Question about Fuji FinePix E900 Zoom Digital Camera
I have a lens error on my Fuji FinePix E900. The lens is stuck and will not retract or close although does attempt to. It makes a lot of noise gets so far then concedes defeat.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 22, 2010
I have a lens error. The lens is stuck and will not retract or close although does attempt to. It makes a lot of noise gets so far then concedes defeat.
Hello
Regards
Andrea
Jul 31, 2010 | Fuji FinePix E900 Zoom Digital Camera
Digital zoom error on an A600, lenz will not retract either
Have you tried spraying a can of compressed air into the lens assembly? All it takes is small piece of debris like a grain of sand to jam up the assembly.
Hope this helps
Jul 07, 2008 | Fuji FinePix A600 Digital Camera
Zoom error ( stuck) fujifilm finepix s2000 hd
The lens is having a hard time retracting out that is why it is giving you that error. Make sure that your battery is fully charged and if it is, but still does not do any good, then do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Nov 27, 2009 | FUJIFILM Finepix A200 Digital Camera
Hi, the zoom wont retract and it says focus error
It won't focus because ya lens is out of focus due to it being stuck had same prob wig my Sony worked out cheaper to buy a new camera than have it fixed.very fiddley to repair hope if bin some help
Nov 23, 2009 | Fuji FinePix A500 Digital Camera
Lens wont retract or extend when pushing the power button and cannot take photos. power will not remain on.
Can you turn the camera on by pressing the playback button? This should turn the camera on to view pictures on the card without opening the lens.
Check the tab on the battery door. it should activate a micro switch next to the card slot on the main board. If this is damaged then the camera will not power up.
If the lens is stuck then this will also prevent power up
Nov 15, 2009 | Fuji FinePix E900 Zoom Digital Camera
Taking a picture, I get a focus error message and the lens won't retract.
Try this post:
http://www.fixya.com/support/t2284005-camera_powers_down_when_pressing_shutter
It is probably a battery problem, I had no error but autofocus didn't work. Replacing batteries solved it.
Gus
Jul 28, 2009 | Fuji FinePix E900 Zoom Digital Camera
Fine-Pix A400 is showing Focus Error and will not allow photos to be taken. In addition, the lens will not retract when the camera is shut off. This problem occurred after using the zoom procedure several...
Here is a quick fix to try. If you attempted to remove the focus error doing the 3 times on and off, and it didnb't help to this. Power the camera on, you will hear the gear skipping as if it is slipping. Right at the moment you turn of the camera push the lens in manually slightly and gently. This will reposition the timing of the lens to focus. This usually fixes the Focus error when the lens is stuck in the out position and never retracts. I have had this happen twice, and it cleared both times by doing this. Good Luck
Jul 22, 2009 | Fuji FinePix A400 Digital Camera
Lense won't close
Does it make a noise when trying to close? Does the lens zoom ok or is it just stuck firm?
Possible solution and/or email help available in "THE ONLY WAY I KNOW HOW..." In tips & tricks. Thanks
Apr 12, 2009 | Fuji FinePix F460 Digital Camera
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Fuji FinePix E900 Zoom Digital Camera Logo
87 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
