Question about Mercury P4VM800M7 Motherboard
My pc shuts down secounds after powering on, i checked and there is a small error message that comes saying cpu error, on cpu ratio changed something like that, can u help me please
  • kakjose Jul 31, 2010
    i don't know how to get to safe mode since the pc last for not more than a minute only a few secouns, i can only go to the setup page view a few thingsand then it shuts down
    President:
  • 1,768 Answers
1. oyu may have to go into "safe mode" to see if you have the video graphics resolution at the proper ratio >> this is possibly what you see as an error message and the board has put the computer into the sleep mode until you correct this hard ware issue to safe guard the mother board.
Posted on Jul 31, 2010
  • Harleen Nash Jul 31, 2010
    this is a power supply issue then it may require a tech to check the power supply. the power supply is not supplying the proper voltage and current to that mother board therefore it shut down to protect the components of the mother board.
PC will not turn on?
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 21, 2012 | Sony PCV-RS620G PC Desktop
AFTER SWITCHING ON, SCREEN STAYS FROZEN AFTER SAYING CMOS CHECKSUM ERROR- DEFAULTS LOADED
When starting your PC, the following error message is displayed:
CMOS wrong
CMOS MEMORY size WRONG
CMOS Checksum Bad
CMOS checksum error defaults loaded
Warning! CPU has been changed please re-enter cpu settings in the cmos setup and remember to save before quit!
You are prompted to:
Press F1 to resume
Press F2 to load default values and continue
This is due to the fact that the CMOS, which contain data related to the BIOS, has been reinitialized and that your PC has been reset to factory settings.
Solutions:
Reinitializing the BIOS
  • Change BIOS battery
    • If the problem persist this may be due to the fact that the battery powering the CMOS (when the computer is shut down allows the CMOS to store information), is depleted.
    • The CMOS battery is a small pin found on the mother board, you can refer to the manual provided with your motherboard to change it or have the nearby computer technician change it for you if you don't want to risk any damage.
    • More information with: Replacing the battery of your motherboard (CMOS battery)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | Sharp Actius PC-RD10 PC Notebook
My note book, (acer inspireone) is on loop, the first 2 loading screens come up, then a small blue error message appears for a split second, then the it starts rebooting again... and again, and again, i...
You can recover your PC by going to Recovery console. If you are Using windows Xp then i suggest you to Microsoft Knowledgebase artice (KB307545).
This will fix your issue.
Dec 30, 2010 | Acer (91.AD303.001)
CF-29, shuts down periodically. restarts then works for a while, then shuts down. Error message says something about a mini dump.
Maybe due to overheating issues. Clean up the cpu FAN (HAS TO BE FREE OF LINT AND DUST). For this you have to disassembly your laptop
If that doesn't help you may want to run Windows Recovery Console
Nov 16, 2010 | Panasonic Toughbook 29 Touch (P/N...
Old power supply no good. bought this dynex 400 watt atx cpu power supply and need to know how to connect wires as there are some plugs that can go in multiple spots.
as long as you have the 20 or 24 plug in and the 4pin square plug in plus the hard drive dvd floppy fans i donot no your motherboard or graphic card so i cannot say anymore only next time write down your conections before removing power supply or get manual for your pc
Jul 30, 2009 | Dynex 400-Watt ATX CPU Power Supply
I changed the CPU fan on Dell dimension 3000 but it does not run.
Dell uses a proprietary fan on it's cpu's. This is more than likely your problem. The motherboard does not recognize the new fan and the motherboard is not powering it on. Without replacing the motherboard you are stuck using dell replacement parts for this model. The motherboard & psu are also proprietary in this model so it would take a whole lot of modification to use anything but Dell replacement parts. Your pc is shutting down due to overheating. Sorry. Hope this helps.
Jul 12, 2009 | Dell Dimension 3000 PC Desktop
I have a HP Proliant DL360 G3 which I host a small radio station from. It went down the other night and when I went back to check on it, it was still running but I couldn't get the monitor to come on. So I...
Did you check the connection on the CPU zone up near the front interior of the server? They are like two black modules that sometimes get loose. If you open up the case, near the front left (usually) there you can push the modules down and make sure they are set properly, then try to power up server again. Let me know if that doesn't work and we can try something else.
Feb 02, 2009 | Computers & Internet
Power goes off
1. Your heat sink (keeps CPU cool) may have dust built up on it causing the laptop to overheat and shut down to avoid damage.
Try a can of compressed air ($7.00 Wal-Mart) shoot air in all the vents on the side and under the laptop (do this outside or someplace easy to clean up)
2. Your fan to keep things cool may be stuck (the cleaning with compressed air could fix that) OR it could be broken. When you turn on your computer SOME fans power up this will let you know if it works (some only come on when needed) if your fan does not come on at all you may need to change it. You can Google laptop fans to find a replacement fan and install it yourself.
Good luck My Computer Guy
Nov 13, 2008 | HP Compaq nc6000 Notebook
HP Pavilion a6101(desktop)
hi my name is gary i will try to help you out with this problem......
the first thing that comes to mind is the cpu could be over heating... this could be caused by the cooling fan not working correctly ..if this is the case what is happening is that the bios has a setting that looks after the temperature of the cpu and if it get to hot will shut the pc down to protect any further over heating and of course other components within the pc tower...to check if the fan is working take off the side of the pc while it is turned off you will now be able to see the large fan located on the mother board...now switch the pc on and see if the fan starts up ...if not this will be the problem ... just pop to your local computer shop and they can easily fit a new one for you.
also if the fan is matted in dust this could also cause the pc to over heat and shut down.....if so just turn the pc off and get a small paint brush (new not used) and clean down the fan and the heatsink.
i hope this helps
regards
gary
Sep 20, 2008 | Computers & Internet
PC gets shut down
this means that it is overheating. you can do many things here. 1. take off the CPU cooler, and reapply some heatsync and see if that fixes the problem. 2. buy a larger, or more efficient CPU cooler, newegg.com is a great place to find good parts that are cheap and come with customer reviews already. 3. change the settings in your bios to allow the CPU to become warmer (do not go above 75 degrees) without shutdown or alarm.
Jan 06, 2008 | Audio Players & Recorders
Mercury P4VM800M7 Motherboard Logo
201 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
