Question about Canon CanoScan LiDE 70 Flatbed Scanner
Unable to scan. no target space
Was scanning OK. I moved residence and now the following error message appears. Unable to scan. There is not enough target space.
    Sergeant:
    Champion:
  • 301 Answers
Install the software o driver again
Posted on Jul 31, 2010
Can not scan. Get message "Unable to scan. Make sure there is enough space on target disk". Changed default temporary disk location, have plenty of disk space.
Had this before and after a day of playing about with cleaning out the windows temp folders, I simply uninstalled all the driver and toolbox software, downloaded the latest version from Canon's site and reinstalled it. After doing a bit of research, found out it was caused by a windows update conflicting with the drivers
Dec 27, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
Scanner sends message "Unable to scan. Make sure there is enough space on target disk"
Check the resolution settings.  If you're trying to scan at 9600dpi, the image will be huge, it may not fit into ram either, so the swap file would be used and you would need twice the file space to scan the image.
Scanning at 600dpi is generally fine enough for most uses (300 or less for web use), including scanning photographs (you may want to scan negatives at 1200 though.)
JBV^_^
Sep 01, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
I have just been unable to scan and get the following message: Where is the target disc? How do I clear it or give it extra space?
Just U Have to define the location where the scan image will be save. wheather it is "C" drive or "D" Drive
Apr 02, 2010 | Computers & Internet
An error message when i try to scan
On the CanoScan Toolbox program bar, select settings. Then hit the Browse button next to "Select Folder where Temporary Files are Saved" and go up one level to Canon from TB50. Then hit OK. This fixed the problem for me after Microsoft Updateinstalled updated Canon drivers. It looks like the geniuses at Canon are either having you write to a write-protect folder or one that only has system permissions and then giving you a disk-full error.
Mar 25, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Unable to scan.make sure there is enough space on the target disk
Do a "reset".
•Go into the CanoScan toolbox,
•click Settings,
•click the Defaults button on the bottom
•then click OK.
It will take a few seconds to reset and you should be good to go.
Jan 24, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Won't scan - says not enough disk space.
I had the same problem. Solved it by going into the "CanoScan Toolbox" - "Settings" - and pressing the "Defaults" button in that panel - and then "OK" button. Afterwards everything worked fine. Hope this helps you.
Dec 18, 2008 | Canon CanoScan 8600F Flatbed Scanner
Canoscan lide 70
Head for the Canoscan Toolbox and click on "Settings".
Under "select folder where temporary files are saved", click on "browser".
Choose where you want the scanned item to be sent and then click 'OK".
This works for me.
Jun 08, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
LiDE 600DF - Unable to scan
Hi Peter
Have had the same problem, seems to come and go a bit... Quickest & easiest fix is to go to CanoScan toolboox > Settings then press the 'defauls' button at bottom... this sets everything back to factory settings and should fix your problem. Cheers.
Canon CanoScan  LiDE 70 Flatbed Scanner Logo
177 people viewed this question
old marine
old marine
