Hi, my acer is running on vista, my problem is that on the start up, it says operating system not found, i dont have a windows vista boot disc but i have an xp disc, but every time i go to boot it up, it says that there is no hard drive dresent
    Sergeant:
  • 170 Answers
When you start your machine press and hold f8 and it will send you to the bios menu......go to the boot up options,and scroll down and select the hard disk option you have . then press f10 to save and exit. and have fun
Posted on Jul 31, 2010
How can i format a pentium 3 acer desktop computer.
you will need to get an operating system boot disc, such as an original windows XP, vista or windows 7 disc,, or use the restore disc that came with the product.
1.) boot from the disc (usually f9 at the boot pompt) thn select your cd drive as the boot device.
2.) follow the onscreen instructions..
3.) select new instillation instead or repair or restore.
4.) follow onscreen instruction.
Dec 27, 2012 | Acer Veriton PUV9803001 Desktop Computer...
Tip
Repairing Windows Vista using bootrec.exe
Bootrec.exe tool can be used in the Windows Recovery Environment (Windows RE) to troubleshoot and repair the following items in Windows Vista:
  • A master boot record (MBR)
  • A boot sector
  • A Boot Configuration Data (BCD) store
To run the Bootrec.exe tool, you must start Windows RE. To do this, follow these steps:
  1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
  2. Press a key when you are prompted.
  3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
  4. Click Repair your computer.
  5. Click the operating system that you want to repair, and then click Next.
  6. In the System Recovery Options dialog box, click Command Prompt.
  7. Type Bootrec.exe, and then press ENTER.
Bootrec.exe options
The Bootrec.exe tool supports the following options. Use the option that is appropriate for your situation.
/FixMbr Use this option when you must resolve MBR corruption issues, or when you have to remove non-standard code from the MBR.
/FixBoot Use this option if one of the following conditions is true:
  • The boot sector has been replaced with a non-standard Windows Vista boot sector.
  • The boot sector is damaged.
  • An earlier Windows operating system has been installed after Windows Vista was installed. In this scenario, the computer starts by using Windows NT Loader (NTLDR) instead of Windows Boot Manager (Bootmgr.exe).
/ScanOs Use this option when there are Windows Vista installations that the Boot Manager menu does not list.
/RebuildBcd Use this option when you must completely rebuild the BCD.
Note: It will work with all windows Vista versions
on Mar 03, 2010 | Microsoft Windows Vista Ultimate Edition
My acer aspire 5515 laptop system error window show when I try to boot. Hiw do I fix it?
so what i guess its giving mbr not found and its not booting , the solution is you need to have the windows operating system disk and then when your acer laptop starts to boot click on f8 then click on repair windows then after that you will see 3 option click on the third it will say repair cmd then type as what is given below
Click on the "Repair Your Computer" option to gain access to the System Recovery window. Now choose "Command Prompt" to run the Bootsect.exe utility. Bootsect is located inside the boot folder so change your directory to boot. Now run "bootsect /nt60 C:\" (without quotes) if you had Windows 7 initially installed in the C partition. Alternatively, you can run "bootsect /nt60 SYS" or "bootsect /nt60 ALL" (without quotes) to repair the system partition or all partitions. Eject the DVD and restart your computer. Your computer should now boot Windows 7 again.
Read more: How to Repair the MBR on Windows 7 ' eHow.com http://www.ehow.com/how_4836283_repair-mbr-windows.html#ixzz2CY96TyX0
Nov 18, 2012 | Acer Computers & Internet
Acer aspire 5515 blue screen
hi
yes it may be related to bios setting . Just enter your bios in the laptop (F2)
and for HD change the SATA to ATA or vice-versa. SAVE and retry boot.
(it can also be AHCI to ATA or ATA to AHCI.)
Aug 12, 2012 | Acer Computers & Internet
My acer aspire 7551-7422 says operating system not found
Try running the check disk utility to see if maybe it can recover it.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 03, 2012 | Computers & Internet
I have a acer aspire x1700 that will not boot gives me a message that says windows failed to start status 0xc0000034. it will not run a disk
You can try two things:
1. Boot up and Immediately begin tapping the F8 key. When the Option menu comes up select "Last known good configuration"
2. Sounds like you need to reboot using your windows recovery disc.
If it will not boot up using the disc, try again but press F12 while booting (Sometimes F2 or Del) to get into the Bios settings. Here you can tell the computer to boot up from a disc.
When booted, select Repair your Computer.
Apr 01, 2011 | Acer Computers & Internet
Windows boot manager problem acer aspire 5920
Creating recovery discs After setting up the computer for the first time, be sure to create a set of recovery discs of the full factory image. the recovery discs are used to start up (boot) the computer and recover the operating system and software to factory settings in case of system instability or failure.
Jun 16, 2009 | Acer Aspire 5920-6727 Notebook
Boot problem on Acer Extensa 4220
do a fresh installation of operating system or if your laptop provides recovery then you can also do that. may be your problem is due to system files.
Jun 28, 2008 | Acer Aspire 3000 Notebook
Password
You can try booting in the safemode to see whether the default administrator account is enabled. If it is there then log on to the administrator account and changed the password for the account.
If the administrator account is not enabled then you should have the Vista disc to do system restore. Boot the computer from the Windows VIsta disc.. when you see the setup screen look for Repair your computer link at the left bottom corner. Click that follow the instruction to do system restore.
IF you dont have the vista disc call you Acer support to find how to boot in to Win RE
Good luck
Bala
Jun 25, 2008 | Microsoft Windows XP Professional With...
Won't boot
You need recovery Disc Or Windows Vista disc. Else you need Windows Xp With sata driver in It. Please try to find out from your friends Or from Acer Service center may be they will Help u.
Mar 12, 2008 | HP Pavilion dv6000z Notebook
Open Questions:
How to Remove a Virus from Windows PC or Laptop - Toshiba Dataalign As the number of cybercrimes and harmful online attacks are increasing these days, it is difficult to keep ourselves safe while surfing the websites of various sites online. If you are looking for a safe online risk reduction scenario, then trust the tech support of TechFree for Toshiba products. Toshiba laptops and other devices get best maintenance and recovery by the services of Toshiba support. Toshiba support provides best risk safety from online threats and also recovery for broken computers and other peripheral devices. Online threats in the form of viruses, Trojans and malwares that are prevalent everywhere pose serious safety threats to the customer's personal information. Various other regular issues like slow computers, snail speed processing, recurrent screen freezing, frequent and without reason computer shutting down and restarting etc. also prove to be a reason of headache for the customers. In case you want all your tech issues to get resolved while you can be busy doing your usual life stuffs then get in touch with the fabulously supporting Toshiba supprot team. You can get the benefit of 24/7 tech support service at your home or office by calling on their toll free helpline number Call Toshiba +1888784-9316 Technicians of Toshiba support got certified for involvement of advanced technology and still making it available for customers at affordable prices. Also, many profitable deals and offers are provided to the customers. Your search for that perfect tech support with features like reliability and consistency is over with Online Toshiba support Email service technique makes delivery of support easier and comfortable for the customer. Also, professional tech services become more trust-worthy with the 30 days money back guarantee it comes with. Toshiba technicians make efforts of delivering the best customer support along with proper knowledge sharing which helps the customers to get proper understanding about all issues and their resolutions. For tech related support contact tech service team of TechFree on their toll free helpline number Toshiba Customer +1888784-9316 anytime. Toshiba support providing professional and certified tech experts will use the most appropriate troubleshooting to resolve tech issues in least turnaround time.
Aug 22, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
