Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
In which direction do you place the line on the trimmer head - clock wise or anti clock wise
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
There is infact a small directional arrow on the head but if you cannot find it it should be replaced anti clockwise
Posted on Aug 30, 2010
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
Tip
Trimmer/Weed Eater String Replacement
"How do I remove the spool and restring my trimmer?"
The spool is ******* on. There should be a Half Sphere-like object (Spool Retainer) on the bottom of the spool where the line goes. Twist counter clock-wise, or clockwise, depending on whether you have a Left-hand or Right-hand Trimmer.
If it is a duel line trimmer then:
1. Cut two separate pieces of string, about 7 ft. each.
2. Stick the end of the line in the hole on the inside of spool.
3. Wind clockwise onto spool,putting the line that is closest to the ground on first. Once you have wound this piece on, lock the last 4"-6" inches of line through one(1) of the 4 or 5 slits on spool.
4. Repeat process for second piece of line, putting it on the top side of the spool; locking the last few inches in the slot opposite the other locked in piece. (Remember, if you have a left-handed trimmer, the winding instructions will be just the opposite.)
5. Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
6. Before you push the spool all the way on, pull the strings out of the locked position.
7. Place Half-Sphere-like object back on, twisting it clock-wise to tighten.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer a little longer than 7ft.
Here is a short video that explains 3 different types of heads:
http://i.fixya.netutube.png You-Tube video "OQauZqaEBUI&feature=player_embedded" placeholder
Good Luck with your project!
Jim
Key Words: Weed Eater, Trimmer Head, String, Chainsaw, Leaf Blower, Snow Bower, Pressure Washer, & Varnisized
on Oct 04, 2010 | Garden
Head removal
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, 22
Jan 28, 2012 | Garden
Need to know how to wind trimmer line on trimmer
depends on the trimmer, all heads are different. However, the majority of trimmers are wound as follows:
1. pop the top cover off the head, pull the spool out. It will be either single or double lined, they will be wound counter clock wise.
2. the end of each line goes out each of the seperate holes
3. slide spool back on and replace cover
www.ButlerPower.com
Sep 04, 2010 | Husqvarna 28cc Gas Line Trimmer
I need to remove a trimmer head on a tb514cs how do you do this
it if has a bent drive shaft the head removes by undoing it RH (anti clock wise) if it has a straght shaft with a gear head at the line end, it will come off LH ( clock wise) there will be a hole to lock the head to undo it.
Jul 01, 2010 | Troy Bilt Tb70ss Gas Trimmer
How to change to a rapid loader head on an echo
line up the hole on the collar that the trimmer head is installed against with the arrow or notch on the gear housing, insert a punch or the brass colored pin that most Echo pieces of equipment come included with, this will lock the head. now turn the head clock wise, IT IS LEFT HAND THREADED! so righty loosey lefty tightey. now install the rapid loader with the included washers and10mm gold colored lefthand thread nut
May 18, 2010 | Echo Rapid Loader, Trimmer Head
How do you put the line on a Line Trimmer WT320 CLS , do you wind it on clockwise or anti clockwise
Look at the spool itself there is a direction arrow on the spool itself. If you can not see the direction arrow it is upside down. The arrow should be facing you when the trimmer head is facing the sky. The direction of the arrow is the direction of the cord winding. If the head rotates CW the cord is wound CW.
Thanks for using FixYa!
Kelly
Feb 22, 2010 | Husqvarna 28cc Gas Line Trimmer
Ryobi weed trimmer
I have one of this trimmers. It is simple to replace the line.
-First line up the arrows on the bottom of the spindle.
-Then feed the line back in one of the holes in the side of the spindle (this is the same hole that the cutting string comes out of).
-You will see the line come out of the bottom of the spindle.
-Take that line a place it in the hole on the bottom of the spindle.
-Leave about 9 feet of string hanging out of the weed eater (do the same with the other side).
-Then turn the inside wheel (I can't remember if it is clock wise or counter clock-wise but it will only turn one way) most of the string is rolled into the spindle.
-Cut the string of about 5 inches out of the weed eater. You're ready to cut!
May 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
162 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
