Question about Avanti Top Load Washer W797
I can't find an adapter for my kitchen sink that will fit the hose end of the Avanti. Avanti customer service was useless.
  • 10,865 Answers
Hi. Take the hose to most any neighborhood hardware store and they will fit it for you. Often, a local mom and pop hardware will be most helpful and knowledgeable. I assure you that there is a fix for your problem. J.
Posted on Jul 31, 2010
How to lengthen the water supply hoses. There to short to reach sink.
Buy a flexible braided hose for mains pressure. They come in different lengths.
Fit one end to the water outlet tap and for the other end you will need a fitting you can attach the dishwasher hose to that any plumbing supply has. I don't think you can buy a flexible braided hose that will fit to your water supply tap on one end and then straight to the end of the dishwasher hose on the other. You will need the adapter between the 2 to hook the fittings up. Use plumbers tape on the fittings when installing them for a good water seal.
Or you can just get a plumber in who will fit everything up for you and will also probably use a flexible hose to plumb in the water supply.
Jan 04, 2016 | Dishwashers
How do I install grohe kitchen faucet hose 46092000 from a 1992 faucet? I do not see a yellow quick coupler.
look at the ends you need to connect then go to a plumbing supply store and get the adapter.
Dec 19, 2014 | Grohe Home
Why does my locking collar from my unicouple hose not fit on my kitchen sink faucet/
Go to a plumbing store where the contractors
go & get the correct adaptor
Sep 28, 2014 | Plumbing
I have a brand new LG bottom/slider freezer and I am trying to hook up the water supply for the ice machine to the cold water supply under my kitchen sink. I have purchased a kit inculding a copper pipe...
well I had a plumber connect a new hose it cost me $ 85 but it was properly install, since we added a splitter Home depot recommended but it can't take the pressure and the hose connector will leek. or if you are handy connect a splitter and a new valve
Oct 06, 2009 | LG LFX25960ST Stainless Steel French Door...
How to fit POLO PULLOUT SPRAY KITCHEN SINK MIXER TAP 0119 **NDD**
hi i need to fix a pull out sink mixer...but i have no idea how to fix.pls help.thanks
Oct 05, 2009 | Food Mixers
Looking for parts for Avanti g20aw
Go to www.repairclinic.com. You will need the model number. You will see all the parts available for this unit. Good luck.
Sep 29, 2009 | Avanti G20AW-1 Gas Kitchen Range
I have a new hose for my Grohe Euro Plus to replace a leaking old one. I have disconnected it from the water supply but now the ends of the the old hose will not fit through part connected to the sink...
There are 2 sets of nuts and washers underneath the faucet that holds the faucet in place. loosen them and the water lines (after turning the water off) faucet lifts off from the top of the sink. Replacement the the same, just in reverse. BE SURE TO USE TEFLON TAPE OR PLUMBERS PUTTY ON THE WATER LINE THREADS TO PREVENT COSTLY LEAKS.
Jun 20, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Avanti DG 241 BS gas range oven burner goes out and wwill not rel
You need to order parts from AVANTI.
http://www.avantiproducts.com/
Very disappointing customer service.
I have been waiting 6 weeks for a new thermostat. It will not
arrive from China until June -- I was originally told it would come in April. All AVANTI parts are from China and AVANTI in Florida is the
only dealer. I will never buy AVANTI again.
Feb 19, 2009 | Avanti DER24CSS-1 Electric Kitchen Range
Hose does not fit on sink faucet
Yes, the adapter was the answer!!! I went to the Sears Service Center and bought one, under $10. HURRAY! And say hello to softer hands . . .
Nov 12, 2008 | GE 24-7/8" Convertible Portable Dishwasher...
Hotpoint dishwasher
Did you have a dishwasher before? If so, you must have had a sink tail piece with a dishwasher drain coming off the side. For the connection, you may have to get an adapter to fit the end of the dishwasher drain hose to the sink tail piece. Take all pieces to hardware store if necessary to get an adapter which fits. After you connect the drain hose, make sure that the drain hose has a "high loop", meaning that the hose curls up at least 6 inches above the connection point before it goes down again. This is important to keep sink waste from getting back into the diswasher hose if the sink drain backs up.
Feb 14, 2008 | Dishwashers
Avanti Top Load Washer W797 Logo
136 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
No_ky
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
