Question about Microwave Ovens
SANYO SUPER SHOWER WAVE 900W TURNTABLE MOTOR DEFECTIVE, WHERE AND HOW DO I FIND REPLACEMENT?
5 Suggested Answers
  • 30 Answers
SOURCE: change power level on microwave
try pressing the power botton it should cycle through hi. low. med then back to high.
Posted on Sep 03, 2008
tiway1
  • 100 Answers
SOURCE: Turntable motor - Sanyo Microwave Model EM-S8000W
There are actually two, both Panasonic motors...
Here are the full links...
http://microwaveglasstrays.com/shop/120v-microwave-turntable-motor-253w-b6326408ap-p-215.html
http://microwaveglasstrays.com/shop/120v-microwave-turntable-motor-6rpm-f63265g60ap-p-217.html
Here's the link to their main page for motors...
www.martinmicrowave.com
Posted on Sep 06, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: The microwave facility in this
When you hit Start to cook, do the inside light and turntable come on?
Any unusual noises? Is it louder or quieter than usual?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Posted on Nov 27, 2008
shane_barnha
  • 136 Answers
SOURCE: Can you tell me where
Because I do not know the exact Model number of your Microwave Go Here and enter your model number to get the Owners Manual.
Thumbs Up if Helpful!!!
Posted on Jun 20, 2011
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
Change Motor but turn table does not turning?
test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Main Control Board
If the microwave turntable doesn't turn the turntable motor is usually the problem. If the motor is good the main control board might be defective
Jun 16, 2013 | Microwave Ovens
Can you tell me where I can find a manual to sanyo fan assisted owen 1200 w, super showerwave 900W?
Jun 20, 2011 | Microwave Ovens
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Mar 13, 2010 | Frigidaire FMT148GP Microwave Oven
The microwave facility in this multi function Sanyo shower wave oven EM-D993 has ceased to work. Everything else does.
Nov 24, 2008 | Sanyo Microwave Ovens
Turntable on my sanyo EM-C6786V MICROWAVE OVEN do not turn wilst cooking
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find Sanyo UK support, parts and authorized servicers here.
Nov 04, 2008 | Sanyo Microwave Ovens
Sanyo Microwave EMS 8000W Turntable motor failed need a replacment?
About the only option is to carefully take the motor apart and see if one of the pins that holds one of the gears has broken.
If you're very careful, you can use super glue to glue parts back in place, but they have to be squeaky clean and dry before applying glue and they must be clamped in placed to bond.
Be sure you hold it shaft side down when you pull the outer cover off.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 02, 2008 | Sanyo Microwave Ovens
Microwave Ovens Logo
278 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
