulling them out and blow out the excess carbon material out of motor wear a mask when doing the black dust can be much then re assert motor brushes and it should take care of problem. If they are worn (less than 3/8 in. in length) then call Sports Art @1-866-709-1750 the people their are good to work with and any further question they will be able to answer.
Posted on Feb 28, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a sportsart 6300 that keeps blowing up Q2
The bridge rectifier is shorted with gives Q1 and Q2 the appearance of being shorted and blowing the 15 amp ceramic fuse
Posted on May 13, 2010
joeguest2
  • 2080 Answers
SOURCE: I need an owner's manual
Click on the following link:
http://www.sportsartamerica.com/saf/support/technicalsupport/owners_manuals.asp
Select the 6300 Treadmill under COMMERCIAL PRODUCTS.
Save the file somewhere on your computer.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
Otherwise just unzip and open the file.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Posted on Mar 12, 2011
Testimonial: "Great service. just what i needed. many thanks! Jim McClanahan"
  • 95 Answers
SOURCE: I have a Sportsart treadmill
I would think that it can't hurt anything to try another magnet but if you end up needing to buy another one here is one website that sells them: Sportsart TR20F safety key
Posted on Apr 18, 2011
ercupa190
  • 12223 Answers
SOURCE: My SportsArt 6300 suddenly accelerate from 4
Dear Sir:
Hello, I will try to help you, inmediately.
Please follow the next step:
1) Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be
on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack
bolt models will have flat mounts and may contain up to four bolts.
2) Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel
with the drive and walking belts. If your treadmill is not equipped with this bolt, . If your
treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16"
wrenches, make a few turns to this bolt, tighten the bolts from Steps 1 and 2 and test your treadmill for
slipping. If belt continues to slip, repeat Steps If a second attempt does not repair the problem
3) If you have arrived at this step, let's make sure you have a drive belt tension problem. With the motor cover
removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the
problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when
stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem
is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls,
you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will
usually make a loud squealing sound on the metal front roller. The entire front roller assembly repaired or
replaced (see the help topic on replacing a pulley) and the drive belt must be replaced. We suggest
replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual
wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt
dressing may help correct the problem. If not, the drive belt must be replaced.
Please check this video:
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
http://www.youtube.com/watch?v=zXeHMWTcLUY&feature=related
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Oct 13, 2011
Sportsart 1080hr has power, but only red emergency stop lights are flashing. Magnetic key in place. Nothing happens if I reset the emrg stop?
1) adjust the REED switch, test for open or defective, clean it, and tight the plug or connector very well.
2) After you fixed RUN the software calibration for easy diagnose, troubleshooting. and fix it.
God bless you
Nov 28, 2012 | Sportsart 6300 Treadmill
Pada saat menekan tombol power camera digital tidak hidup atau mati , bagaimana solusi menghidupkannya kembali ?
saya mempunyai camera samsung ES95 baru dua bulan 4 bulan entah knpa pas saya mau pakai terus saya hidupkan/ tekan tombo; power nda mau nyala2 padahal kamera saya aman2 ajx kondisi sebelum saya hidupkan batrai full kondisi nda aman
ada yang tau nda gaimn cara hidupkan
terimakasih ???
Jul 13, 2012 | Fuji FinePix A345 Digital Camera
Tlong bntu sy bos,, sy lupa pasword poker 88
bos sya lupa password poker88 sya , sya lupa alamat emailnya dan sya ganti nomor telpon sya nich nomor telpon baru sya 081256409287 tolong bos dengan segera ,,,
trims
Jun 17, 2012 | Yahoo Mail
Psp-1004 pada saat saya main games ya tiba hilang sendiri n saya mau coba lagi games ya tidak bisa terbaca, tapi pada saat memory ya saya pasang di psp teman saya terbaca dan memory teman saya...saya...
tolong dibantu ya....
waktu itu memori saya lepas buat ngehapus musik,tapi pas aku masukin lagi memorinya tiba2 gamenya ilang smua,itu kenapa ya,padahal game sama sekali enggak aku sentuh?? apa bisa game2 tu kembali.????
May 10, 2012 | Sony PlayStation Portable (PSP) Slim...
Printer epson L 200 mati total
Mainboard diodanya adalah kelemahan epson pada semua jenis printernya, bisa diperbaiki, :) dioda murah hanya 6000an, atau bisa lgs ke garansinya
Mar 21, 2012 | Epson Office Equipment & Supplies
Need an owners manual for A sports art 6300 TR 63
Go to SportsArt America.com click on support drop down and click on manuals click on owner's manuals scroll down treadmills and half way down you will find t6300 owner's manual
Sep 16, 2011 | Sportsart 6300 Treadmill
Knp saat saya sms tiba-tiba hp saya mati ??? truz sms yg say tulis hilang smua ,,,
menurut saya ada dua kemungkinan kenapa hp mati secara tiba2:
1. terjadi kerusakan firmware dalam arti hp anda terserang virus ato anda sering menginstal aplikasi yang tisak kompatible dengan hp anda
2. ada masalah dengan baterai anda...
coba bawa hp anda ke samsung center dan minta hp anda di upgrade, jika masih memiliki masalah yg sama berarti baterai anda yang mungkin bermasalah..
jika baterai anda menggembung (permukaan nya tidak datar), maka coba ganti dengan baterai yang lain..
kalau anda sedang menulis sms dan tiba tiba hp anda mati, pasti sms yang anda tulis hilang karena belum tersimpan dalam hp anda..
semoga membantu..
thanks. please rate
Mar 06, 2011 | Samsung Omnia Pro B7320 Smartphone
Power on lensa tidak mau keluar.muncul tulisan turn the power off and on again
Error: TURN THE POWER OFF AND ON AGAIN ditampilkan pada layar LCD saat Mekanisme Lensa macet atau ketika terpengaruh oleh kerusakan apapun. Jika memutar power on dan off lagi tidak menyelesaikan pesan kesalahan, coba lakukan reset kekuasaan dan Inisialisasi pilihan.
Melakukan reset tenaga manual
Matikan kamera.
Keluarkan baterai.
Tekan terus tombol daya selama 30 detik.
Biarkan kamera untuk tetap tanpa listrik selama 60 detik.
Masukkan kembali baterai.
Hidupkan kamera.
Untuk mengatur ulang Kamera kembali ke default pabrik, pilih Opsi Initialize dari Menu Utama Pengaturan 1 dari Kamera ke OK.This akan mengatur pengguna menentukan pengaturan kembali ke default pabrik. Gambar-gambar dan video tidak akan bisa dihapus.
Jika masalah berlanjut, mungkin diperlukan layanan.
Terima kasih telah menghubungi FixYa.
Feb 23, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
Akun keamanan saya hilang
Anda bisa mendapatkan password baru, pengingat Yahoo ID, atau keduanya. Jika Anda lupa Yahoo! ID atau sandi Anda, pergi ke halaman Daftar-in Masalah.
Jika Anda lupa ID Yahoo!, Anda harus memberikan tiga informasi sehingga kita bisa memastikan identitas Anda:
Anda ulang tahun
Anda ZIP atau kode pos (pada saat Anda membuat akun Yahoo! Anda atau ketika Anda terakhir diperbarui)
Anda alternatif alamat-email Catatan: Anda harus memiliki akses ke alamat email ini
Kode negara (pada saat Anda membuat akun Yahoo! Anda atau ketika Anda terakhir diperbarui)
Jan 12, 2011 | Yahoo Mail
Sportsart 6300 Treadmill Logo
88 people viewed this question
Top Sportsart Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Steven Brandon
Steven Brandon
Sportsmith LLC
Sportsmith LLC
Are you a Sportsart Exercise and Fitnes Expert? Answer questions, earn points and help others
