Question about HP LaserJet 1018 Printer
My printer does not print anymore
I have HP laser Jet 1018, before it was printing very well but now it stops printing, all documents go on queue and i do not get an error message if the document cant be printed its just does not print at all now,i have change and unplug the cable so many times now,i even change the ports but still no error message and does not print. i need help here so fast please!
  • 624 Answers
Hello and Welcome to FixYa!
There may be many aspects of this issue, but its good to see that HP have written a nice article about this issue. I've attached the link below. Kindly read it throughly and I'm sure that one of the solution will definitely work for.
If you are having any trouble/questions, don't hesitate to ask. I'm here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Solutions for the Stuck in Print Queue Issue
Posted on Jul 31, 2010
Testimonial: "thank you very much, i downloaded the diagnostic tool and now evrythng works fine"
How do i cancel a printing on my laserjet 1100a
The document you sent to the wrong printer is still in the print queue. You need to go into the print queue and delete the document there. You may need to click to control panel, click on the laser jet printer and delete the wrong document.
Dec 15, 2017 | Office Equipment & Supplies
My HP Office Jet won't print the entire document sent to it when it is asked to print double sided. And repeatedly will fail at the exact same spot in each document; although the spot where it fails is...
There are 3 step to repair 1018 error
If you got 1018 error then there is a 94% chance that your computer has registry problems. To repair 1018 error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair 1018 error.
Here are the url of Perfect Optimizer:http://www.pcerrorremover.com/tidpp-1018...
Jul 06, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
How do i clear the print queue on a HP laser jet 2600n? Jobs have spooled to printer but will not print as cartridge needs replacing - how can i remove jobs from printer memory??
Hi There,
Please follow the below link to clear the print queue or jobs on the computer......
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=446153&prodTypeId=18972&objectID=c00775196
Please vote for me if your issue is resolved by this solution.
Thanks.
Enjoy and cheers !!!!
Oct 28, 2010 | Office Equipment & Supplies
I have a HP Laser Jet 3800n and it is showing the code 49.4C02 Service Error Code.
Printer error 49.4c02 may occur due to corrupted print queue. Just clear the queue and restart the printer and the error may be fixed. This would seem to work for most cases. If none of them are corrupted, check to see if any of them are in an uncommon size. Larger printings tend to result in this error as well. Check if it's the cause by clearing the queue then printing normal-sized documents instead. The error may also be caused due to complicated fonts as they are harder to read, especially if they're in color or written in a pdf format. If this is the cause of the error you can either stop printing such documents and update the drivers or firmware. The drivers may contain bugs which cause the printers to act this way, so updating them will solve the problem. get more information and help Printer Error 49.4c02
Sep 16, 2010 | Office Equipment & Supplies
Error 49.4C02 on my hp laser jet 2420 dn printer. Haw can I fix that?
Printer error 49.4c02 may occur due to corrupted print queue. Just clear the queue and restart the printer and the error may be fixed. This would seem to work for most cases. If none of them are corrupted, check to see if any of them are in an uncommon size. Larger printings tend to result in this error as well. Check if it's the cause by clearing the queue then printing normal-sized documents instead. The error may also be caused due to complicated fonts as they are harder to read, especially if they're in color or written in a pdf format. If this is the cause of the error you can either stop printing such documents and update the drivers or firmware. The drivers may contain bugs which cause the printers to act this way, so updating them will solve the problem. for more help......
http://www.fixya.com/support/t6031482-hp_laser
Sep 10, 2010 | HP LaserJet 2420dn Printer
Having a 'spooling' problem with my HP Laser jet 1018 printer Therefore, my printer will not print anything!
In run window type services.msc and the go to print spooler option just stop and restart the service.
Nov 25, 2009 | HP LaserJet 1018 Printer
Hp laser jet 1018 printer
hmmm..have you tried cleaning and re calibrating the heads?
Feb 29, 2008 | HP LaserJet 1018 Printer
HP laserjet 1018 service
Have you installed the new drivers for your HP?
Personally, on all HP Printers, I use only HP products, mainly Jetdirect Print Servers, but you might try creating a TCP Port Printer (via your Printer Install Wizard) and use that. You only need to know the IPAddress of the DLink and the Drivers for the HP Printer.
Dec 04, 2007 | D-Link DP 311U (DP-311U) Print Server
Hp 1610 and 1018
Are you printing from MS Word? What software package are you using? Each printer is different and some require software settings.
Jun 22, 2007 | HP PSC 1610 All-In-One InkJet Printer
439 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
