Question about Car Audio & Video
Hi, i changed my battery and then turned on my radio afterwards and its asking for a code. i've got the code from renault but my display shows CODE and none of the buttons function. What do i do?
    Sergeant:
  • 170 Answers
Try the buttons Vol+ Vol-
and stuff to enter the code
Posted on Jul 31, 2010
Renault grand scenic espace radio shows ERROR code
Was the battery power lost to the radio?
Jan 18, 2017 | Renault Cars & Trucks
Tip
How to Enter a Renault Radio Code
This tip deals with instructions on how to enter the security code in your Renault car radio and assumes that you already have the correct code for your radio. It also describes what to do if your radio will not accept a code after too many incorrect entries and appears to be locked.<br /><br />
If you happen need a code for your Renault Radio I can also recommend this site which is cheap, fast and accurate and will email or text the code directly to you.
1) You must have 0000 showing on the display before the radio will accept the code.<br /> <br />If CODE or ERROR is on the display you must leave the radio switched on with the key turned to the first point in the ignition that activates the radio until the display changes to 0000.<br /> <br />This can take over an hour depending on how many wrong code entries have been made. It is very important to leave the key in the ignition turned to the accessories on position and the power must not be interrupted or the wait period will be reset and start all over again.<br /> <br />2) When you get 0000 on the display, use the steering stalk and <b><u>not</u></b> the radio to enter the code. Turn the thumbwheel on the stalk until the number changes on the display. Accept each number by pressing the satellite button on the bottom of the stalk before moving on to the next one.<br /> <br />3) When all four numbers are entered on the display you must press and hold the button on bottom of the stalk until you hear a confirmation beep. This may take up to 10 seconds.<br /><br />4) Enjoy your sounds!<br /> <br />Hope this tip helps. Please do leave a vote for it and thanks for using FixYa.<br />
on Nov 17, 2010 | Car Audio & Video
What is the radio code for renault senic Model 22DC279/62P See this picture Thanks
First question I will ask, Did you replace the internal battery? Then what year is your Renault? Always provide the most information such as year.
Most code that worked for others is 0515
Yet I have a list of codes:
The codes I choose are for years 2001 -2004
May I suggest that you disconnect the negative side of the battery for five minutes. Then reconnect. This procedure reset the main computer which in turn might reset all codes program.
Feb 01, 2015 | Renault Cars & Trucks
Battery went flat so need radio code for renault megane
With the car, comes a plastic "infocard" with the radio and alarm codes. If you lost the card or didn't receive it with the purchase, you can ask for the code to the radio manufacturer, they'll ask you the serial number of the radio and the car and they'll send you the code.
Jan 12, 2010 | Car Audio & Video
Hi, my year 2001 kangoo's radio code is locked. I have the actual code now, but the radio keeps displaying ''CODE'' instead of ''0000'' on its LED, can anyone help by telling me how to get to the ''0000''...
On most Renault / Philips radios the display should show CODE before entry  (see below)
Make sure you are entering the correct code.
Get it checked by POSTING ANOTHER QUESTION
quoting the 14 character Serial Number beginning with RN++++++++++++  and also the Renault Security Code found on the radio casing label
Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [¬ ] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [¬ ] button for up to 10 seconds to store the code
Oct 20, 2009 | Philips Car Audio & Video
Need car radio code
your best chance of getting the code is call your local dealer or someone who deals with your model car. You should be able to give them your vin/serial number and they can look up the code. The code should be in your glove box with your owners manual or with the papers that came with the vehicle but if not your going to have to talk to someone from tech services at a dealer.
Feb 17, 2009 | Car Audio & Video
Renault Megane Scienic
hi you have to look at the car documents, the code is wrote on a special sheet or little card named «radio pass or radio code», if you don't have this paper you have to go to a Renault dealer to ask the radio code with your car serial number.
i hope this helps you
sserpentio
May 15, 2008 | Radio Communications
Car radio code
ok i dont know if this helps but i looked up some info on getting your radio code back
i dont know the codes off hand but this is what general consences says
"if you look on the right hand side of the radio, you will see a four digit code beginning with a letter. it is usually located near a bar code, and sometimes it says the word 'security' by it."
also Renault dealer can find out the code for that radio.
i copied and pasted this from a friend from the sterio installation bay at best buy
hope this infor helped
May 01, 2008 | Car Audio & Video
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
