Question about Lenovo 3000 Y410 Laptop
Starting window I am having the problem in my lenovo laptop,when power on the laptop the LED's are lighting and the LCD screen also works, but the screen stand by starting windows . i can't enter in to the main window
  • 20 Answers
You have a corrupted operating system try to reinstall your OS. :)
Posted on Jul 31, 2010
My lenovo z570 won't start even LED light also not blink
If LED does not blinks, the problem can be of its hard disc too, other than mother board. http://electronicshelponline.blogspot.com/
Aug 01, 2014 | Lenovo IdeaPad Z570 Notebook
Lonovo ideapad tuns on but doesnt work
You turn on but it won't boot to your OS? or powers on (i.e LED power light comes on) but you get no display at all, not even Lenovo logo?
If it's not booting try booting from your windows CD/DVD and running a start up repair. This is a guide for Windows 7 but should be very similar process for Windows Vista.
http://pcsupport.about.com/od/toolsofthetrade/ss/windows-7-startup-repair.htm
If you get no display at all (Not even a Lenovo splash screen) and just lights, try popping your battery out and power the system up on mains only. If this works, pop your battery back in, it should be begin to charge. You laptop should continue to work from now on. This is a problem that occurs from time to time on any laptop and is cleared this way.
If removing the battery doesn't work I would try removing/re-seating/swapping out RAM.
Let me know how it goes, I may be able to help further.
Dec 05, 2013 | Lenovo IdeaPad S10-3 Netbook
I have a Lenovo L520 with a dim screen.
You may have a faulty inverter, this supplies high voltage to the CCFL lamp that provides the back light for the LCD screen.
Sep 10, 2012 | Lenovo ThinkPad L520 15.6" LED 2.1GHz 4GB...
Screen of lenovo G475 does not want to light up. Laptop does start up
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 04, 2012 | Lenovo Computers & Internet
I own a lenovo laptop G465 which I bought from lenovo sm cubao last april 2011. One morning when I turned my laptop on I was dismayed to find out that there was no screen display. I've been very...
Does the laptop indicate any power? does the LED turn on and stay on but you can't see anything on the screen? Is there no power at all, No LED light turns on and everything is switched off?
Since you bought it April 2011 it's only been a month so there should still be warranty for your laptop. If you are comfortable enough try removing the memory sticks, the hard drive, the WLAN card the battery and try to plug it in the power outlet without those and check if it will turn on. Otherwise find your receipt and bring it back to the store "SM" where you bought it and have it checked by one of their technicians or possibly get it replaced.
Hope you find this helpful.
BTW: I'm also from the Philippines.
May 10, 2011 | Lenovo Computers & Internet
My lenovo ideapad y560's monitor won't open. the monitor is pitched black.
Hi thelzy,
I see that your Lenovo Y560 is having issues showing no Video, you mentioned that you only get a Black screen when booting.
I am assuming that there is still power on the machine but no video at all, Just to ask do you still see the Lenovo Splash screen? if not then we can try doing a power cycle on the machine.
* Remove the battery on the system unhook the Power Cord/AC adapter as well then press and hold down the power button of your Y560 Laptop for about 15 seconds then let go.
*After Doing the Power Cycle connect the AC Adapter again but leave the battery out for the time being then turn the compute ON, check to see if it will show the Lenovo Splash screen if it does then we're in progress and should show windows Loading up on the LCD screen.
*If it does not show the lenovo Splash screen then most probably the BIOS screen never showed as well on the issue.
*Connect the battery back n the machne turn it ON again check if it will show anything on the screen, if not then see below.
*We can try connecting an external mnitor to the system using a VGA connection it should show us the Screen on the external monitor if not then it means that Windows as well is not booting on your Laptop.
*Check the indicator Lights on the Laptop, one of the Lights will be a cylinder icon on the Laptop check if there is any activity from that light if there is no Light or any avtivity to any of the indicator lights then your Y560 is having issue with the Motherboard.
I hope this info Helps.
Have a nice day.
mvincentc
Apr 21, 2011 | Lenovo IdeaPad Y560 Notebook
IBM LENOVO NOT WORKING
Hi, try this step:
Turn off the pc
remove cables and battery on the laptop
Press and hold the power button for 5 seconds
reinsert cables and battery on the laptop
Turn on the pc
If there is no screen on LCD, please contact our tech support at 1-800-426-7378 for repair....
May 22, 2010 | IBM Lenovo ThinkPad R61i Notebook
Lenovo R61 won't get to login
I,d suggest To charge the battery Fully.
Then power up the laptop, with A/C Adaptor connected.
Also check your models user manual, regarding the sleep/hibernate mode. the laptop may have gone into one of these modes. Usually a ( zzz ) Icon Key or Similar.
Also when booting press the LCD/VGA Button.
If all else fails, try to see if your laptop, has a hard-reset button or switch. ** Sometimes this can be a small hole ** On the underside of laptop. *** Only use with laptop Powered Off ***
Mike @ Compurepair.
Jul 03, 2008 | Lenovo R61 T7300 Notebook
Lenovo 3000 Y410 Laptop Logo
67 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
