Question about Braun 8585 Electric Shaver
I've connected it to 115v with cable from old Braun and probably burned out fuse or rectifier. How I could take apart the shaver?
  • Braun Master
  • 1,626 Answers
To open the shaver body on model 8585, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
You will probably need to replace the circuit board you will find a replacement circuit board for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-activator-circuit-board-with-batteries-select-models-p-363.html
Posted on Jul 31, 2010
I need to replace the battery in my Braun 5414 shaver. Thanks John Lennard
You will find compatible battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
First, remove foil and cutter. Then remove the swivel frame by removing the two tiny screws. Then pop off the two screw covers on the bottom of the shaver and also the screws underneath. You can then gently pry the two halves of the case apart at the bottom to access the insides.
For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Dec 03, 2010 | Braun Health & Beauty
Hello, I have had a Braun 5564U model shaver for years. I used in up till last week when it quit running altogether. At that point, the led light will also not illuminate and the unit does nothing. I...
Most likely, you have damaged the circuit board from using it directly from the cord for so long and not changing the batteries when they were needed. The fact that the chatging light no longer illuminates tells me that this is probably the case. However, it is possible that only the batteries are bad. It is pretty hard to tell which it is without installing new batteries though. If you want to try new batteries, you will find the correct type at shaveroutlet.com.
If your unit has two batteries, order two of the type linked below
http://shaveroutlet.com/shaver-replacement-parts/batteries/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
If yours has only one battery, you need this type:
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-replacement-battery-aa-nimh-p-108.html
Nov 16, 2010 | Braun Flex XP 5614 Electric Shaver
My Braun series shaver recently stopped working. I have tried to charge it, thinking thats the problem, but thats not it. It started again, but stopped a couple days later. Its 1 year old. What are...
If it is intermittent, that sounds like there is a bad connection inside. Braun has a 2 year warranty. If it is only one year old, call Braun at 800-272-8611
Oct 21, 2017 | Braun 360° Complete 8985 Electric Shaver
My Braun shaver 8585 has died. Foil, cable, box, Clean and charge unit as new. Which Braun shaver replaces Braun 8585 and can utilise good pieces?
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Aug 23, 2010 | Braun 360° Complete 8985 Electric Shaver
Head (foil and blades) used to last 10-12 months. Now they last about six weeks. I don't hink I have done anything different when shaving. Braun Syncro is abotu four years old.
Six weeks? That's very peculiar. Are you certain that they are seated properly on the shaver? If there's a problem with the head and they're not fitting into place slightly off, they can end up wearing out faster.
If you've used your shaver for a number of years, your best bet is to probably step up to a newer model Braun shaver. The 7000 series was OK, but the 8000 series is much better. You can still pick up new old stock ones off "that auction site". They shave not much differently from the new 9000 series (Pulsonic). Good luck!
Sep 16, 2009 | Braun Syncro 7526 Electric Shaver
How to change batteries braun shaver ?
It is suppose to be rechargeable and have a 2 year waranty on it. send it bback and get a new one or just take it apart and use regular batteries.
Aug 29, 2009 | Braun 8585 Electric Shaver
Braun shaver won't charge
Batteries have an expiry date, Even if you're not using them they are still discharging. Even the regular AA type you buy at the shops.
Batteries can die even if there is a lack of use. And even regular rechargeable shavers that are used all the time have only a limited life a little shorter that=n what you've had.
Should you get new batteries or a new shaver? probably not, you're using 2-3 times a year. I'd recommend buying a cheap Braun or Remington that can take AA's.
Apr 07, 2009 | Braun Health & Beauty
Where do I buy a replacement side-burn trimmer for the shaver?
The trimmer is sold as the back housing assy. I have them in stock. Please call me aty 1-888-643-9806 to order 1. I will tell you how to get the shaver apart to replace. Ask for Action Mike.
Jun 05, 2008 | Braun 8585 Electric Shaver
Braun Shaver 360 Complete #8985
the 110 plugin goes into a circuit which changes AC to DC for charging the internal NiCad batteries. If there is NO charge whatsoever in the batteries, the shaver will not work. If you have any electronics background a simple test with a VOM will determine if the bridge rectifier is putting out any DC.[you must disassemble the shaver] If you have no experience on circuits take it to a repair location.
Sep 10, 2007 | Braun 360° Complete 8985 Electric Shaver
Braun 8585 Electric Shaver Logo
138 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
