GCET1031FS will not drain and spin - Washing Machines
  • 487 Answers
Check the filter and see if there is nothing in the pump. this should normally work
Posted on Apr 24, 2008
Its wont spin and drain my modyl mwa-6000dp
Bad or clogged drain pump. It waits and senses water level to drop before it will spin once in drain spin mode
Jul 04, 2016 | Washing Machines
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Washer does not spin and drain properly
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
https://www.youtube.com/watch?v=k41abYwM9WY
Jul 12, 2013 - Uploaded by ApplianceVideo.com
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
I have a kenmore elite electric washer Model #229 42 101 CM 4905520 the spin will not spin on ocassions and it only hums and the tub does not turn. when it does spin does not spin all the water out the...
Hi.
From description it looks like a drain problem. Check drain filter, drain hose and pressure switch.
Check motor, motor control unit, drain system and pressure switch. Start checking from drain system and pressure switch. The pressure switch determines water level. The timer checks the output from pressure switch to decide that drain is complete and advance cycle to spin.
Check also the position of the drain hose. Ensure that the height is as specified by the manual or you get siphoning and drain does not end.
Here a page about drain/spin problem.
Start checking drain and pressure switch, then test the other parts.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 09, 2011 | Kenmore Dryers
Will not drain. it does'nt look like its spinning very fast.
The washing machine not draining water.This problem is related to few possibilities. 1) The drain pump is got loose to the drain hose. check the connection from drain hose to drain pump. 2) The drain is blocked by any thing.Like cloth or any thing like metallic nails or coils etc etc. 3) The drain hose is got blocked./The drain hose is not letting the water to enter the drain pump. In most of the cases the drain pump has to be removed and checked for any kind of blockages.Also if the machine not draining can effect the spin cycle.But other possibilities for no spin or slow spin are faulty or broken motor coupler or weak spin motor.The motor coupler and motor both can be possible,if the drain pump and drain hose both checked ok.This will clear the fault. ----------- Keep updated with any more queries.Thanks,.
Oct 14, 2010 | Washing Machines
Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Jan 31, 2010 | Asko W6021 Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Wont spin or drain it only only hums when turn on
Either your drain pump is bad or something is stuck in it.  It won't spin until it drains so fix the drain pump, and it will spin.  You should be able to get at the drain pump by taking off the bottom panel, or back panel.
Dec 19, 2009 | Kenmore HE2 Plus Front Load Washer
GE WCXR1070T5WW washes OK but won't spin and drain
It depends on what type of pump it has.If its an electric pump it could drain without spinning,but if the pump runs off the same motor as the washer then the motor has to be running for it to drain,and it will probably spin.There is no guarantee,but the switch that closes when you shut your washers lid is probably bad.Try bypassing this switch,and see if it spins.Please if it spins replace this switch.It is a safety measure that you should really want to keep intact.
Jun 05, 2009 | Washing Machines
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
