My Samsung washing (WF8692SFU) machine displays error Uc and will not spin
SOURCE: Samsung Washing machine fault
possibly a blockage at the end of the thin pressure hose where it fits onto drum ie;scale or soap powder. Also clean the chamber/hose it fits onto
Posted on Jan 16, 2008
beltronic205
  • 1474 Answers
SOURCE: the washing machine does not spin and displays an
Make sure water pumping out if not check /clean filter
Posted on Oct 03, 2009
SOURCE: BOSCH WFMC2100/UC WASHING MACHINE
It tend up to be the control panel on the unit
Posted on Sep 13, 2008
SOURCE: SAMSUNG 845 - ERROR MESSAGE HE2 - not in manual
heater or wiring
Posted on Aug 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code ( IE ) on my samsung washing machine model wa13g7q1
1E - WATER PRESSURE SWITCH ERROR
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Samsung washing machine error code uc
Since you are receive UC error code, Please call the after-sales service.
Source: Samsung CS Portal
May 24, 2013 | Washing Machines
Code LL flashing. Will not complete a cycle.
The LL error code is not documented very well.
Can you tell me what point of the Wash Cycle the Cycle Status LED is in when you error out with the LL error code?
I believe it will be in the Spin Cycle of the wash cycle.
You could try a Quick Spin test and see if the wash basket will spin up to 850 RPM with no laundry in the Wash Basket. See Page 14 of the Service Manual and see if the Wash Basket will spin up to 850 RPM.
You could also check the TDS for proper range of motion using the SM or this typed out process.
Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you fail this test it would be time to remove the machine front cover check if the TDS sensor has fallen of its mounting position between the Tub and the washer frame.
Jul 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a top loader and i have been getting an LL error
I would next check the TDS. Are you taking the error in Spin Cycle of the wash cycle?
Let’s do this quick check and see what you get for test results.
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 of the SM for the details.
e. Press Hand Wash.
What are your results?
Rich
Mar 14, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a fav6800 maytag washer, I am getting a UC code. If the drain is blocked in someway will it give this message? the machine works fine till it comes to the rinse and spin and then error code comes...
What are the first to digits of your machines serial number? It will be 10 thru 17.
Did the machine bang around in Spin Cycle during the wash Cycle with the uC error code?
The FAV6800A and it’s sister FAV9800A LCD display version of the machine suffer from a chronic Dry/Rusted One-Way Roller clutch issue. See this Clutch repair post on this forum for clutch maintenance and or replacement and this post on another forum. Read how to check the failure of the One-Way Roller clutches to slip in the CCW/Spin direction at this post.
If you are just a bit handy you can do the maintenance or order a replacement from AZ they have the best price around $56. I will help you every step of the way…..Rich
Couple of links to the Service Manual and Sears Parts Direct for reference.
I’ll paste in how to check the Tub Displacement Sensor. I don’t feel that is the issue but is will give you a chance to go into Service Mode and check thru the lid for proper operation.
e. Press Hand Wash.
If you get these results your TDS sensor should be just fine and not the cause of dC or uC unbalance errors……fix the clutch and your machine will be
J
Jan 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune TL FAV6800AW Washing Machine is receiving the dC error code on every load. It sits at 12 minutes remaining and attempts to spin several times before throwing the codes.
Hello zacas6,
dC/uC unbalance errors are caused almost all the time by a Clutch malfunction. Take a look this post and see if you want to DIY the repair. I will help you through the process.
I would also check the Tub Displacement Sensor. This a thru the lid check and you get a feel of how to enter Service Mode.
e. Press Hand Wash.
I have some additional info if you decide to remove the Clutch in the machine if you are going to DIY.
Rich
Nov 30, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Not happy with Maytag Neptune TL Washer
I assume you are taking dc/UC errors to the console. This is a classic problem with the FAV6800AW/FAV9800AW after the 3yr to 5 yr mark. I own the machine and decided to learn what was involved to repair the machine. Take a look at this post and see if will give you some insight to a DIY fix to resolve the unbalance errors. No fix for the tumbler action of twisting up the clothes. After a re-lube of the one-way roller clutch bearing I could wash a single pair of socks or over load the wash basket with bath towels and extra water in the tub with no unbalance errors (dc/UC).
Shout back if you have any questions.
Here is a quick test for the TSD sensor but I believe you have a clutch issue. The TDS test is in the SM I’ve typed it out if you want to give a quick check. I’m sure you will pass and find the one-way roller clutch berings are dry/rusted and causing the dc/UC unbalance condition.
3.0 Tub Displacement Sensor Diagnostics check.
3a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
3b. Press the Super Wash key display reads “in”…something like that.
3c. Press Delicates the Display will show “UC” (Unbalance Closed).
3d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
3e. Press Hand Wash.
3f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). If you get these results your Tub Displacement sensor should be OK and I believe it’s not the component failure producing dc/UC errors in spin cycle. I would remove the clutch for inspection and re-lube or replace if necessary. There is a more technical troubleshooting method to check Tub Displacement Sensor in the Troubleshooting guide and Service manual.
Jun 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
UC code on my Maytag Neptune Washer FAV6800WW
HI. this uc code represents a no spin state of the unit. this is caused by a faulty Motor control assembly. you will need to replace the Motor control assembly. this will fix this issue and, restore the normal actions of the unit.
This Motor control assembly will cost about $219.00.
Jun 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Will not spin because the unit moves all cloths to one side and then wobbles until it errors
I saw you post from back in November, did you do anything with your clutch? I assume you are taking dc/UC errors to the console. Take a look at this post and see if will give you some insight to a DIY fix. Shout back if you have any questions. Here is a quick test for the TSD sensor but I believe you have a clutch issue. The TDS test is in the SM I’ve typed it out if you want to give a quick check. I’m sure you will pass and find the one-way roller clutch berings are dry/rusted and causing the dc/UC unbalance condition.
Rich
Jun 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I have an 2002 Maytag Neptune TL (FAV6800A) that won't spin. I replaced the clutch about a month ago. Worked great until now with same problem. Replaced clutch again,but won't work. Received advice from...
Hey Nick,
“”Received advice from one of your experts that it was a resistor problem w/instructions to fix. Opened my machine up and the mother board does not match””
That’s not the way I troubleshoot. Did you pull out the troubleshooting guide out of the console, while you had it open it’s good to have the schematic that’s all that advice was good for.
Do you take any errors to the display such as dc/UC while the wash cycle moves into spin cycle? If you run a Spin Only Cycle with no clothes in the wash basket will it complete the cycle? Does the wash basket spin at all in Spin Only cycle? If it does have you done a Tub Displacement Sensor check? I us this quick check to rule it out.
It is possible the Tub Displacement Sensor may have failed try this check which is the Troubleshooting guide stored in your washer console or refer to the SM.
3f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). If you get these results your Tub Displacement sensor should be OK and I believe it’s not the component failure producing dc/UC errors in spin cycle. I would remove the clutch for inspection and re-lube. There is a more technical troubleshooting method to check Tub Displacement Sensor in the Troubleshooting guide and Service manual.
Rich
Jun 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
328 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
