Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
PRINT UNABLE 46 SEE TROUBLE SHOOTING CHAPTER IN TROUBLESHOOTING & ROUTINE MAINTENANCE IN USERS GUIDE SHOWING ON LCD
  • 700 Answers
I posted few days back solution to this particular problem, please follow these steps:
first, try to establish if this really is full absorbent pad, remove power cable from the back, wait 20sec, press menu/set key, insert power mains - in most brother printer/faxes this will display machine error code. if this is code 46, you are on the money, your absorbent pad is full (not necessarily, only counter is showing it as such in most cases).
we will asssume that counter is showing full and therefore reset it again to zero:
1. after machine code is displayed, key in "80",
2. go down with arrow key till you find "purge counter"
3. type "2783" this should set counter to "0"
4. press "stop/exit"
5. press "9" twice
6. remove cartridges from craddle
7. remove power cord
8. insert power cord back
9. switch on printer
10. insert cartridges back
if that do not work, then maybe really you need to replace absorbent sponge... it is done under warranty and if not technician in service centre.
if you want to do it yourself, remove cartridges, remove fron cover and on the right hand you will have "offending" sponge. either clean it (absorbent, lint free tissue is fine to remove excess first, then few drop of water and repeat draining process with tissue several time, at least till "cake" from the top is removed. best of course will be to replace the sponge with new one.
after that you still need to reset counter. in another way - follow steps...
if you find this advice useful, pleasae leave comment and rate it, thanx!
Posted on Jul 31, 2010
  • 2 more comments
  • preciousbraz Sep 01, 2010
    very helpful :|
    i tried several times.. this doesn't work
  • amanda-6118 Sep 07, 2010
    looks like usefull but it doesn't work..haiz~
    however~thx^^
  • ejalawncare Sep 15, 2010
    The actual reason for any code that starts with 4 is the printer head, you need to call brother c/s and they will connect to your printer and verify.
  • coolitz Nov 09, 2010
    It worked for me. thanks so much.
"clean unable 46 " and see troubleshooting and routine maintenance chapter in users guide.
HI Gail,
Please watch this brother problem related video and solve your problem.
Still having Problem Then follow Us For Brother Printer Support
Mar 22, 2014 | Brother DCP 165C Compact Color Inkjet...
Dcp-165c clean unable trouble shooting and routine maintenance chapter in user's guide 46
for non fax models ie I have DCP 165C you say press ...... press up arrow four times then press 8 then 0 etc ... but I have no numbers to press!
Jul 15, 2012 | Brother DCP 165C Compact Color Inkjet...
THE LCD SCREEN SAYS PRINT UNABLE 50 AND SEE TROUBLESHOOTING AND ROUTINE MAINTENANCE CHAPTER IN USERS GUIDE.
Read the users guide and do what they say in the Troubleshooting and Routine Maintence Chapter for the "Print Unable 50" error message.
Mar 29, 2011 | Office Equipment & Supplies
Clean unable 46, See Trouble shooting and routine
When you are doing cleaning process many times, You Purge Countergets overflown, You need to be reset the same by some technical rest code required. By pressing - menu -start - menu , Just go in reset counte and reset the same
May 12, 2010 | Brother DCP 165C Compact Color Inkjet...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Its says. see trouble shouting and routine maintence.chapter. in users guide,.but theres nothing there in the book
Hi there. . . okay . . . Follow this step 1.) Unplug your printer. 2.) Plug your printer again while holding the menu button 15 sec. 3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK 4.) then numbers appear looks like this ###:### ###:###. 5.) now push the MONO button until the purge:#### appears on the LCD 6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok 7.) - switch off the printer ,switch it on - ready to print - CHEERS! email me if I helped you. . ryuuzaki182@gmail.com
Aug 29, 2009 | Brother DCP 130C All-In-One InkJet Printer
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
940 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
