Question about Sony KV-27FS13 27" TV
I connected my XBOX 360 to the component cables on the back of the TV. The Image looks beautiful, but there is no sound coming out of the Television. On the other VIDEO 1 which is the Composite, there is sound? Is there something wrong with the settings of the TV?
4 Suggested Answers
SOURCE: Component Video Problem
The problem is not with your tv it's with your dvd player. You have to go into the setup on the dvd player and change your output setting to component.
Posted on Feb 05, 2007
SOURCE: Non-HD picture issues
Looks like u MAY have a convergence problem. There are 2 convergence settings. One for standard definition and one for HDTV. Go into your menu while in the HD mode and adjust it. Refer to your owners manual for the procedure on your model.
Posted on Feb 26, 2007
SOURCE: Sony KV-32FS12 Component Video 4 Has A Wavy Picture
sounds to me like the differnence between watchiing in progressive and interlace. these older tube tv's are not capable of displaying a progressive scanned image. like the first dvd players. check your video out settings on your ipod to make sure its an interlace output.
Posted on May 04, 2009
I recently got a 51h83 toshiba tv. When i try to hook up my xbox 360 with the hd component cables in the back i get sound but no video. Please help.
WITH THE TOSHIBA 51H83TOSHIBA TV YOU CANT HOOK UP HD CABLES TO THAT SPECIFIC TV FROM YOUR XBOX 360 BECAUSE THE DEVICE ISNT EQUIPPED WITH THAT CAPABILITY
Nov 16, 2016 | Toshiba 51H83 51" Rear Projection...
How do I hook up Xbox 360 to this TV? I have no clue where all the plugs go in the back
component leads from xbox to component in on tv
Xbox 360 Component HD AV Cable
http://support.xbox.com/en-AU/xbox-360/system/connect-xbox-360-console-tv
https://www.youtube.com/watch?v=JlE2zHSoQmE
Nov 20, 2015 | Sanyo DS31590 31" TV
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
How should I hook up my xbox to the back of the television using the red, white, and yellow wires? It is hooked up but I am not getting any audio. Thank you.
First make sure your video cable is set to TV not HDTV
Then plug the 3 RCA cables into the color coded slots on the TV. Make sure you aren't using the red cable from the component RGB but are using the red cable for sound (next to the white one).
Then, if you still have no picture, start the console using the controllers Xbox button and hold "Y" and "RT" until the console restarts. this will reset the video settings on the 360 to default.
Follow this guide if you get confused:
http://support.xbox.com/en-us/pages/xbox-360/how-to/audio-video-devices/connect-xbox-360-console-tv.aspx
and for the video reset about halfway down the page:
http://support.xbox.com/en-us/Pages/xbox-360/troubleshoot/xbox-360-top-issues/tv-or-monitor-screen-is-blank-while-connected.aspx
Mar 30, 2011 | Video Game Consoles & Games
Light is on and green but no video coming out to television what might be the problem.
Typically, this problem occurs if the audio/video (A/V) cable is not connected correctly, or if the A/V cable is faulty.
Solution 1: Set the television or monitor to the correct input
Make sure that the TV or monitor is set to the correct input for the console. Check the TV or monitor's manual to see how to configure the video inputs, or try to use the console on a different TV or monitor.
Solution 2: Connect the A/V cable securely
Sometimes, you can insert the A/V cable far enough to prevent any red lights from flashing on the Xbox 360 console but not far enough for the console to transmit images or sounds to the screen.
Solution 3: Switch the Xbox 360 Component HD AV Cable to the correct setting
Make sure that the TV/HDTV switch on the cable is set correctly.
  • For standard-definition TVs with only the yellow connector plugged in, set the switch to TV.
  • For high-definition TV or monitors with the red, blue, and green connectors plugged in, set the switch to HDTV.
For more solutions, check this web page.
Oct 09, 2010 | Microsoft Xbox 360 Console
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
Picture but no sound
OK, I don't have a 360, but are you sure the audio cable is connected, in the correct jack, and pushed all the way in? Sometimes it looks like the jacks are all the way in, but they are not. Thus, no audio. You could also try using Component 2 if that is an option on the TV. Maybe Component 1 ports are bad. Hope this helps.
Jan 24, 2009 | Mitsubishi WD-62327 62" Rear Projection...
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Sony KV-27FS13 27" TV Logo
18 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
