Question about Grohe Plumbing
How to replace the mixer cartridge on a Hansa kitchen faucet mixer
  • 94 Answers
SOURCE: Replace cartridge in Moen kitchen faucet and now
it probably has a plastic cartridge,remove it, and push the center piece out slowly and firmly. wipe this down,not completly this is what carries the wieght of the handle.give this a shot.
Posted on Apr 27, 2010
  • 171 Answers
SOURCE: rohl 3810 faucet nut not engaging threads
Hi murphygm,
I'm Harvey the Master Plumber.
Your problem is: You have replaced a leaking Rohl cartridge in your kitchen faucet, but when you
replace the nut holding down the cartridge, the threads of the nut do not
engage. You have tried to push hard down on the cartridge while you turn the nut,
but to no avail.
Assuming you have the correct cartridge, I find it helpfull to take pictures with my cell (easily deleted later) as I disassemble to make sure I'm getting the new one in exactly right because there are only two reasons why the new cartridge won't go all the way in. 1 It's the wrong cartridge or
2 something's not right. Take the new one out and check that everything is correct, it's easy to make a small mistake. That's it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
  • 127 Answers
SOURCE: Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
Posted on Oct 18, 2009
FixinFax
  • 3085 Answers
SOURCE: need to replace cartridge in single lever moen
Turn off water
Remove the handle with an allen wrench, usually 1/8".
Unscrew the dome with a pair of channel lock pliers with a rag to prevent scratching.
Wiggle out the old cartridge with the channel lock pliers.
Clean all innards with WD-40.
Reverse procedure
Posted on Dec 12, 2009
Testimonial: "Thank you for the speedy reply it was needed at the time because the part was jammed or at least it seemed so."
SOURCE: handle won't stay up
I did the same thing recently, that is replaced the cartridge on my moen kitchen faucet to stop and leak, and I also have the same problem. I called moen back and they sent me another cartridge that was supposed to fit tighter, I suppose. I just put the new one in and it still wont stay up. I'm going to call moen one more time and then I guess I'll have to buy another faucet, but NOT moen!!! Good luck with yours.
Posted on Jul 22, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Dripping faucet price pfister kitchen
    Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
    Jul 25, 2010 | Price Pfister Savannah Two-Handle Kitchen...
    The tap is leaking it appears at the bottom of the tap where it meet the sink it is a hansa single handle with vegatable sprayer with a ceramic cartridge
    Hi, there are flexible water pipes that scew into the bottom of the tap, one of these could of come loose; try tightening, or the washer may need replacing.
    Hope this helps
    Jul 21, 2010 | Blanco Classic Single Handle Faucet with...
    Hansa mixer
    If it is a single handle faucet remove handle it has a dial that has a stop on it you take it off and put it back on turn it sigthly to one side til you get it back to desired position. it may need stop at top postion to get handle in right place when off.
    May 01, 2010 | Plumbing
    How do I get to the valve cartridge to replace it?
    how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
    Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    I can't get the mixer valve out
    take a good look at top of faucet,w/handle assmb,off there is a small brass/cooper colored,horse shoe shape clip that must be removed to remove cartridge.i think that's your after.
    Feb 24, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Jan 12, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    I have a Hansa pullout kitch faucet that leaks out of a hole in the back when faucet is shut. Is this a bad backflow preventor and how do I fix it? I can't get the spout off to access the body of the...
    I can't get the spout off to access the body of the faucet.
    I have the same problem. Have you had any luck?
    Sep 05, 2009 | Hansa Home
    Mixer tap in kitchen hard to turn on and off
    It is a simple matter of on o-ring being out of align. REmove the valve cartridge fromthe faucet by first shutting off the water at the shut-off valves. Then remove the handle by means of loosining the set-screw on the front side of the handle. Then remove the valve cartridge by unscrewing the packing nut that surrounds the shiny stem that the handle was connected to.
    Once that is removed then the cartridge will slide out, probably with a bit of force. Replace the o-rings and any other washers that may be there and coat liberally with plumbing grease before re-installing. This should fix you right up.
    Bring the old cartridges, rings and washers with you to your home improvement store to make replacing easier. Should be about $15-$20.
    Good luck.
    Apr 25, 2009 | Grohe Classic Kitchen/Bar Faucet ...
    Plumbing Logo
    2,016 people viewed this question
    Top Grohe Plumbing Experts
    john h
    Craig Butler
    Craig Butler
    Mike
    Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
