Question about Karcher K2.26 Electric Power Washer
Does not give a continous high pressure flow cuts in and out
I have an electric powered karcher 6.91 after i have connected the hose turned the pump on after i have checked the water flow and made sure the filters are clean all i get when depressing the nozzles trigger is an intermittent flow off high pressure.This on and off again is about every 10 seconds?
  • 10,865 Answers
Hi. Water flow may be restricted to the pressure washer.
Check that all hoses are free of kinks, leaks, or blockage. Make certain all hoses and fittings are connected properly. Make sure to open the faucet/spigot to full force. Set the spray wand to high pressure.
Clear any debris from the nozzle. If the nozzle has even a little bit of dirt in the tip, it may cause enough obstruction for the pressure washer to pulsate. If your pressure washer came with a nozzle cleaner, use it to clean the tip. If not, you can use a pin or paper clip to clear the nozzle tip of debris that may have become lodged in it.
If these have been checked and the washer is still fluctuating from high to low pressure there may be air trapped in the pump. To bleed the pump of any air, turn the machine off and disconnect the high pressure hose and trigger gun from your power washer. With only the garden hose connected to the machine, turn on your water source and allow water to run through the pump of the machine for 20 or 30 seconds. Turn off the water and connect the high pressure hose and trigger gun and try using the machine again.
Posted on Jul 31, 2010
  • 700 Answers
That is sure signal of insufficient water supply!
try easy solution first:
make sure that your mains is fully open, that tap on whihc hose is hook up is fully open and hose is of "decent" diameter to allow sufficient flow.
if above solution do not work then you need to make another, more difficult arrangement:
prepare 20litres pressure tank with inlet connected to mains and outlet by short hose to power washer, fill it with water from mains, keep it under mains pressure and use karcher power washer normaly. this will solve water supply problem. twenty litres will last about 2min, because it is re-filled, under standard pressure therefore it will last about 3min...
third possibility is to stop washing...
if you find my advice helpfull, please do not hesitate to left the comment and vote for me, thanx!
    Problem Solver:
  • 18 Answers
If when you have the trigger gun pull or spraying and your pressure goes up and down you may have a clogged nozzle the is overpressure your pump check your nozzle or you can have wrong size nozzle.
Posted on Aug 25, 2010
  • omark Sep 11, 2010
    Solved my problem
    Omar
Tip
Winterizing your Pressure Washer
Once again it's that time of year to get your pressure washer prepared for the cold months ahead. Proper winterization will protect your pump from the freezing of excess water in the pump over the winter. There are many ways to winterize your pump; we like to classify it as the good, better and best.<br /> <br /> Good: (Gasoline powered) Leaving your machine in the off position with the high pressure hose disconnected pull the recoil rope 4 to 5 times or until you don't see any more water coming out of the high pressure end of the pump. (Electric powered) Disconnect your high pressure hose, turn the machine on for 5 to 10 seconds or until you don't see any more water coming from the high pressure end of the pump.<br /> Better: If you have a air compressor around the house, hook the air line to the garden hose end of the pump and blow the water out until you don't see any more water coming out of the high pressure end of the pump.<br /> Best: Purchase Karcher's Pump Guard, follow the simple directions that come with the product. This product is specially formulated to keep your pump from freezing, corrosion, premature wear, adds lubricant to the valves and seals to prevent sticking in the spring. You can usually get 2 or 3 uses from one bottle of Karcher's Pump Guard. <br /> <br /> <a href="http://www.wmpcs.com/blog/?p=63">Visit this link to read more</a>
on Nov 01, 2010 | Garden
Karcher electric power washer480 .pump runs on when trigger is released there are no leaks . Also i can not turn machine off at the main switch.
If you are unable to shut off the pressure from the wand, there may be an issue with the unloader valve that is stopping it from switching into bypass mode when the trigger wand is released. The unloader valve is designed to respond to the spike in pressure created when the trigger wand is released, and to divert the flow of water coming from the pump to bypass the pressure hose and flow back into the intake end of the pump. If the unloader valve fails to switch into bypass mode, water may continue to flow out of the trigger wand. This may also cause damage to the wand. If you are unable to shut off the pressure from your power washer, stop the engine and discontinue use immediately. The unloader valve should be removed and possibly replaced if found to be malfunctioning. The inability to stop the flow of high-pressure water from the wand can be dangerous and should be fixed before continuing to use the machine.
Dec 28, 2017 | Karcher Garden
Karcher high pressure washer has very low water pressure
make sure that the hose connected to the pump is not kinked and the flow is adequate for the pump need
Oct 30, 2016 | Karcher Garden
The garden hose was used to siphon water from a dirty pool. The hose was connected to the pressure washer without cleaning out the hose and turned on. After a few minutes he couldn't get pressure from the...
Hello, check the hose connection on the pump. There is generally a screen there to prevent dirt from entering the pump. Clean off this screen and all should be well.
joe
Jan 27, 2011 | Karcher K3.68MR Electric Pressure Washer
Australian Karcher 2.91 intermitant start
Under the top cover there is a micro switch that sometimes dislodges
This switch is for auto cut off when you release the trigger
Jul 27, 2009 | Karcher K2.26 Electric Power Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Leaking power washer hose
most auto stores have high pressure connectors and or machines
to make these connections. Also there are radiant heat connectors
that may or may not fit.
Jul 26, 2008 | Karcher 2500 PSI Pressure Washer
Gas pressure washer
I have the same problem with a Karcher 2400hh.
Go to: http://www.wmpcs.com/index.php?main_page=page&id=14
they have the best diagrams and answerss that I have found.
May 02, 2008 | Karcher 2500 PSI Pressure Washer
Karcher K2.26 Electric Power Washer Logo
2,188 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
