Question about Dishwashers
I like to to remove the bottom cover and how can i get anexpolen viw of the dishwaser
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post back with the manufacturers name and model no# of your Dishwasher so that I can assist you further.
Thanks
Rylee
Posted on Aug 07, 2010
How can i change the saying from kilometers to miles
From the GPS menu select settings. At the bottom of the screen select the right arrow to viwe other options. Select the Icon called Regional settings. There you can set miles and your time display preferences.
Mar 09, 2012 | Sylvania SGPD430 GPS Navigator
No power no lights , worked fine 3 days ago
You may have a wire problem where the house wire hooks to the dishwaser wire.you will have to take off the bottom panel and check. Please be sure to turn off electric before removing the panel.
May 29, 2011 | Maytag Dishwashers
I am getting a F 1 code on my dishwaser. I hit power to shutt off but it just comes back on and blinks F 1
This video will aid you in you F&P dishwasher repair.
http://www.appliancerepairlesson.com
Feb 09, 2011 | Fisher and Paykel 23 in. DD603H SS...
Viwe cam pro pk 335mb dowmload
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 23, 2011 | A4tech Viewcam PK335 Webcam
My LG Dishwaser LDS4821 all of a sudden has been making a very load noise after a few minutes. This has been happening the last 3 times I have ran it. (also ran it empty, noise is still there.) Is this...
First, remove the sump cover in the bottom of the tub to check if any object (like a part of a broken glass or plate) is being knocked around by the impeller or hard food cutter blade. (Note: The screw on the end of the motor shaft has a left hand thread) If nothing found there, then continue on to replace motor by removing dishwasher from cabinet and laying it on it's side to access motor. (sometimes bits of the permanet magnets in the motor break off, causing noise)
Sep 25, 2010 | LG LDS4821 24 in. Built-in Dishwasher
Le indication, stopps shortley after cycle starts
LE indicates a problem with the wash motor. I've replaced mine twice now. Check to see if something has the pump locked up first.
Motor can be replaced by turning unit on its side. Motor is on the bottom. First take off pump impeller from inside the dishwaser (left hand thread on screw). Turn unit on its side and remove cover. Motor is the one in the center of unit. LG part# 4681ED1004A. This motor can be ordered from repairclinic.com.
Nov 02, 2009 | LG LDF6810ST Stainless Steel Built-in...
Water not draining in the bottom of the dishwaser,no power at all
if you have a row of buttons on the left side for heat cycles check them a shorted switch will cause a loss of current situation so that the drain solnoid wont activate
Oct 12, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
Disherwasher fills with water but will not spray
Mine did the same thing; cycled through without any actual washing by the spray arms. pulled the sump and found a piece of broken glass was jamming the impeller. Might have been able to remove this glass by removing the volute cover and exposing the impeller while the sump was still in the machine, but that's hindsight.
Jul 25, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Dishwasher will not drain
MY BOSCH EXXCEL DISHWASER WONT DRAIN?
Dec 17, 2008 | Dishwashers
Quiet Dishwasher no longer quiet
Hello. The drain motor is what runs at the beginning and end of the cycle. You can take off the drain impeller cover, which is on the left side of the sump area under the filter screen. You will need a torx head screw driver which can be bought at any hardware store. The tip kind of looks like an astorics/star. This may be hard if you don't know what you are looking for. Any way take off the cover and see if something is hitting the impeller. If not then you will need to replace the drain motor, which can be removed, not very easily though, from the bottom front.
Warning: It can be hard to get the motor to install properly with out it leaking. You will need to make sure that the "O" ring is properly installed onto the the pump and you may need to put some liquid soap on it (the "O" ring) to keep it from binding.
Mar 17, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
12 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
