An actionscript error as occurred error #1009
Reset hp amd to factory settings
The particular error code (1009) is a generic error code for 'interrupted' for system recovery. Meaning, somehow, the recovery process was interrupted. For most HP machines this can be a simple as a few keys being pressed on the keyboard, a power interruption, bad disc, faulty hard drive, or some other form of read error during the process.
Unfortunately, the error code isn't specific enough to give you the best possible troubleshooting information, but I shall try to help as much as I can.
If you can provide the exact HP model number, I can provide a more specific solution for you; but, if you have a Desktop or Notebook computer that uses F11 (on start-up) to enter into system recovery, then you can do the following:
  1. Click Next when Welcome to Recovery Manager displays.
  2. Select No and then click Next when Microsoft System Restore displays.
  3. Select Yes and then click Next when System Recovery displays.
  4. Select the appropriate item (backup file or not) and then click Next when Recover your computer to original factory condition displays.
  5. Allow the system recovery process to complete.
NOTE: The PC will appear to FREEZE for several minutes (it can take quite a while depending on the Operating System you are installing), so do not turn off the power to your machine. If the machine stays frozen for longer than several hours, then chances are the hard drive is having issues, or the recovery image cannot be recovered.
If you have tried the above steps, and you are still failing with Error 1009, it usually points to a failure with the recovery medium (image on a CD, or image on the hard drive), or that the hard drive it is restoring too is having a write/read error. This can be worked around if you have a USB recovery media you can use.
If you have access to another computer, you can create a recovery key on a USB stick to boot your HP computer from, and then kick off the recovery process that way.
Those options, however, shouldn't be taken unless you have tried the above solutions first.
Dec 23, 2013 | HP Pavilion Computers & Internet
I want to learn actionscript.
Well ..There are lots of actionscript tutorials outthere on net...You can find them in the torrent world ..go here > and search for actionscript...
Apr 07, 2009 | Macromedia Flash Professional 8.0 Full...
How to download action script in pdf formate?
These are some links include learning Actionscript 2.0 for Flash MX and with source of actionscript 2.0 in PDF format, I hope it could help you.
Good luck
Feb 25, 2009 | Macromedia Flash MX
Flash action scripting 3
you should learn actionscript 3! :)
Actionscript is a object-oriented scripting language.
It is based on ECMAscript (Javascript), so if you know Javascript, it could be easier to understand and learn actionscript. But there are differences, that come with flash. Using scenes and time-lines to handle graphics is something specific of actionscript. on adobe website, there is a good library with information on how to use actionscript. Best is to learn it from a book.
Apr 23, 2008 | Macromedia Flash MX
Flash Action Scripting
I might have something for you:
[Getting Started with ActionScript]
And over here are some more:
[ActionScript Tutorials]
I hope this helps, please rate.
Jan 29, 2008 | Macromedia Flash MX
we want to know what is _self, _parent, and things related to this programm?
Oct 03, 2007 | Macromedia Flash MX
Scared of actionscript
Have a look to see if these fellows can help you?
Sep 13, 2007 | Macromedia Flash MX
My file showing unexpected error while opening.
they might help
Sep 12, 2007 | Macromedia Flash MX
using fs command you can make your flash presentation fullscreen the code is given bellow this.fullscreen_btn.onRelease = function() { fscommand("fullscreen", true); }; this.unfullscreen_btn.onRelease = function() { fscommand("fullscreen", false); };
Sep 01, 2007 | Macromedia Flash MX
Computers & Internet Logo
David Payne
David Payne
