Question about Boating
Wiring diagram vn 3.8 holden
Hi, im fitting a holden 3.8 vn motor into a jetboat, can anyone help me find a wiring diagram that allows me to run the motor out of the car?
MrLard
  • 94 Answers
SOURCE: Anyone might know the wiring diagram for the cdx c680
does the harness look like this?
Posted on Apr 24, 2007
night71
  • 328 Answers
SOURCE: jenson mercury 4000
Here is one that should  work
http://www.audiovox.com/manuals/owners/JPA600D_1000DQuickStart_121205.pdf
Posted on Oct 29, 2007
SOURCE: wiring diagram
nae luck haha
Posted on Oct 26, 2008
  • 261 Answers
SOURCE: heater blower motor wiring diagram
replace the bolwer motor relay mounted on the fire wall the relay is stuck in the on poition.
Posted on Dec 07, 2008
SOURCE: Security Code for Holden Vectra
I rang my holden dealer, they say it will cost $16 and they just go on the internet to look it up. Thats what i'm doing now. They charge you to do the internet search.
Posted on May 19, 2009
Hi I have a 1992 holden rodeo dual cab turbo diesel. 2.8l and manuel I was wondering if the engine components of a 2000 model fits a 1992 model
At www.reliable-store.com get complete guide on whether to repair or not, service it, and how to repair etc, along with wiring diagrams, electrical diagrams, torque specs,
error codes, everything.
Mar 02, 2018 | Holden Cars & Trucks
I have a 2000 model Holden Vt my key won't start my car when I push the button it will unlock and lock but won't start the car,,,, I have checked the battery and it is finei
Hi Cheryl Im not sure if i am missing something in your question but the way i understand it is what you are asking is, you have the key in your hand you press a button on your key and you can lock and unlock your car doors (normal) You are also pressing a button on your key and expecting your car to start (not normal).The standard VT as far as I'm aware this option was not availible as standard on the VT. However It may have had this fitted at some stage as an accessory fit .Do you know if this has ever worked if not then i would say it probably is not fitted. I have never seen one fitted to a VT. If you are 100% certain it has worked then I would take your vehicle to an auto electrician as i am fairly sure its not a holden system fitted. If you are saying that your key works the doors ok but when you put the key in the ignition and turn to start nothing happens then the fault could could be one of many and really needs to be plugged into a diagnostic computer.There is a steel ring that surrounds the ignition switch this picks up the signal from your key and passes onto an on board computer which allows your vehicle to start. I have replaced many of these rings for such a fault, this can be properly diagnosed by a Holden dealer . Good luck
Oct 17, 2017 | Holden VT Cars & Trucks
Hi - looking to fit a Mongoose MAP80 upgrade alarm to a 2011 Colorado dual cab - does anyone have wiring diagram or info for door trigger, arming/lock wire & disarming/unlock wire Thanks
Peter, This is what I found on google search, you can also try google search Mongoose MAP80 upgrade alarm wiring instruction as there is a lot more info. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.mongoose.com.au/vehicle-installation-manuals/MAP80inst.pdf
http://www.mongoose.com.au/vehicle-wiring-holden/colorado_2009_2010.pdf
Aug 04, 2016 | 2005 Holden Rodeo
Rodeo wiring diagram
The wire to the horn button is a live wire and it is shorted out when you press the button. This activates the relay and blows the horn. relays normally work by power coming to a terminal through the coil and out the other terminal to earth . This connects the coil and so the contacts are pulled together to allow power from the battery though to what ever is the relay for .. So what you need is power to a coil terminal on the relay and the horn wire connected to the other terminal. This will complete the circuit when you press the horn and the relay will close and the horn will blow.. To get this it may be necessary to piggy back off the power wire ( battery terminal on relay ) to a coil terminal .
Mar 31, 2014 | 2005 Holden Rodeo
Holden wiring diagrams
Don't have a wiring diagram but if you use a volt meter find live wire on fuse box, connect this to power wire then 2 wires to fuel stop solenoid, using the wire from the stop solinoid to timer this activates the timer and the other from timer to solenoid. This will allow the engine to start by activating the solinoid, I hope this helps
Merry Christmas
Dec 14, 2013 | Isuzu Rodeo Cars & Trucks
Can i put a 98 holden v6 into a 82 wb ute?
I assume a holden is basically a chevy
So if it is rear drive & the one it goes
into then-- yes
Mar 10, 2013 | Holden Cars & Trucks
Firing order for a vn v6 1988 commodore
Hi there:
On Holden - Commodore, VN 3.8 Litre V6 (1988-1991)...
Firing order: 1-6-5-4-3-2
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Sep 13, 2012 | Cars & Trucks
2000 Kawasaki VN 800 Vulcan Drifter wiring diagram
Hi, Fred for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2000 Kawasaki VN 800 Vulcan Drifter wiring diagram Google Search
Kawasaki Motorcycle Wiring Diagrams
KAWASAKI VN800 Service Manual
OEM Parts for Kawasaki
Kawasaki VN800 Owner Manual
May 18, 2012 | 2000 kawasaki VN 800 Vulcan Classic
I nead a wirring diagram to fit a four connection power switch to a Kirby G4 cleaner
There isn't a wiring diagram for these. There is only a switch, a motor and a light, so a schematic isn't really required.
I'm assuming you've made the fatal mistake of removing the wiring from the old switch and have forgotten where to re-connect them. It's also not very helpful that all the wires are white, so I can't really tell you to connect red to "x", black to "y", etc.
The really important connections are the power cord and the motor brush connections. You can't get the power cord wrong as the plug is shaped to only allow connection at one orientation: I've drawn you a diagram to show 3 of the 4 connections:
As long as the motor brushes are correct, there wont be any problem. If these are the wrong way around, the motor will run in reverse and will blow instead of s/uck.
The headlight can be wired either way around so if these connections are switched, it shouldn't matter. You have a 50/50 chance of getting it back the same way as it was originally and if there is any problem with the light, you can easily switch these wires over.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 16, 2010 | Kirby G4 Bagged Upright Vacuum
I have a Gemel Serpi Star alarm gr40 fitted to a 1991 bmw E36, I need to find a wiring diagram, can anyone help. Thank you
Im trying to fit an E90 siren to my E36. Were you every able to get the siren working? please email me at weber.ryan1@gmail.com either way
Apr 21, 2010 | Anti-theft Alarm System 3 Series E90 E92...
Boating Logo
124 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
