Question about Olympus Stylus Verve / ?-mini Digital Camera
I turn the camera on and it shows write project. what does that mean and what do i need to do to get it working
  • emancini Jul 31, 2010
    i have olypus style verve. u-mini digital
    its shows 'write project' and thus meaning i cant take photos. now
    the sd card im using is olympus xl picture card m1gb- if that helps you
  • Olympus Master
  • 19,396 Answers
Hi.
Open the menu and go to Mode Menu. It will display a four-page menu:
Choose menu Play and find option Protect. Turn Protect OFF.
Protect means Write-protects ( remove protection here) from the currently displayed image. Write-protection locks the image file so you can't accidentally erase it or change the file in any way (except by formatting the memory card).If this does not work, format or replace the memory card. When replacing memory card ensure you choose a compatible one. Many cameras do not accept memory card bigger than 2GB.
If the above does not work, before replacing the card, also try a reset.
Open Setup Menu and do All Reset: This resets all of the camera settings to their defaults.
Do not forget to leave feedback.
Regards.
Ginko.
Posted on Jul 31, 2010
  • 10,515 Answers
Eject the SD card from the unit, and make sure the little read/write protect switch on the SD card is set to unlocked.
Let me know,one done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • 2 more comments
    ive got the sd card out............ no problems/
    but what do u mean by this
    'the little read/write protect switch on the SD card is set to unlocked' dont understand this instruction
    any luck
  • taran_2005
    taran_2005 Jul 31, 2010
    Thanks for your response!!
    The procedure is explained :-
    http://www.getflashmemory.info/hack-why-...
    You need to make sure SD card should not be locked.
    Have you tried some other SD card? Sometimes, a faulty SD card could result in the same error.
    Let me know,once done.
    Hope i helped you.
What does write project mean
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 10, 2012 | GE X500 Digital Camera
Will turn on but will show no picture
Check the inputs. If you can hear audio that means it's processing but no picture can mean that the lamp is burned out.
Jan 12, 2011 | RCA HD52W59 HDTV Projection Television
How do I turn off the date time function. It can be altered but there appears to be no way to turn it off.
Well ,there's good and bad news.
the usermanual....
http://safemanuals.com/user-guide-instructions-owner-manual/CANON/POWERSHOT%20A2000%20IS-_E
suggests that you need to set the time and date (How to - page 18), as its stored with each image. There appears no option to turn it off "at the recording stage".
However, on page 118, hidden in the <print settings> menu the option there is the option to turn off (suppress) the date on printing.
So it would suggest that the file is kept separately from the image.
...... Which probably means if you look through the official software you see it, but if you looked at the jpeg through another viewer (such as xp media center, adobe photoshop, photosuite etc ... there are lots) it may not show up on the projected image.
Just a theory, but one worth looking into?
Feb 28, 2010 | Canon Powershot A2000 IS Digital Camera
'Write project'
I don't know this message, and am going to guess what can be done. I searched on the Olympus site for such a message, none. Not sure what it means.
I believe this has to do with a setting in the menus.
Turn the camera on, go to the menus and set all to factory default, or something like that such as reset or reset all.
Test the camera after setting and set the menus to what you want.
Oct 27, 2009 | Olympus Stylus 820 Digital Camera
The display shows
This stands for Error number 50. I need to know what camera this is to give a definitive answer
Jul 19, 2009 | Sakar 23070 Digital Camera
Kodak EasyShare V1003 Digital-Turns off and Lence projected
its the hanging of ur cam's software..it can b solved by the technicians itself..so don dave ur hand in solving it..it may b due virus from ur memeory card..so rush to the service center..don get the product spoiled more..it wont cost u much for repiaring also..
ne thing els do tell me..n plz plz do rate me..
cya
Apr 24, 2008 | Kodak EasyShare V1003 Digital Camera
Write Project?!?!?
If you camera has some internal memory remove your memory card and see if the camera works. If so, check the memory card and see if the little switch is in the "lock" position.
Feb 21, 2008 | Olympus FE-190 Digital Camera
It takes time to turn on
I hold the digital camera with the lens upward when I switch it on, and then the problem doesn''t occur and I can take pictures.
I hope that this workaround will also work for you.
Nov 13, 2007 | Olympus Stylus Verve / ?-mini Digital...
Camera shows an error E30 message
Hi Chittu, This error usually happens when there's problem reading and writing from the Flash memory card (CF). Did you try to pull the memory card before the camera finished writing data? Here's what you should do - try using another memory card. If it works, it means that the original one is damaged. Let me know if this helped. Please rank this post.
Mar 05, 2007 | Canon PowerShot A75 Digital Camera
Olympus Stylus Verve / ?-mini Digital Camera Logo
53 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
