Question about Bosch 24 in. SHU43 Built-in Dishwasher
How to clean water matrix in SGV3313 - Bosch 24 in. SHU43 Built-in Dishwasher
How do I clean a blocked scuttle drain in 2004 hyundai santa fe?
remove wiper blades and lower windscreen cover drainage pipes should be in far left and right corners also make sure that water is not coming from heater matrix
Jan 28, 2016 | 2004 Hyundai Santa Fe
No heat whatelse could it be
water pump, air lock , blocked heater matrix , three to get you started does the engine over heat, if not then not likely to be the water pump, has the coolant level dropped, if so top up and bleed and open and close temp control for heater at same time , need a helper , do this for ten minutes so the engine is at a good temp ,making sure coolant is topped up, if after all this still no heat i'd suggest having the heater matrix cleaned through or even replaced
Oct 20, 2014 | 2000 Buick LeSabre
Keeway matrix 150
The carburetor needs to be removed and cleaned, water must be in it or some rust from the old can must have got into some of the injectors.
Jun 30, 2014 | 2009 Keeway Matrix 150
My car won't heat on the interior
Air lock in heater matrix, or matrix clogged with sediment. Is water level ok, is coolant clean?
Heater controls malfunction.
Water pump faulty/belt slack.
low level of heat could be thermostat jammed open.
Blower motor inoperative/slow?
Nov 06, 2013 | 2006 Chevrolet Chevrolet Impala LT
Water got inside my 2001 Toyota corolla
Remove the box (ECU), and thoroughly clean it, dry it and retry. Remember to clean its connector pins and plugs. Don't use WD-40, but an electrical cleaning spray like switch cleaner.
Check engine main fuses and all minor fuses.
Repair water leak. Was the leak from the interior heater matrix? If so, then you will need to repair the water leak before replacing any electrical components or ECU.
Nov 02, 2012 | Toyota Cars & Trucks
Heater is very poor
Has the vehicle been run with anti-freeze its whole life? If not, then flush heater matrix.
With vehicle in cold state, disconnect heater matrix feed and return pipes from within engin bay. Turn the vehicle's internal temperature setting to hot. If the vehicle is fitted with climate control, then do this with the ignition in the 'on' position.
Take a garden hose and with low pressure first, try flushing the matrix. If the water pressure is not enough to flow through matrix at low to medium pressure, then a blockage is almost a certainty. If water does not flow at first, then try using a high pressure air-line to force air and any blockage material through the matrix and out of the exit pipe. You can also reverse the flow to blow or flush any dirt out of the other end.
Once all is clean and free flowing, reconnect and fill entire system with a 50-50 anti freeze-water solution.
If blockage cannot be resolved, then replace heater matrix.
If no blockage is present then continue to check heater control switches and wires.
Oct 29, 2012 | 2000 Lincoln Navigator
I have no heat inside the car 825 rover checked the pipes there is heat going in but the outlet pipe is cold is it possible the thermostat is not opening to allow the flow thru the heater matrix
no the water should bypass thermostat, its is more likly that either your heater matrix has an air traped or is blocked from sediment, i would opt to first try the blocked test . undo both pipes that go to the matrix , using a hose pipe connect to bottom pipe on matrix and turn hose on to flush out matrix, continue running until water runs clear not rusty colored, then connect to top pipe and repeat, repeat several times until your happy it is clean, reattach bottom pipe and fill from expansion bottle until water flows from matrix then re attche the other hose, you can also try this on your main radiater . hand book states it should be flushed every 2 years .
Jan 04, 2010 | 1996 Land Rover Discovery
No heat from defrost
SOUNDS LIKE YOU MAY HAVE AIR BLOCK, OR BLOCKED HEATER MATRIX, CHECK FIRST CHECK THE HEIGHT OF THE HEATER MATRIX IN THE CAB , IF ITS HIGHER THAN THE FILLER/EXPANSION TANK. THEN COULD BE AN AIR LOCK, LOOK FOR THE HIGHEST PIPE AND SEE IF THERE IS A BLEED VALVE, IF NOT TAKE BOTH PIPES OFF THE MATRIX FEEDS (TWO PIPES GOING FROM ENGINE BAY TO INSIDE OF CAR, AND FLUSH OUT WITH HOSE TO SEE IF IT IS BLOCKED, AND RECONNECT LOWEST PIPE FIRST AND FILL SYSTYM TILL WATER APPEAR FROM TOP AND RECONNECT RUN MOTOR, AND KEEP TOPIN UP, YOU CAN BY A COOLENT FLUSH SOLUTION TO CLEAN THE SYSTYM OUT
Dec 20, 2009 | 1995 Oldsmobile Achieva
Since i washed my keyboard with water is been acting weired.when i press spacebar it turns out enter so i have to hold ctrl before it becomes space why?
Common keyboards are nothing but a bunch of switches and the currents that flow inside of keyboard are very small. If you 'washed' it as you stated, you have probably gotten moisture into it along with some contaminents you wanted to remove and it is causing currents to flow where they shouldn't.
Don't do this to your next keyboard; if you want to clean it, use a dampened clean paint brush followed immediately by a clean towel.
Never put liquid anything on these, they aren't designed for use while snorkeling.
Standard keyboards cost <$20 and I have gotten them free after rebate so you can shop these pretty well.
Dec 16, 2008 | Computers & Internet
Bosch 24 in. SHU43 Built-in Dishwasher Logo
536 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
