Question about Dishwashers
Water will not drain .cycle stops , will not start even on new cycle
    Scholar:
  • 59 Answers
The water will have to be evacuated first. there may be a blockage either in the outlet of the dishwasher or the drain connection under the sink. The dishwasher tries to drain at the very start of the cycle. If this doesnt happen then a new cycle wont start.
Posted on Aug 01, 2010
Water drained out of tube, but dishwasher stops and indicators tell me "drain is plugged."
The drain hose on a dishwasher must be long enough to go up above the water level of the dishwasher and then back down to connect to the sink drain. This is to keep gravity from draining the tank. However, you probably replaced the drain hose the same way it was originally.
Try checking the float and float switch for smooth operation. Maybe the float has debris holding it up from dropping to the true water level.
Jan 10, 2014 | Asko 24 in. D3450 Dishwasher
Maytag centennial washer
Put some water in the washer tub, a few gallon should do it. Then turn machine back on, it will recognize when the water has drained out and stop that cycle.
Aug 05, 2017 | Washing Machines
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 26, 2011 | Maytag Washing Machines
Brand new SGS57A02GB just fitted. Run initial cleaning wash to get rid of factory water. Drain starts then stops, starts filling, goes through 2 filling cycles then the drain pump starts. The drain pump...
This problem is mostly caused by the drain pump or a restricted drain line. Try taking the end of the drain hose off under the sink and re-checking the drain-out condition. If the unit is still not draining, I recommend replacing the drain pump.
Other possibilities could be that the sump is blocked, or the control or harness may need to be replaced.
Hope this helps.
Shane
Feb 01, 2011 | Bosch 24 in. SGS57E02 / SGS57E08 Exxcel...
Keeps filling up with water even on spin
Close the water supply valve and allow the machine to completely drain the water from the tub. Turn off the machine and disconnect it from the power outlet. Open the water supply valve. Replace the water inlet valve if water drips into the tub when the machine is off.
Start a new cycle if the machine stops filling when it is off. The control board or the water level switch is malfunctioning if it keeps filling even during the spin cycle. Indicate the model number for proper troubleshooting and repair assistance.
Feb 05, 2010 | Washing Machines
Won't advance to spin cycle from drain cycle
install new timer....thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Washing Machines
LG WT-R801 keeps draining
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
May 16, 2008 | LG WM0642H Front Load
Dishwashers Logo
144 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
