Question about Garden
I bought a used 5500 pump and filter . On reciept I discovered two problems. THe pump would not run and seemed to be siezed . The bioforce filter also appears faulty . On inspection the uv bulb was blown and when the housing was opened up it had rust inside . It is my belief that these items were out of water for a while before I bought them .Is it viable to attempt to fix these items.
  • 10,865 Answers
Hello. Honestly, I do not recommend attempting a repair. The parts are pricey, there is no returning parts; and if, in the end, you can not get it to work properly you are stll without the pump and filter. J.
Posted on Jul 31, 2010
Hozelock bioforce revolution filter
yes you can buy them
http://www.hozelock.com/our-products/aquatics/bioforce-revolution/
May 19, 2016 | Hozelock Garden
I got the same soundsystem and it does the same thing,makes those thunder noises,i bought it over ebay...what should i do now,i dont have a receipt...please someone help me .
Hi Stefan,
Sad to say that you can't replaced the unit without the reciept, this is the common problem when you buy a refurbish/recon product. This symptom indicated that you have a problem in the output amplifier stage. Isolating the faulty needs the skills of an expert. All you can do now is to look for a qualified technician to troubleshoot the problem.
Hope I helped you.
Thanks for using Fixya.
Mar 06, 2011 | Logitech Z-5500 Computer Speakers
My water pump doesn't work. Our unit is nearly 6yrs old and I have installed a new battery and fully charged it. I have removed the filter on the pump and rotated the impeller. I discovered that the fuse...
There is a wire that runs to the connection of the impeller pump to the unit, my guess is that it is probably touching the side of the copper element and has melted. The other possibilities are that the tiny circuit board behind that connection has come off or the connector at the other end (near the main circuit board) has detached somehow. Hope this helps
Aug 29, 2010 | Coleman Hot Water On Demand
Power shuts down
Sounds like a power supply issue.
If you call intex and tell they you have a power supply problem and a reciept within two years. they should ship you a new one.
Jun 23, 2010 | Intex '10 Saltwater System Pool...
I have a hozelock bioforce filter that i have
Sounds like the the bypass valve may have been disturbed and so water is coming out of the air bleed hole.
I suggest you turn off the pump, remove the bypass valve cover (clear part that quater turns off bayonet style), extract the red valve (careful not to lose spring), rub some pertoleum jelly (vaseline) around the seal of the red valve, replace spring, red valve, press the red valve a few times to ensure it returns, replace clear cover and turn pump back on.
This should ensure the valve is working.
May 23, 2010 | Hozelock Garden
'87 Subaru GL, fuel delivery
You say the pump is running and you have spark - but are those working when the engine stops?
Discovering those things is probably the first step towards diagnosing the trouble.
How about the possibility of a foreign object in the fuel tank periodically cutting off the supply? It isn't an unusual thing...
Monitoring the fuel pressure while you drive is one way of discovering the truth.
Feb 13, 2018 | 1987 Subaru Gl 4WD
Servicing a koi pond filter - Hoselock Bioforce
You can backflush it. Just swap the intake hose over to the outlet hose, then put the outlet hose on the intake. Don't forget to remove the outlet hose from the pond. Run the pump for a minute or so. Then switch the hoses back.
If it's real dirty, turn the pump off and take the outlet hose out of the pond, then undo the clips on top of the filter and lift of the top, then clean the sponges. Re-assemble.
Feb 20, 2009 | Garden
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
