Question about Refrigerators
Hello there, my mini fridge isn't working, dont know why. it doesnt get cold or anything.
  • 17,130 Answers
A fridge without cooling and the finger points out to the compressor, the motor capacitor and the contactor. So shut off the fridge and put it on to check if the compressor works . If there is no cooling then you must check for the gas pressure and then for the performance of the compressor. If so then get help to test this out and to confirm. If the compressor needs service get quote for service with warranty, then decide accorrdingly. Hope you try this out. Good day
Posted on Jul 31, 2010
My chef mate mini fridge isn't cold
buy a new one cheaper than repair
Apr 30, 2012 | Refrigerators
Galaxy mini fridge stopped working
The thermostat, which is also an ON_OFF switch has failed (@ 99% probability).
No, the little fridge doesn't have a pressure switch to turn the compressor off when freon is low. And no, auto freon is the wrong kind and it wont work in the little fridge. The freon that your little fridge uses is the stuff that all the fuss has been about (with the ozone layer), so it is not sold to appliance owners but only to licensed techs.
If this is helpful I hope you'll take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Koolatron Mini Fridge Compact Refrigerator
Hello. My Bosch dishwasher just isn't turning on again. It was working fine and now I cant get anything to turn on. Thank you
Make sure you have power to the machine. Plug in something you know works into the same power point as the dishwasher. If it works, then you will know the dishwasher has failed. If it doesnt, then check your meter box, switch, RCD etc.
Jul 26, 2011 | Bosch Dishwashers
Danby mini fridge model dcr054w has stopped working the thing in the back is extremly hot and the fridge no longer gets cold, i turn the knob and i hear a click but the fridge doesnt actually turn on. the...
This is a problem with the 'Motor Run Capacitor'
What you suggest is exactly what happens when this part fails.
Unplug - and look carefully around the connections to the compressor - there should be a cylinder with 2 connections on it. Read what value it says (like 250V 50pf) - and order a replacement from a parts store.
Fit it any way round - it doesnt matter.
plug back in and should work 100%
Cost about - $5
Dec 27, 2010 | Microwave Ovens
Sanyo mini refridgerator won't get cold
This sounds to me like your fridge might be in defrost mode. There should be a switch up toward the top of the fridge near the cold setting. It's not always very visible, but feel around for a little round hole. There should be a small, plastic rod sticking out. Push it back in. (If it's out.) If this is the problem, you should hear the compressor turn on and the fridge should start cooling off again. If you still have the owners manual, it'll probably point you to its exact location.
I hope this helps! :)
Jul 23, 2010 | Sanyo Refrigerators
Hello, my daewoo fridge freezer has stopped working. The light comes on & it sounds normal, any suggestions?
SOMETHINGS LIKE THAT YOU CAN UNPLUG FOR A WHILE THEN PLUG BACK IN AND THEY WILL MAGICALLY WORK AGAIN, I GOT A NON WORKING MINI FRIDGE FROM CRAIGSLIST AND THE GUY SAID IT DIDN'T GET COLD, SO I ASKED HIM SOME QUESTIONS ABOUT IT AND HE ANSWERED THEN AND I ENDED UP TAKING THE FREE MINI FRIDGE HOME , ALL I DID TO MAKE IT WORK AS UNPLUGGED IT FROM THE WALL AND CHECKED ALL THE CONECTORS ON THE BACK NEAR THE COMPRESSOR, I DID THAT THEN PLUGED THEM BACK IN AND I HEARD THE COMPRESSOR START TO KICK ON AND WAS LIKE YES AND NO I HAVE A GREAT LIL MINI FRIDGE TO KEEP SODA FRESH AND CHILLED , SOMETIMES I GET A POP TO EXPLODE IN THE FRIDGE BECAUSE IT IS SO COLD INSIDE
Jun 25, 2009 | Freezers
Bottom not cooling
the blower is broken or frozen.you need to defrost and clean it.or the air passages are clog.
May 08, 2009 | Dometic RM2620 Refrigerator
My Haier Mini Fridge comes on but keeps nothing cold. I defrosted in August and it worked for awhile and now it defrosted on its own and no longer gets cold.
This could be a bad defrost timer. See if the compressor is working. If it isn`t or only works sometimes. The defrost timer could be bad. When the frig goes into the defrost cycle, turns off the compressor. It may failing to turn the compressor back on after the defrost cycle. Since it stopped defrosting at one point and started again, the defrost timer may be bad. Let me know if this was any help or if I can help any farther.
Nov 12, 2008 | Haier Refrigerators
Doesnt get cold
You have the start of a defrost problem.  On this model they are know for bad connections to the defrost heater.   Read this article on defrost issues.  It will explain in detail what to do to repair your machine.
Thanks, Bill
Nov 09, 2008 | Frigidaire FRT15B3A Top Freezer...
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
