Question about Formula Option Influence Snowboard 154
Board??? im a beginner only having 5-6 days of experience 5'7" 125 lbs and i was looking at buying a 148cm forum destroyer board for next season. would this be a good selection?
    Problem Solver:
  • 11 Answers
Should be fine, people will tell you to get a longer board, I'm 6'2" and ride a 152cm K2 Zepplin and its great!
Posted on Sep 11, 2010
What's the best stand-up paddle board to buy for a beginner?
If you're new to the sport, this is the place to start. We've narrowed down the selection to our five top picks for beginning to intermediate stand up paddlers, and we've created a handy guide so you can get some clarity and understand exactly what you're getting before you decide on a board.
Click Here : 5 Fishing Kayaks For Beginners: Finding The Best Fishing Kayak
Of course, these are not the only good boards out there, but we think this small pool of boards covers the range of options, and we're confident in the quality of these boards.
If you read nothing else before buying your first SUP, follow this guide and you'll end up with a board that's right for you.
QUICK ANSWER: THE BEST BEGINNER STAND UP PADDLE BOARDS
  • Isle 10'8" Soft Top Foam SUP.
  • California Board Company (CBC) Stand up Paddle Board.
  • Isle 10ft Inflatable Stand Up Paddle Board.
  • Tower Adventurer 2 10'4" Inflatable SUP Package.
  • Tower Adventurer 9'10" Inflatable SUP Package.
Click Here : Fishing Kayak Care: A Brief Guide To Beginners
Apr 12, 2018 | Water Sport
What are the head bolt torque specifications on a 2003 Suzuki volusia?
Hi Tony, most of the fasteners on a Suzuki are made of medium carbon heat treated steel SAE grade 5 or better.
1/4"-10 ft-lbs. 6.4mm-15nm
5/16"-20 ft-lbs. 7.9mm-25nm
3/8"-35 ft-lbs. 9.5mm-45nm
7/16"-55 ft-lbs. 11.1mm-75nm
1/2"--75 ft-lbs. 12.7mm-110nm
For more information about your issue, please visit the websites below. Good luck and have nice a day.
2003 Suzuki volusia head bolt torque sequence Google Search Torque Wrench Suzuki Volusia Forums Intruder Volusia and Boulevard Forum
Suzuki volusia owners manual pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 27, 2015 | Suzuki Motorcycles
1997 ford countour right tail light not working.
both sides use the same fuse so if one is working the fuse is good. use a test light to check for power and grounds at the back of the socket then proceed to find were the break is in the wiring.
Apr 09, 2015 | 1997 Ford Contour
Torque specs for 2013 road king classic exhaust flange nuts
Hi, Julian most of the fasteners on a Harley Davidson are made of medium carbon heat treated steel SAE grade 5 or better.
For more information about your issue and valuable free downloads that you will need please visit the websites below, and for specific information or questions please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
Head pipe torque spec Harley Davidson Forums
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Mar 26, 2015 | Road Motorcycles
My vespa lx 125 ie is having problems starting, what could this be?
Hi, Josmerriman9 and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.
8. Faulty fuel pump.
9. Intake air leak.
10. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
11. Enricher valve inoperative.
12. Engine lubricant to heavy (winter operation).
13. Ignition is not functioning properly (possible sensor failure).
14. Faulty ignition coil.
15. Valves sticking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Modern Vespa Vespa LX 125 startup problems
http://modernvespa.com/forum/wiki--won-t-start-diagnosis-for-beginners
http://www.vespaclub.org.pl/images/manualki/lx/LX-S-125-150-3v-ie.pdf
Products at Vespa Genuine Parts
VESPA LX 125 150 Euro 3 User Manual
Jun 16, 2011 | 2011 Vespa LX 125 ie
Im looking for the torque specs for the cylinder bolts & the cylinder head bolts.
Hi Jbharshbarge, most of the fasteners on a Harley Davidson are made of medium carbon heat treated steel SAE grade 5 or better.
1/4"-10 ft-lbs.
5/16"-20 ft-lbs.
3/8"-35 ft-lbs.
7/16"-55 ft-lbs.
1/2"--75 ft-lbs.
For more information about your issue, please visit the websites below, and for specific information or questions please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
Sprint 175 250 350
Feb 14, 2011 | Aermacchi Sprint 350 Motorcycles
How to modify yamaha RX100 in yamaha YZ 125
it is possible in a city like bangalore
Apr 02, 2010 | 2003 Yamaha YZ 125
Snowboard length calculation
"Your height (inches) x 2.54 x 0.88 = Suggested Board Length Rider Height Range of Board Length 4 Feet 109cm 4'2"" 114 -120cm 4'4"" 115 - 125cm 4.6"" 118 - 135cm 4.8"" 120 - 135cm 4'10"" 125 - 140cm 5 Feet 130 - 142cm 5'2"" 135 - 145cm 5'4"" 140 - 148cm 5.6"" 145 -152cm 5'8"" 147 -155cm 5'10"" 154- 163cm 6'0"" 157-165cm 6'1"" 160-168cm 6'2""+ 159cm or greater"
Dec 01, 2008 | All Star Forum Star Women's Snowboard
Snowboarding skill level
In Snowboarding, the skill level is divided into three types: * Newbie - from total beginner to having a few days of riding experience * Intermediate - comfortable with common riding techniques and starting to try tricks * Advanced - comfortable with riding all pistes and off slope; advanced tricks and skills"
Gps module
I just went through this with Lowrance. tthe LGC 2000 module on my LCX 20 depth finder "quit responding" out of the clear blue. You have to go Lowrance.com and they have some tests you can follow to see if it is a bad cable or the module itself. I had to replace the module. They charged $99 bucks plus $12.50 shipping for a new one. I bought it spring of 2008, and the unit was 3 months out of warranty when it quit working. Last season I had lower back fusion and didn't use it except for 2 times late in the season. Getting ahold of Lowrance is going to be an experience. I called twice and waited on hold over 35 minutes before I was suddenly cut off both times. I tried email too, but it took 3-5 days to receive a response. Mine broke down June 18 of this year. I started trying to get hold of Lowrance the next day. By the time all the back and forth emails with the delayed responses were done, I received my new unit on July 24. 5 weeks! with out my gps in MN. It is a short season up here as it is. I sure didn't enjoy waiting that long.
Oct 19, 2007 | Lowrance LGC-2000 GPS Unit GPS Receiver
Formula Option Influence Snowboard 154 Logo
105 people viewed this question
Top Formula Winter Sports Experts
Arnie Burke
Arnie Burke
Marvin
Marvin
vtrktrmn
Are you a Formula Winter Sport Expert? Answer questions, earn points and help others
