Question about Samsung ML-1640 Monochrome Laser Printer
Hi the printer won't take paper anymore. After a while the led turns yellow indicating a paper jam. But there is no paper inside !
    Sergeant:
    Champion:
  • 301 Answers
Clean the printer , buy a airspray and clean in , if not , take local support
Posted on Jul 31, 2010
I have a Brother Printer HL-240D that gives me a constant paper jam inside indication even though the paper goes completely through the printer, and there is no actual paper jam. What switch causes the...
Have you tried shutting it down completely? Also, double check to see if the inside of the printer is completely clean. I had the paper jam indicator showing because there a small piece of paper stuck inside. Also, found a helpful manual for a similar printer, you can see it here - Brother HL-2240 manual
Sep 29, 2013 | Brother HL-2040 Laser Printer
Orange light on SIDE (not top) of HP LaserJet P2015 Series printer won't go out. Have disconnected all leads and re-booted printer and computers (2) to no avail. There are no paper jams and have
Is there any text to indicate what this light refers to?
In general, you might want to remove paper trays, and use a compressed air can to spray inside the printer, especially the paper path. Oftentimes, paper dust will impede a photo-optic sensor, and keep an indicator light lit when there i no real reason for it. It can also give you a paper jam indication when there is none.
So blow out all paper dust to get the printer to work correctly now.
Cheers!
-a.
Apr 10, 2012 | HP LaserJet P2015dn Printer
There was a paper jam. I got the paper out but now error message 6A00 appears in the screen. I have tried to turn off and on.
The error code means paper path jam.
Inside your printer a paper path sensor has been activated indicating paper jam so the printer will give off a 6A00 code.
So please check for any stuck paper, debris
The offending item needs to be removed or the purge unit needs replacement.
Also clean the purge unit out make sure all is clean
May 11, 2010 | Canon PIXMA MP610 InkJet Printer
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
I have a canon MP140 but the printer dont work anymore.
E 3 is telling you that there is paper or something still in the paper path. You need to clear the jam, if there is nothing in the path, there is a defective sensor which requires a shop repair.
Jun 30, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Paper jam
there is a sensor which detects if there is a paper jam in the printer.that sensor is bit moved from its orignal position so it is continuously detecting the paper jam in your case.
Oct 06, 2008 | HP DeskJet F380 All-In-One Printer
PAPER JAM
Rotate tires. Pull out paper tray. Pull down on red low paper indicator at left bottom. Two rollers come down on axel near center. I pulled off the rubber tire like roller, then twisted the roller inside out and reinstalled it with the fresh side out.
If tires dry out again will probably buy new ones from ebay.
Jun 26, 2008 | Lexmark E232 Laser Printer
PIXMA iP1700
hi dear
turn off your printer,
try with this metode
Waste Ink Counter Reset. Manual for Service mode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and release the RESUME button again, the indicator
6. Release both buttons
oke try to print
Mar 23, 2008 | Canon PIXMA iP1700 InkJet Photo Printer
1020 laser printer problem
Problem is you have paper jam!!! Seek for the paper inside the printer, pull out cartridge!!! when you do that, turn off printer and disconnect power cable for 1min. Pull back the cable, turn printer ON!!!
good luck!!!
Jan 22, 2008 | HP LaserJet 1020 Printer
Samsung ML-1640 Monochrome Laser Printer Logo
260 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
