Question about Sebo X4 Bagged Upright Vacuum
My sebo x4 extra does not start. There is power but no warning lights are flashing. When I turn the vacuum on there is a continual clicking/buzzing sound.
  • 19,396 Answers
Hi.
Eeither motor or servo motor with gear box is seized. Testing is done energizing the motor. Test and repair must be done by a technician. Call the number listed on the owners manual to contact a qualified repairer.
See: Parts List and schematics SEBO X4
Posted on Jul 31, 2010
Orange spring will no longer hold cleaner in upright position.
You may need a replacement spring just a guess so here's the list of replacement parts with prices best of luck! Spare Parts AUTOMATIC X4 SEBO Vacuums Online Store
Jan 07, 2016 | Sebo Automatic X4 Extra Upright Vacuum...
How do I replace the front bottom plate on my Sebo X4 Extra vacuum cleaner, this is the metal/plastic plate on the front base of the bottom of the cleaner (no visible fixings)
With the power head cover removed, you will see tabs on the inside of the chassis inline with the front bottom plate. Simply pinch the tabs with some needle nose pliers and push. I have included a link to the parts list as well as the front bottom plate. You will see by the picture what those tabs look like and how to remove the front bottom plate. 5411 HG Front Bottom Plate Windsor Sensor S12 XP12 SR12 86138280 allstar... http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Dec 09, 2014 | Sebo X4 Extra Bagged Upright Vacuum
My Sebo x 4 Extra is showing all the four lights at once. It also is rising and falling all the time on the same surface. Carpet or hard floor. It went through a spell of cutting out after several sec
If all 4 lights on the indicator panel are on at once that would usually be caused by a bad PC controller board. If your vacuum is under warranty, this should be covered. If not, I have included a link to this part as well as a parts list for your reference. This is an easy part to replace and requires only a Phillips head screw driver. http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf 5740 ER Computer Controller Windsor Sensor SR XP 86140160
Dec 08, 2014 | Sebo X4 Extra Bagged Upright Vacuum
I have a sebo x4 , when I switch it on the red lights flick on and off and nothing happenes
The red lights should flash very quickly upon vacuum start-up (normal). If the motor is not turning on there is likely a problem with the motor or power supply board. The lights flashing does indicate that you are getting power to the PC control board. If your vacuum is under warranty, this would likely be covered. I have included a link to the parts list for your reference. http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Oct 05, 2014 | Sebo X4 Bagged Upright Vacuum
My Sebo X4 does not switch on, when powered up two red lights flash momentarily. There was a buzzing from the black box underneath but that has now stopped. I changed the bag yesterday as it said it w
Your red lights flashing momentarily is normal start-up. The fact that your servo motor is operating tells you that you are getting power. If the vacuum motor does not turn on, you likely have a problem with the motor itself or the power supply board that feeds power to the motor. These items should be covered under warranty. However, if your vacuum is outside the manufacturers warranty, you can replace either of these parts fairly easily with only a phillips head screwdriver.I have included a link to the parts list for this machine. We do stock both parts. http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Sep 24, 2014 | Sebo X4 Extra Bagged Upright Vacuum
The brush on sebo x4 will not go up or down. Red check brush light briefly flashes
You should try to replace your SEBO roller brush with the softer one. The part number is SEBO 5010GE Genuine Sebo product
Jan 11, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
My sebo x4 bagged hoover is losing power, what could the problem be
Is it a Sebo , or is it a Hoover. It can't be both . "losing power" ??? Motor comes on and off ? or stops picking up ? Be more specific please.
Oct 20, 2013 | Sebo X4 Bagged Upright Vacuum
I need a new set of instructions for my sebo x4 extra upright cleaner
you will have to call sebo or the dealer you brought it from to get manual
Aug 27, 2010 | Sebo X4 Extra Bagged Upright Vacuum
Sebo X4 Bagged Upright Vacuum Logo
347 people viewed this question
Top Sebo Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
